| Forum topic by Robin1976 | posted 190 days ago | 650 views | 0 times favorited | 19 replies | ![]() |
190 days ago |
Topic tags/keywords: mdf workbench finish beginner Hey everyone, I’m new to woodworking and slowly developing my skills as I go. I made a very basic workbench out of entirely 2×4’s… typical 96” lengths you can get at any home renno store like Home Dept, Lowes etc. I combined 2×4’s to make 4×4’s with basic shelf underneath and supports. For the top, I just went with MDF. I’m attaching the top this weekend and have questions concerning this… 1. What would I seal the MDF with? I’m not sure about sealing/finishing at all so specific info is appreciated. 2. Some sites recommended edging the MDF to prevent chipping, etc. How do you edge MDF? I’m not even sure what wood I would use, how I would cut it, etc. etc. Any input is appreciated… I am learning as I go so sorry if some of the questions are really dumb. :) Thx, |
190 days ago |
Hey Robin -- Jim from Heirloom Woodshop Southern Oregon |
190 days ago |
Robin….....First of all welcome to LJ’s. There are no supid questions. Sealing MDF is an easy process. Multiple coats of shellac. As for the edging I used poplar on mine, but any wood will work. I used poplar because thats what I had on hand. You will notice that some of the guys will use oak, walnut or another hardwood. Attaching the edging can be done numerous ways. The problem with MDF is that it doesnt hold screws well especially in the edge. If you use screws predrill the edging and the MDF, remove the edging and countersink the MDF slightly. The countersink will give the screw enough room as it pulls the MDF material out of the hole as you drive the screw. I would also apply a good healthy bead of yellow glue to the MDF and the edging as you attach it. Make sure to spread the glue evenly. You will notice the MDF will absorb the glue quickly, it is very pourous on the edges. If you dont wanna go with the screws you can also use finishing nails, I used 18ga 2” nails on the edging on my bench and it has held well. I would apply the edging before you finish the top and apply shellac to the top and edging as well. Good luck!! -- My job is to give my kids things to discuss with their therapist....medic20447@gmail.com |
190 days ago |
I heve never tried this on MDF, but Tung Oil is an excellent sealer and finish wich hardens very well…...why about trying on a small piece? it takes a week to dry. -- Francisco Luna, San Francisco Bay Area. |
190 days ago |
Are you planning on painting it to lighten it up as MDF is awful dark. I know some like it that way. If you are going to paint it to lighten it up. Use glue sizing, basically watered down yellow glue. Like 6-8 parts water to glue brush it on let dry (it will look pasty white when dry) lightly sand (220-400 Grit) to smooth then repeat one more time sand smooth again (be careful not to sand through) and then paint. As for trim choose what you want to use cut it then same width as the top is thick and glue and nail (I used brads) to the MDF, as noted above, MDF is thirsty an even more so on the edges, so make sure you heavily glue size the edges have don’t worry so much about sanding it. Down the road when you have completed finishing a project with a oil, take the rag/brush and work out the excess on the trim. Take a look at my Miter Bench ….. I used Maple as that is the trim I have used on all of my benches. -- //FC - Round Rock, TX - "Experience is what you get just after you need it" |
190 days ago |
Countersink screws into the MDF and attach to your framework .Plan on replacing the top every -so often and don’t worry about it ! Finish the MDF with any cheap acrylic or solvent born sealer , then paste wax .Beat the heck out of it , sand it , wax it , then replace the whole thing when you are tired of looking at it - |
190 days ago |
Another way to prevent chips would be to route your edges with a round over bit. |
190 days ago |
Robin, I used MDF on my bench recently. Considering the cost and ease of construction and just starting out I am very pleased. I finished mine with 3 coats of Minwax Polycrylic and then paste wax. It a little slick, but, nice to keep glue off. I use a rubber mesh pad or bench hooks when sanding, routing or planing. Anyhow works for me and makes a nice little bench for my small shop. -- Duane, Iowa |
189 days ago |
I have my MDF bench top mounted on top of 1-1/8 sub floor plywood with screws (slightly recessed) and that combination makes for a solid bench top. It has no edge protection and I have no problem with chipping although Dennis’s idea of rounding the edges sounds good. -- Les B, Oregon |
