| Forum topic by kimball | posted 188 days ago | 344 views | 0 times favorited | 12 replies | ![]() |
188 days ago |
188 days ago |
How wide and tall is each door or is there only one? -- Never board, always knotty, lots of growth rings |
188 days ago |
There will be 2 doors w/ a center stile between them. The doors will be 22 1/2×56 and I am conscerned about sag w/ a conventional cabinet rail and stile router bit. |
188 days ago |
Correction: door size will be 22 1/2” x 50” ( overall height of cabinet is 56”) |
187 days ago |
You can add floating tenons to the cope and stick if your concerned about there strength -- Jim from Heirloom Woodshop Southern Oregon |
187 days ago |
mitered half lap are strong enough.. i would go with Jim, loose tennons. another very strong joint that you don’t see much anymore is saddle joints.. twice the glue surface as half lap.. very easy to cut.. i use them on aquarium stands where i need to support up to a ton of water so they are strong -- It's not a sickness, i can stop buying tools anytime. |
187 days ago |
John, What is a saddle joint? -- Debt is nothing more than the 21st Century's form of slavery. |
185 days ago |
In the craftsman style aren’t you suppose to use a mortise and tenon joint or floating tenon if you like that better? |
178 days ago |
I don’t know what I was thinking. I have been using rail and stile bits for so long, I forgot about old fashioned joinnery (slower but better). Thanks you wonderful wood chucks. |
177 days ago |
M&T or floating tenons would be best. Doors that size should be about 1” thick to avoid racking when they are being opened. Is the glass insert full length or divided lights? |
173 days ago |
Hey Vincent, Hey Topmax Vincent picture depicts a saddle joint. |
164 days ago |
It is also called a bridle joint or open mortise and tenon joint. That should explain it. -- My philosophy: Somewhere between Norm and Roy |
164 days ago |
hey skeeter, |
| Forum | Topics |
Woodworking Skill Share
2916 |
3944 |
256 |
949 |
224 |
Woodworking Trade & Swap
619 |
Coffee Lounge
2386 |
LumberJocks.com Site Feedback
524 |
