Triton in a Table
Forum topic by HickoryHill posted 02-27-2015 04:05 PM 793 views 0 times favorited 5 replies Add to Favorites Watch
View HickoryHill's profile
HickoryHill
219 posts in 4324 days
02-27-2015 04:05 PM
For all of you who have the big Triton in a Router Table, did you take the clear dust shroud pieces off or leave them on? I took them off thinking it wouldn’t limit the flow.
-- Jim, Michigan
5 replies so far
View goochs's profile
goochs
60 posts in 1408 days
#1 posted 02-27-2015 07:22 PM
I left mine on. I have an INCRA LS Wonder fence which also has an outlet to hook a vacuum up to and for some profile the hook to that but for others I use the one on the triton which really sucks the chips.
View jakep_82's profile
jakep_82
105 posts in 2484 days
#2 posted 02-27-2015 07:28 PM
I also have an Incra setup with this router. I left the shroud on, and I get surprisingly good dust collection with my shop vac when it’s connected to the built in port on the router. I also have the Cleansweep insert rings which makes a noticeable difference.
View Lumberpunk's profile
Lumberpunk
334 posts in 2515 days
#3 posted 02-28-2015 02:47 AM
Shroud on… great dust collection even with a small shop vac.
-- If someone tells you you have enough tools and don't need any more, stop talking to them, you don't need that kind of negativity in your life.
19274 posts in 2035 days
#4 posted 02-28-2015 03:00 AM
I have the triton in a cabinet where dust collection is connected to the cabinet and draws a vacuum thru the hole. I left the shroud on for a while, but it started to collect chips so I removed it.
HickoryHill
#5 posted 02-28-2015 04:49 AM
Mine is in an enclosed cabinet as well.
-- Jim, Michigan
