Throat plate tabs
Forum topic by nerdbot posted 02-28-2015 12:26 AM 966 views 0 times favorited 8 replies Add to Favorites Watch
View nerdbot's profile
nerdbot
97 posts in 1236 days
02-28-2015 12:26 AM
Hi all,
I have a Dewalt DW744X portable jobsite table saw, and in the last few months one of the throat plate tabs broke off. Because the saw is still under warranty (past the 1 year warranty, within the 3 year limited warranty), I called up Dewalt and arranged to have it serviced. When I dropped it off at the service center for pickup, I was told the throat plate tabs isn’t a manufacturer defect, that it is normal wear and tear, and won’t be covered under the warranty. After calling Dewalt again and talking to a manager at the repair center, I was told it was “user error” that broke it. The saw is still usable obviously, I just have to be that much more conscious about how I use it to stay safe.
Since this is my first table saw, and I use this as a hobby woodworker (a few hours on the weekend), I’m not familiar with what is considered normal wear and tear on a table saw or how common/likely it is under “normal” use for a throat tab to break off. The top isn’t cast iron, but I’m not sure what kind of material it is – it’s not magnetic, that’s for sure. I realize this type of saw isn’t meant for fine woodworking (it was what I could afford/justify at the time I started woodworking), but I wanted to see what the community thinks just to make sure I’m not off-base on what my expectations are.
Thanks in advance everyone!
8 replies so far
View paxorion's profile
paxorion
1107 posts in 1920 days
#1 posted 02-28-2015 05:21 AM
The table top is a cast aluminum. Was the tab broken on the throat plate or on the table saw top? Any pictures?
-- paxorion
nerdbot
#2 posted 02-28-2015 05:47 AM
Hi Paxorion,
No, not of my saw and the Dewalt repair center currently has it. But, it’s the throat tab on the table saw top itself, like in this picture:
When standing in front of the saw, it’s the back left tab that broke.
paxorion
#3 posted 03-02-2015 03:43 AM
That is a very odd place for the table to break. Those tabs are used to support the leveling screws and should not be load bearing. I’d personally push for the service manager to explain how it can be “wear and tear”. Can you also shed some light on what caused the tabs to break?
-- paxorion
View JAAune's profile
JAAune
1772 posts in 2191 days
#4 posted 03-02-2015 03:46 AM
Not wear and tear. I’ve never seen this issue on any saw nor have I heard of such a thing from any other woodworkers.
Either the saw is defective or you (or someone else) somehow subjected it to heavy weight or a sharp impact.
View MrUnix's profile
MrUnix
6199 posts in 2074 days
#5 posted 03-02-2015 03:50 AM
That ain’t “normal” wear and tear.. if that were the case, then the whole table top would need to be replaced every so often, which is NOT acceptable, or anything close to normal. They may however have determined that the damage was caused by abuse, but that’s a hard sell. How did you manage to break it anyway? If it just broke on it’s own, then I agree with Paxorion, bump it up the food chain. It’s still under warranty, so they should make it right. If you slammed something into it, then you will probably need to suck it up and pony up the bucks to get a new table top if you want it fixed.
nerdbot
#6 posted 03-02-2015 03:25 PM
I’m not sure what caused the tab to break. The only thing I can think of is I regularly rip dense 8/4 stock (Jatoba, hard Maple, Hickory) for cutting boards and when I first got started I was just using the stock Dewalt 40T blade it came with. Very occasionally there would be a lot of vibration during the cut (felt like the saw was rattling). As I got better and got a proper ripping blade that went away. I do have the plate raised a bit higher in the back – the throat plate opening is beveled and I noticed that unless the back of the plate is a fraction higher than the top (a suggestion in the saw manual) at the back some pieces tend to catch. As a result, the paint on the back of the throat plate is wearing off and I can see bare metal. Not sure if that makes a difference or not.
But I’m very careful when working in side the throat plate area when changing blades, etc, so I know I haven’t dropped anything on or in there like the manager suggested. Never dropped the saw either as it’s bolted to a mobile base I made so it just rolls around in my garage.
As it stands, after a bit of discussion, I was able to get them to take the saw anyway (I dropped it off at a pickup location, actual repair center is in a different city) to have an actual tech look at it and give me a more definitive answer. The manager said he’d get back to me by the end of this week, so fingers crossed.
Thanks for the replies!
View devann's profile
devann
2246 posts in 2567 days
#7 posted 03-05-2015 06:42 AM
Hello nerdbot, flipping through the forum section looking for my last forum post I noticed your Throat plate tabs thread. Hopefully DeWalt will be able to repair your saw. But if not, looking at what you have I may have a solution to your dilemma. My shop TS (table saw) is of the vintage variety, a 1964 Boice Crane. When I got it, the “throat plate” (ZCI, zero clearance insert) had been hogged out by the previous owner for a dado setup. I like a ZCI for obvious safety reasons, and on a homemade TS that I built I made several ZCIs so I could change them has I changed the angle setting on the saw. When I got the olderTS with the hogged out ZCI I decided to make myself some plywood ZCIs for the saw. The metal one that came with the old saw is fairly heavy, (must weigh 4-5 lbs) and the weight alone holds it in place. I went ahead and made several plywood ZCIs and drilled each at the drill press to keep the hole locations uniform. I then made my on clips to secure the plywood ZCIs. You can see pictures of them here http://lumberjocks.com/devann/blog/22030
1. To aline the clips I placed the plywood ZCI in place,
2. Marked the approximate hole location on the table top
3. Remove plywood ZCI, Install the clips, Shoot a blast of spray paint to mark clip location should they fall inside TS .
4. Replace pylwood ZCI and carefully drill holes in clips using self tapping drywall screws.
Hope this will give you some ideas if you have to fix it yourself.
nerdbot
#8 posted 03-05-2015 08:11 AM
Hey Devann, I’ll keep your post in mind if it does come down to me having to fix it myself. Thanks for the info!
