Rapair Kawasaki 840703
Forum topic by garyhi posted 02-28-2015 06:32 PM 750 views 0 times favorited 2 replies Add to Favorites Watch
View garyhi's profile
garyhi
1 post in 1179 days
02-28-2015 06:32 PM
I pluged in my air compressor and it runs great until it reaches 45psi then it stops until I reset the built-in breaker. Does any one know what’s going on?
2 replies so far
View ohtimberwolf's profile
ohtimberwolf
799 posts in 2348 days
#1 posted 02-28-2015 07:03 PM
Sounds like a weak or defective breaker. Does it do this always at that pressure or is it after a certain amount of time or seconds of running that it trips?
-- Just a barn cat, now gone to cat heaven.
View MrUnix's profile
MrUnix
6705 posts in 2195 days
#2 posted 02-28-2015 07:14 PM
Bad overload protector, defective pressure switch, bearings going south in the motor, lack of lubrication in the pump or pump going bad, clogged air inlet port… could be any number of things. Until you narrow it down with some testing, all you are going to get is guesses.
