Seeking input/advice
Forum topic by Randy Sharp posted 05-19-2009 06:56 PM 1107 views 0 times favorited 10 replies Add to Favorites Watch
View Randy Sharp's profile
Randy Sharp
363 posts in 3575 days
05-19-2009 06:56 PM
Topic tags/keywords: tip joining
Looking at the photo below, how would you secure the disc to the base plate?
- I’ve tried pre-drilling and using a large wood screw, but the disc tends to still rotate on the base.
- The best luck I’ve had is using a 3/8” dowel rod as a connector. It seems to work, but still leaves the disc open for snapping off, though not likely.
“Grooving” the base or jointing the bottom of the disc is not an option I would prefer, so I’m hoping my experienced LJ’s will come up with other suggestions.
Thanks!
Disc Golf trophy
-- Randy, Tupelo, MS ~ A man who honors his wife will have children who honor their father.
10 replies so far
16272 posts in 4121 days
#1 posted 05-19-2009 07:10 PM
If you are really worried about it snapping off, instead of a wooden dowel use a steel rod . And instead of wood glue, use epoxy.
View GaryK's profile
GaryK
10262 posts in 3891 days
#2 posted 05-19-2009 07:11 PM
Charlie has it!
View Francisco Luna's profile
Francisco Luna
943 posts in 3296 days
#3 posted 05-19-2009 07:32 PM
but the metal rod can still be weak by itself, so it must be welded to a steel plate that goes recessed underneath the base.
-- Nature is my manifestation of God. I go to nature every day for inspiration in the day's work. I follow in building the principles which nature has used in its domain" Frank Lloyd Wright
View PurpLev's profile
PurpLev
8534 posts in 3551 days
#4 posted 05-19-2009 07:41 PM
how about a floating tenon? since it’s elongated it will also prevent the disc from spinning.
View Toolz's profile
Toolz
1004 posts in 3645 days
#5 posted 05-19-2009 07:53 PM
A 1/4” or 3/8” threaded steel rod (depending on the thickness of your disc) would work and like Charlie said, use epoxy.
-- Larry "Work like a Captain but Play like a Pirate!"
Randy Sharp
#6 posted 05-19-2009 08:07 PM
Lots of great advice. Thanks!
Now…if 20 of you will re-create the trophy above and send it to me, with your advised connection, I’ll get a better idea of what you’re talking about. Oh, did I mention I’ve got to make 20 of these?
View mtnwild's profile
mtnwild
3474 posts in 3430 days
#7 posted 05-19-2009 08:16 PM
Drill a hole in the dowel and epoxy a nail in there and then use. Maybe two small dowels close together then it can’t spin. Good luck.
View Kindlingmaker's profile
Kindlingmaker
2656 posts in 3429 days
#8 posted 05-19-2009 08:41 PM
CharlieM1958 has it and for the steel rod use a long 1/4” or 5/16” or the largest size you can carriage bolt counter sunk into the bottom. The threads on the bolt will also help in hold strength and carrage bolts come in just about every length you might want, pre-made.
116900 posts in 3480 days
#9 posted 05-19-2009 08:51 PM
I think I would try a sliding dove tail on the disc being the male and the base the groove then epoxy it in place.
View abuck's profile
abuck
12 posts in 3233 days
#10 posted 05-19-2009 09:18 PM
My idea is would be (I dont know the technical name for it) a threaded rod that has bolt type threads on one end and a screw on the other. secure the bolt end through the base with a nut and screw the disc down on the screw end.
