Seeking Advice on what type of wood to use....
Forum topic by Joe Bush posted 05-19-2009 09:09 PM 1017 views 0 times favorited 8 replies Add to Favorites Watch
View Joe Bush's profile
Joe Bush
4 posts in 3419 days
05-19-2009 09:09 PM
I am planning on making some Adirondack chairs which I intend to paint. Does anyone have any recommendations on what species of wood to use. Do I need to use treated pine or something else. Any advice is appreciated.
Thanks,
Joe
-- Joe B, NC
8 replies so far
View PurpLev's profile
PurpLev
8534 posts in 3557 days
#1 posted 05-19-2009 09:19 PM
I think redwood and cedar are the commonly used – they dont require finish and protection from the elements and will age to a nice grey color
I would recommend avoiding any treated lumber for anything that comes in contact with human skin, or vegetables and other things that will cycle into/onto the living.
View Milo's profile
Milo
869 posts in 3228 days
#2 posted 05-19-2009 09:34 PM
If you can get your hands on it, Bald cypress would be a good wood to use on outdoor furniture. As PurpLev said though, redwood is also a good choice.
-- Beer, Beer, Thank God for Beer. It's my way of keeping my mind fresh and clear...
116912 posts in 3486 days
#3 posted 05-19-2009 09:44 PM
Purp and Milo have the best choices
Joe Bush
#4 posted 05-19-2009 09:47 PM
Thanks for you responses. Should I use those species even though I am going to paint them?
-- Joe B, NC
16272 posts in 4127 days
#5 posted 05-19-2009 09:58 PM
A good weather-resistant species will hold up better over the long haul in all likeliehood, but I’d say you would be okay using treated pine if you wanted to save a few bucks.
View lew's profile (online now)
lew
11946 posts in 3664 days
#6 posted 05-19-2009 11:33 PM
Another factor to consider is the location where they will be used. Will they be completely exposed to the elements or partially protected?
I made 2 out of white pine (Borg Lumber) painted them and placed them on the front porch- it has a roof but no other sheltering parts. They have been there for 15 years and still in great shape.
View LesB's profile
LesB
1562 posts in 3351 days
#7 posted 05-20-2009 12:52 AM
If you are going to paint them I think almost any sound wood will work. Just not oily ones. Exposure to the elements has a lot to do with the durability of both the wood and the paint. Make certain the wood is really dry before you apply paint or you will have blistering of the paint from trapped moisture. After painting I would put some sort of rubber or plastic footings on the bottom of the legs to keep moisture from wicking up from the soil or deck.
In North Carolina Redwood will be quite expensive but cedar may be reasonable. Some cedars can be oily so check them out. Douglas fir would be great but again it is a west coast wood that is probably expensive there.
-- Les B, Oregon
View CaptainSkully's profile
CaptainSkully
1566 posts in 3467 days
#8 posted 05-29-2009 02:56 AM
I would also recommend priming the wood very well before the finish coat(s). Make sure you use exterior grade paint, whether it’s latex or otherwise. Also, boating stores have an excellent array of weatherproof finishes that allow the wood to show through.
-- You can't control the wind, but you can trim your sails