189 days ago |
I don’t finish at all, when it gets damaged I just turn it over and have a clean place to work. Then when that wears out, resaw it for other projects and put another piece on. -- Life is to short to own an ugly boat. |
189 days ago |
All good tips! Thanks everyone! I’m 6’2” and the bench is < 3’ high, < 2 1/2’ deep and only 54” long (not counting top size) so I am already planning up my 2nd bench :). Given the chances that it will be come a storage platform… I think I am going to go with the routed edges and basic finishing on top. The key advice above is why I went with MDF… for the $$$ of it… don’t care if once a year I have to replace the top :). Cheers, |
189 days ago |
For my last bench I did this: 1) Two layers 3/4 MDF. Lots of 1-1/4 screws acting as clamps to hold the pieces together as the glue set. See the video over at FineWoodworking on getting started and building a bench for ideas. 2) Cut up some poplar to make edging for the top. To keep it aligned while the glue set (and lots of glue, the edge of the MDF will just drink it in) I pre-drilled for small 1-1/2 finish nails every foot or so and used them to pin the edge. Clamps and scrap the squeeze-out after an hour. 3) Sealed the MDF with lots and lots of inexpensive sanding sealer. Happens to be a store up the road from me that buys old and shipping damaged stock then just puts it out on the shelf for pennies on the dollar. Can’t remember the brand but it was “in date” just dented. Got a couple quart cans and a cheap brush and went to town. Sanded down with 100 and 150 between. I think 2 coats for the bottom side and 4 for the top with a liberal application on the edging too. 4) 220 for last sanding then waxed the top with Johnson’s Paste wax. Glue, etc pretty much just pops off. After a year, it is about time to sand and re-seal just to clean it up. A few dings but then it is a workbench after all! -- Don't sweat the petty things and don't pet the sweaty things. |
189 days ago |
Myself, I don’t worry about sealing and edging – the top is disposable. The top of my bench is 3/4” MDF, and when it gets badly bunged up I’ll cut out whatever portion I think can be recycled and toss the rest. -- Derek, Bremerton WA -- |
189 days ago |
I wouldnt worry about finishing it , nor edging it… just use it as is, less work for you.. and when it’s beat up to the point it won’t take it any more – just replace the top. my guess is – you won’t be replacing that top anytime soon… so like I said – nothing really to worry about, or lose sleep over. you’ll probably get better ideas and built a better bench way before that top will become obsolete. -- When in doubt - There is no doubt - Go the safer route. |
187 days ago |
Robin, |
186 days ago |
Hey Kimball, please describe what a torsion box is or does. I’ve never heard of it. Robin, Don’t know too much about MDF but I used it in a small garage workbench over a year ago and it’s pretty much like the day I put it in. My Woodshop bench top is a solid core door I got from salvage because it was damaged and unuseable as an office door. Good Luck and welcome to LumberJocks!!! -- There are three signs of old age. The first is loss of memory. I forgot the other two! |
186 days ago |
I just keep adding more Johnsons paste wax! Maple edge! http://lumberjocks.com/projects/14133 -- spanky46 -- Never enough clamps...Never enough tools...Never enough time. |
186 days ago |
Hi Thelt, |
186 days ago |
heres a video on torsion box’s by non other then our very own wood whiperer torsion box’s are extreamly ridgid and heavy duty. mater of fact i read in fine working onceabout a guy who builds these as a sort of floating shelf in the artical he joked that if you wanted to sell the self youd have to buy the house it was attched to. http://thewoodwhisperer.com/episode-18-assembly-table-torsion-box/ ps by far one of the bes ways other then solid wood to build a bench top -- I buy tools so i can make more money,so ican buy more tools so I can work more, to make more money, so I can buy more tool, so I can work more |
186 days ago |
I used two sheets of mdf for the top, the top one floating to it can be flipped over when it gets damaged. I faced the edges with doug fir that i ripped from 2/4s. and then rounded over the frame with a router. -- Life is to short to own an ugly boat. |
| Forum | Topics |
Woodworking Skill Share
2917 |
3944 |
256 |
949 |
224 |
Woodworking Trade & Swap
619 |
Coffee Lounge
2390 |
LumberJocks.com Site Feedback
524 |
