Router speed suggestion?
Forum topic by BroncoBrian posted 02-26-2015 11:45 PM 1021 views 0 times favorited 16 replies Add to Favorites Watch
View BroncoBrian's profile
BroncoBrian
831 posts in 2134 days
02-26-2015 11:45 PM
Topic tags/keywords: router bit speed incra cleansweep
I am setting up a Rockler table, Incra lift with a new PC 7518 router. It is a five speed and I am going to install it with the Incra Clean Sweep dust system but the switch is placed where the router will have the speed switch away from the door to the box.
The speeds are 10k, 13k, 16k, 19k, 21k
Curious what speed is the most likely setting for average size bits or how much any of you change speed on your router. I can get the the switch but it will not be easy to read.
Curious if anyone has a pointer for me.
-- I think they could take sesame seeds off the market and I wouldn't even care. I can't imagine five years from now saying, "Man, remember sesame seeds? What happened? All the buns are blank."
16 replies so far
View timbertailor's profile
timbertailor
1594 posts in 1600 days
#1 posted 02-27-2015 12:06 AM
ALWAYS FOLLOW THE ROUTER BIT MANUFACTURERS RECOMMENDATIONS FOR ROUTER RPM SPEEDS.
If they are not listed on the packaging, go to their website or send them an email.
The general rule is the larger the bit, the slower the speed setting.
View dawsonbob's profile
dawsonbob
3066 posts in 1931 days
#2 posted 02-27-2015 02:29 AM
If you’re only going to use one size bit, the set the appropriate speed, and you’re all done. If, however, you’re going to be using a mix of small and large bits, you’ll need to change speeds to suit the bit. In other words, there’s no one answer as to speed: you’ll need access to the speed control.
-- Mistakes are what pave the road to perfection
MrUnix
7005 posts in 2375 days
#3 posted 02-27-2015 02:50 AM
Unless you have a fixed speed router :)
The Bosch 1617 has a fixed speed of 25,000rpm.. as does my C-man. I’ve seen others that even though are variable, only have something like a 19,000-22,000 rpm range or thereabouts (don’t remember exactly off hand). I’d set it for the fastest it will go and only worry about it when using really large bits that need it slower. For most work, you want it to be as fast as possible (round overs, bevels, straight bits.. most of which are not really that big).
dawsonbob
#4 posted 02-27-2015 02:56 AM
Excuse me Brad, but the Bosch 1617 is a variable speed, soft start router, not a fixed speed. I’m sitting about ten feet from mine, so I’m sure of that.
timbertailor
#5 posted 02-27-2015 03:00 AM
I guess people like to open themselves up to a law suit. What I wrote in caps was for a good reason.
MrUnix
#6 posted 02-27-2015 03:12 AM
Nope.. 25,000 fixed speed.. here it is on Bosch’s web site:
http://www.boschtools.com/Products/Tools/Pages/BoschProductDetail.aspx?pid=1617
What you got is the 1617EVS or 1617EVSPK which ARE variable speed.
BroncoBrian
#7 posted 02-27-2015 03:14 AM
You are right about following the bit speed rating. Looks like I will be able to change it easily enough, just might have to make a not of the speeds from front to back as I will not be able to read it on the router.
Should be ok though.
Thanks, Brian
dawsonbob
#8 posted 02-27-2015 03:51 AM
Well, I’ll be danged. I stand corrected, Brad.
You are absolutely correct. When you said 1617 I immediately thought of variable speed, as I think most people would. I’m a fan of Bosch routers, yet had no idea that anything in the 1617 series was fixed speed. And you’re correct; mine is the 1617 EVSPK.
Live and learn, as they say.
View Garbanzolasvegas's profile
Garbanzolasvegas
356 posts in 1403 days
#9 posted 02-27-2015 01:24 PM
Soft start. Yes my DeWalt has soft start. What I hate about it is that one can not, RETSTART the motor turning until it has completely stopped
-- If you don't Play, you can't win
BroncoBrian
#10 posted 03-12-2015 03:34 AM
Thanks everyone. I was able to mount the speed switch to the back side and will be able to reach through the Incra cleansweep to adjust. I just have to note the five positions b/c I will not be able to see the lines and numbers. Now that I think about it, the switch will be upside down and it might not be an issue.
On to the next project….
View MT_Stringer's profile
MT_Stringer
3182 posts in 3407 days
#11 posted 03-12-2015 03:41 AM
- BroncoBrian
You can tell by the sound whether you are spinning it fast or slow. Start slow and go up counting the changes each time.
My Bosch is “electronic variable speed” so I simply turn the knob to change the rpm. I run it by ear. :-)
View TheFridge's profile
TheFridge
10506 posts in 1662 days
#12 posted 03-12-2015 03:45 AM
Fast.
View pintodeluxe's profile
pintodeluxe
5784 posts in 2989 days
#13 posted 03-12-2015 04:17 AM
The thing about router speed that most people don’t consider it that faster speeds means higher power output from the router. Luckily your router has plenty of power, so that’s not an issue for you.
In general the smaller the bit, the faster the speed. Bits with 1/4” or 1/2” cutting diameter can run close to full speed. Large diameter profiling bits and panel raising bits will run slower.
View JeffP's profile
JeffP
573 posts in 1567 days
#14 posted 03-12-2015 01:06 PM
Is the slower speed for larger bits a safety issue (might fly apart)?
Or does it have to do with the quality of the cutting?
-- Last week I finally got my $*i# together. Unfortunately, it was in my shop, so I will probably never find it again.
19259 posts in 2032 days
#15 posted 03-12-2015 01:17 PM
It’s about the speed the cutter is traveling. Router speed is rpms. Small bits travel a short distance to make one revolution, but big panel raising bits travel a much longer distance to make one rev. If that big bit were set to 24,000 rpms, then the cutter would be traveling much, much faster than a 1/4” bit at the same rpm.
