What's the difference between finger joints and box joints?
« back to Joinery forum
Forum topic by utwoodhacker posted 02-27-2015 04:33 PM 1586 views 0 times favorited 18 replies Add to Favorites Watch
View utwoodhacker's profile
utwoodhacker
6 posts in 1057 days
02-27-2015 04:33 PM
Topic tags/keywords: finger joint box joint joints question router joining
I’ve had discussions with a buddy of mine about this topic. He says that these two joints are one in the same. He’s more experienced than I am, but I don’t think he’s correct on this topic. I see both sides mentioned all over the internet. Someone took the liberty of posting on wikipedia that they are the same.
Am I right or am I wrong on this one? BTW, it really doesn’t matter to me if I’m wrong. It’s just that I don’t think I am and well, you know how a debate can go with a buddy that always thinks he’s right.
-- UTWoodHacker, Utah
18 replies so far
View ADHDan's profile
ADHDan
800 posts in 1977 days
#1 posted 02-27-2015 05:05 PM
I’ve always used them identically.
What do you think is the difference between them?
-- Dan in Minneapolis, woodworking since 11/11.
View crank49's profile
crank49
4028 posts in 2840 days
#2 posted 02-27-2015 05:05 PM
/Users/tawana/Downloads/vertfingjnt.jpg
This is what I call a finger joint.
/Users/tawana/Downloads/WoodJointsTT8.jpg
And this is what I call a box joint.
I have heard people refer to the latter as a finger joint but never the other way around.
crank49
#3 posted 02-27-2015 05:07 PM
Well, can’t get this MAC to post images, but the following post shows what I was trying to show.
Finger joints are to splice boards and box joints make corners.
View JayT's profile
JayT
5488 posts in 2080 days
#4 posted 02-27-2015 05:08 PM
A lot of people use the terms interchangeably to refer to the corner joint. Personally, I call those corners a box joint and use finger joint to refer to the similar technique used to scarf two pieces together to form a longer piece, like this:
Don’t know if the way I use the terms is correct, but it at least keeps the different techniques and applications separate in my head.
View jakep_82's profile
jakep_82
105 posts in 2175 days
#5 posted 02-27-2015 05:09 PM
My take on it is that all box joints are finger joints, but not all finger joints are box joints.
ADHDan
#6 posted 02-27-2015 05:11 PM
- jakep_82
Whether or not this is dictionary-definition true, I really like this answer.
Edit: perhaps I have been wrong all this time; I never really thought about using the term finger joints for end-to-end scarfing, but it makes sense.
View JayT's profile
JayT
#7 posted 02-27-2015 05:28 PM
- jakep_82
- ADHDan
Makes sense to me, too. A finger joint would be any joint that uses “fingers” of wood interlaced to make a connection, while a box joint is a specific application of a finger joint used to make a corner.
View TheFridge's profile
TheFridge
8633 posts in 1355 days
#8 posted 02-27-2015 05:47 PM
To me, finger joints are small and box joints are bigger than the small ones :)
View SirIrb's profile
SirIrb
1239 posts in 1099 days
#9 posted 02-27-2015 06:04 PM
In my experience finger joints are used to put together wood in length and usually cut with tapered fingers. Finger jointed moldings is one example. You must paint it. Box joints are used to put together pieces of wood that will join at an angle i.e. a box.
View Picklehead's profile
Picklehead
1041 posts in 1798 days
#10 posted 02-28-2015 12:45 AM
SirIrb: “You must paint it.”
Why?
-- You've got to be smarter than the tree.
View splatman's profile
splatman
586 posts in 1268 days
#11 posted 02-28-2015 01:38 AM
Yeah, aren’t there some people that like that finger-jointy look?
View gfadvm's profile
gfadvm
14940 posts in 2559 days
#12 posted 02-28-2015 01:59 AM
My understanding is the same as Jay T’s. But I do see the terms used interchangably.
View Dark_Lightning's profile
Dark_Lightning
3017 posts in 2978 days
#13 posted 02-28-2015 02:00 AM
You must paint it in the sense that stain grade wood is seldom used for a finger joint.
-- Random Orbital Nailer
utwoodhacker
#14 posted 03-02-2015 05:03 PM
- jakep82
- jakep82
- ADHDan
- JayT
I think these really make a lot of sense. So, going back to my original post, I guess you can say that my buddy and I are both right, but it depends on the specific application. Thanks for all of the input.
SirIrb
#15 posted 03-02-2015 06:32 PM
If you buy finger jointed molding specifically it is sold as “Paint Grade” because it looks like crap if you just clear it. It is made from the dregs and cutoffs in at the molder. You get a bunch of 12” pieces glued together and molded. So specifically molding, yes, paint grade.
Why?
- Picklehead
