Forum topic by AESamuel | posted 02-26-2015 07:42 PM | 1781 views | 0 times favorited | 18 replies | ![]() |
Hi there, Fairly new woodworker here. I’ve been using a lot of pre-planed s4s pine for making things but I’ve started to prepare my own wood from the local hardwood dealer which is pretty much square but with a band sawn surface. So how flat do I need to be? I did have the idea of using a level which is about 1 cm wide which wouldn’t let as much light through and would give me more of a general level of flatness but should I be aiming for “perfect” flatness where a metal ruler shows no light underneath? Many thanks from a quizzical newbie! |
18 replies so far
#1 posted 02-26-2015 07:56 PM |
First thing, is your combination square blade perfectly straight ? Check it against a table saw top or a granite counter top and see if you can still see light. You need to have a reference surface that is guaranteed straight/flat to start from. A piece of aluminum angle extrusion stock is usually very straight as well. How flat you get your wood depends on your own personal preference for exactness and the nature of the project. If it’s a garden planter then it doesn’t need to be dead flat. If you’re cutting joinery on the piece and you want it to be crisp with no gaps then those light showing low spots will be visible in the final piece. A tenon shoulder or dovetail baseline with a low spot on the face of the board will show as a gap. |
#2 posted 02-26-2015 08:03 PM |
Can I offer “if it feels flat, it is flat.” That means, of course, if you’re happy with the feel (and fit), it doesn’t really matter what the straight edge says… -- Don't anthropomorphize your handplanes. They hate it when you do that. -- OldTools Archive -- |
#3 posted 02-26-2015 08:08 PM |
Run it through a jointer and planer….it’ll be flat enough… -- " At my age, happy hour is a crap and a nap"..... |
#4 posted 02-26-2015 08:25 PM |
One: A #4 is too short to make a table top “flat” Two: Need a much longer plane. It will take down the “high ” spots, while skipping ove the low ones. When you can get a shaving full a full pass of that longer plane, stop, and move a little to the next high points. When all points can produce a full shaving the length of the pass, top is flat. Three: Wood will move over time, so what is flat now, may not stay that way over the years. Nature of the wood. Get it as close as YOU feel is flat enough, and call it good. -- A Planer? I'M the planer, this is what I use |
#5 posted 02-26-2015 08:30 PM |
This! You are making a project from wood. Even if it were possible to get it dead flat, as soon as temperature or humidity changes, it’ll be slightly out. Get the piece to where you are happy with how it looks to the eye and feels to hand and call it good. -- In matters of style, swim with the current; in matters of principle, stand like a rock. Thomas Jefferson |
#6 posted 02-26-2015 08:58 PM |
Flat is dependent on the project. You will never get wood “truly flat” and have it stay that way; it moves and always will. If you are going to build something like a box, getting the faces flat may be somewhat less critical than other projects. Also, checking for light is a good technique, but only if you know how much light should come through. The human eye can see light through an opening of less than a thousandth of an inch, which is way more than wood needs. A set of feeler gauges comes in handy, because then you can quantify how out of flat you are. If you are 2 thousandths out of flat, I would say that is more than good enough. If you are 10 or 15, then your application may require further flattening. One final note on the light thing, if you are using a hardware stole metal ruler, it may not be perfectly straight. -- Brian T. - Exact science is not an exact science |
#7 posted 02-27-2015 01:19 PM |
I’d reccommend Rob Cosmons rough to ready. His technique where he would take the cut piece and rub it down on a known flat surface. I used my TS top. Lift up the piece and the high spots will be burnished and easily visible. Worked great. For Twist, I use winding sticks. A Good square will tell you a lot for a specific point but not the entire surface. -- Sooner or later Liberals run out of other people's money. |
#8 posted 02-27-2015 02:28 PM |
Rule of thumb. Place the wood on a level surface. Try to rock it on the sides. If no rocking it is generally good enough. If the surface is expected to as precise as a machine…........ The poor plane will suffer. 1-3 thou is good enough in all conditions I can think of. Just remember that wood moves too. |
#9 posted 03-06-2015 07:34 PM |
Thanks for all the replies! I took a piece of oak that I flattened and put a small piece of printer paper underneath the ruler from my combination square, apart from a 0.5” strip along one side, I couldn’t pull the paper out from underneath the edge of the ruler. Is this flat enough? (I’m mainly making candle holders but I’m starting a foray into dovetails boxes!) |
#10 posted 03-06-2015 07:35 PM |
Double post. |
#11 posted 03-06-2015 09:12 PM |
You need a jointer and a planer. Any amount out of flat is going to translate the error to the rest of the project. You’ll just frustrate yourself and waste wood until you do it right. -- --Dale Page |
#12 posted 03-06-2015 09:38 PM |
That’s not possible for me – I do woodworking in my living room. I also want to use hand tools as much as I can – people managed for hundreds of years without a jointer and a planer so I’m sure I can too. |
#13 posted 03-07-2015 02:37 AM |
The paper test sounds like you’ve got it flat enough. |
#14 posted 03-07-2015 03:23 AM |
AESamuel, you bring up a very good point. People have done it by hand for thousands of years…I think we sometimes get wrapped around the axel about using machines to reach perfection when it’s completely within our grasp to accomplish the same by hand. In my opinion, slight imperfections are a sign of hand workmanship and should be embraced over sterile machining. Machines make the process easier not necessarily better. -- Do or do not...there is no try - Master Yoda |
#15 posted 03-07-2015 03:29 AM |
I moved up to a 4 1/2 and will begin using a 5 1/2 as soon as I get in on line. My projects have been slightly smaller 10”-20” If I was going much bigger I’d pull out my 7. I picked up a woodpecker tri square last month and using it like you for light gaps. Sounds like you right on the money. I’m tackling half blind dovetails with a Leigh jig. Having a bit of trouble getting the joint snug. The wood flatness is not the issue for me, it’s the adjustments. I have to agree with Warrior. You can get to wrapped up looking for perfection. |
Forum | Topics |
Woodworking Skill Share
12033 |
Woodturning
2108 |
Woodcarving
431 |
Scrollsawing
340 |
Joinery
1370 |
Finishing
4906 |
6696 |
28067 |
CNC Woodworking
212 |
Hand Tools
5412 |
Jigs & Fixtures
1420 |
Wood & Lumber
6233 |
1388 |
Focus on the Workspace
2154 |
1187 |
Woodworking Trade & Swap
4759 |
LumberJocks.com Site Feedback
2200 |
Coffee Lounge
8846 |
