R4512 Wobble
Forum topic by Garbanzolasvegas posted 02-27-2015 02:32 AM 1391 views 0 times favorited 25 replies Add to Favorites Watch
View Garbanzolasvegas's profile
Garbanzolasvegas
356 posts in 1256 days
02-27-2015 02:32 AM
Seems my hate filled message to ridged did not get me any love from Ridgid Sooooo…
I have an arbor that makes my $75 freud blade wobble to at least 1/64th. SOOO Now for the time being I have to find the part of the blade that it closest to the fence MARK it and take my measurements off that part of the blade and the fence.
BUT if I have to take the blade off, say to use a dado, I will have to MIC it and mark it all over again. Can anyone think of how I can INDEX the arbor so I can use its Far right travel to mark it so I can mark the blade again to make my measurements between to teeth closets to the fence to do my measurements
THIS SUCKS…... HARD!
I really really really want to curse bad on here right now
-- If you don't Play, you can't win
25 replies so far
View Deycart's profile
Deycart
444 posts in 2286 days
#1 posted 02-27-2015 03:16 AM
You should remove the blade and really clean the arbor. Then using a dial indicator on a stand measure the high spots and lightly file them down on the arbor. (This assumes your arbor is straight). I had to do this to a saw I rehabbed last year. Only took about 30 min. Took more time to set up it up than to file the high spots.
View RobS888's profile
RobS888
2415 posts in 1874 days
#2 posted 02-27-2015 03:33 AM
Could you find the high spot then whack it?
Any chance your trunion bolts are not tightened or some grit got between the table and trunnions to tilt it a little? Have you adjusted them recently?
-- I always suspected many gun nuts were afraid of something, just never thought popcorn was on the list.
View waho6o9's profile (online now)
waho6o9
8209 posts in 2605 days
#3 posted 02-27-2015 03:39 AM
You get more flies with honey
Garbanzolasvegas
#4 posted 02-27-2015 01:10 PM
Yes I put a MIC to it last night and there is definitely RUN OUT not as bad as a 64th but half that. I marked my blade and put a little mark on the arbor so at least I can tell where the far rightest area is so I can at least keep working.
DEYCART I have already done all that.
WAHO6o9: What are they gunna do? Send me another defective arbor! Every part that RIDGID produces is SHEET! DEFECTIVE from top to bottom. And what gets to me …. NO one can do this by accident! IF they were completely incompetent at least SOME of their units/parts would work correctly. A broken clock is right twice a day! I mean you have to do this on purpose! Every part of the R4512 is SHEET and defective! YOU HAVE TO DO THAT ON PURPOSE!
View bondogaposis's profile
bondogaposis
4770 posts in 2380 days
#5 posted 02-27-2015 01:41 PM
You should remove the blade and then place another table saw under it.
-- Bondo Gaposis
View Mark Davisson's profile
Mark Davisson
597 posts in 3346 days
#6 posted 02-27-2015 01:41 PM
Some of Ridgid’s parts work correctly, in my opinion.
-- I'm selfless because it feels so good!
RobS888
#7 posted 02-27-2015 01:49 PM
- bondogaposis
That’s what I did!
Garbanzolasvegas
#8 posted 02-27-2015 02:26 PM
Lets say Ridgid manufactured cars.
The Wheels would be square, the doors would open to swing to the INSIDE of the car instead of out. The windshield would be made out of plywood and the gas tank would be made out of glued up matches and placed on the roof.
But it does have a life time warranty.
What I am trying to say is THIS can NOT be done because of chance or bad management or coincidence… If you replaced all the officers at RIDGID with retarded retired circus chimps, HELL they could do a better job, but the entire company has to be making these defective products on purpose, They have to be doing this to see what fools the american consumer is and laughing at them. It’s a miracle really!
Every critical part of my TB and I suspect every product the sell IS/ARE DEFECTIVE… EVERY DAMN ONE and they could give a F**K less
View ohtimberwolf's profile
ohtimberwolf
816 posts in 2381 days
#9 posted 02-27-2015 02:34 PM
If that saw gets crazy bad do what Bondo (post #5) said….your heart will last a lot longer.
-- Just a barn cat, now gone to cat heaven.
View verdesardog's profile
verdesardog
161 posts in 2640 days
#10 posted 02-27-2015 02:46 PM
your arbor does have to be spot on. If it is just .01 out a 10 inch blade will be .2 out!
-- .. heyoka ..
View altendky's profile
altendky
169 posts in 2239 days
#11 posted 02-27-2015 02:53 PM
Perhaps with an appropriate jig and safety precautions you could flatten the arbor while it is spinning? Done well it would be perfectly flat and true without even measuring. Also, if within 90 days it should be returnable?
View SirIrb's profile
SirIrb
1239 posts in 1259 days
#12 posted 02-27-2015 02:57 PM
How would the honey sound? “Your great saw sucks”?
It is an anchor. Sell it with the boat and use the money you made from it to buy another saw.
- waho6o9
Garbanzolasvegas
#13 posted 02-27-2015 03:11 PM
- waho6o9
Already there!
- SirIrb
Garbanzolasvegas
#14 posted 02-27-2015 03:12 PM
- verdesardog
Try a half a 64th
Garbanzolasvegas
#15 posted 02-27-2015 03:14 PM
- altendky
Return a assembled 300 pound beast? to Home depot 50 miles away. I should have doe that the week I bought it. Yes its my fault for thinking I could make this damn RIDGIS TS work
