| Forum topic by Toddmc | posted 191 days ago | 393 views | 0 times favorited | 16 replies | ![]() |
191 days ago |
I am making drawers for a pair of night stands I just built and my next project is a 9 drawer dresser. I currently have a craftsman 12” dovetail jig. I know craftsmen is terrible quality especially in this jig but it was given to me for free from a friend so the price was unbeatable. I was wondering if anyone else has this jig. The instruction manual says it should be 17/32 from the router base. This height is unachievable because when I adjust the bit height it comes in contact with the guide collar. My idea was to grind away on the dovetail bit until I can lower the bit into the collar to the proper depth. I wanted to know what others have done to solve this problem and if grinding/modifying a router bit is a good idea. I read the reviews on the sears website and many others have the same problem but it does not say how they solved it (most just returned the jig). The bit that the manual calls for is obsolete so it is no longer sold and sears said that any ole router bit should work (which is obviously not true). Maybe I should be using a dovetail bit with a different angle, perhaps an 8 degree bit? |
191 days ago |
I’m not sure if this will work, but could the bit be seated less deeply into the collet. You might be able to gain about 1/4”. Or, you could shorten the guide collar, slightly, by cutting it with a hack saw. I would not grind anything off of the bit. It might weaken the carbide connection or make the bit out of balance. |
191 days ago |
These jigs are very difficult to get set up . If possible replace it or even make another Jig I believe I saw a home made one a LJer had made. http://lumberjocks.com/projects/16652 -- Jim from Heirloom Woodshop Southern Oregon |
191 days ago |
You don’t mention what “it” is? Could you link your request to a website showing the jig? Bob -- A mind, like a home, is furnished by its owner |
191 days ago |
here is the jig I am talking about. http://www.sears.com/shc/s/p_10153_12605_00902579000P?keyword=dovetail the 17/32” is the “recommended height of the bit in referance to the base. The main problem is that if I lower the bit it cuts into the guide collar. I do not see any way to make the jig work besides grinding on the dovetail bit to make it seat further into the collor (that way the bit will not cut into the collar). |
191 days ago |
If you are referring to the comb as the guide bar I can see two wing nuts to adjust the height of this part. You may want to get a Dovetail saw and a couple of chisels if you want to learn how it’s done and do it more quickly. ( search dovetails here and you shouldget lots of hits) Bob -- A mind, like a home, is furnished by its owner |
191 days ago |
I can not find the reference, however i believe that you can downlosd manuals from sears parts. There is also a place that has all kinds of manuals. Do a search on Yahoo for Craftsman parts manuals -- Saved, and so grateful, consider who Created it ALL!!! |
191 days ago |
I had the same problem on my jig, I just ground down the guide bushing to about 1/16” height. Works fine for what it is I guess, but I really am not a big fan of the jig. Too finicky and hard to set up for anything but a LOT of drawers. Usually saw and chisel time when dovetails are called for, plus it adds a bit of character if your dovetails are spaced in interesting ways (not all exactly the same). -- Ooo, er. |
191 days ago |
Save yourself a lot of hassle and grief. Scrap the Craftsman; I did a long time ago. Look into the Porter Cable jig or if you have a bunch of extra cash laying around and want a great jig get the 24” Leigh. It does every thing but super thin dovetails. The learning curve is a bit steep but worth it to do great machine cut dovetails. -- Les B, Oregon |
191 days ago |
Les B is on the right track. I didn’t mention my Leigh 24” jig because I figured youwer not into that kind of investment. Bob -- A mind, like a home, is furnished by its owner |
190 days ago |
I tried to get the jig to work again last night but I gave up after an hour or two. I like to spend my time in the woodshop working with wood not setting up tools. I plan on doing 11 drawers and figure that by the time I get this thing working I could have cut them all by hand. I will try and grind down the collar when I finish the dresser as a “one last try”. If that dies not work I will probably toss it into the trash. If I had actually paid money for that jig I would be upset over it. The hand cut dovetails sound good to me. I have a set of chisels but despretly need some sharpening stones. If anyone is selling some at a good price let me know. |
190 days ago |
Search on this site for Scary Sharp and you will see a low cost method of sharpening that will fit your budget and give a great edge. -- A mind, like a home, is furnished by its owner |
190 days ago |
I bought a Porter Cable 4212 dovetail jig (also got a 4215 miniature dovetail/bo joint template a few weeks ago. My first attempt at making box joints with it went great. I was able to fine tune the adjustments to make perfect joints in 2 tries. For me, that is a major accomplishment. The instruction manual was ok, but there is a supplemental manual that can be downloaded that is really good. There are also some great posts and links on this site that helped a lot. -- Joe |
190 days ago |
Grind, sand or file down your guide bushing collar. They can be purchased in various sizes (depths). I purchased a PC set several years ago and they have a 1/4” and a 1/8” tall collar for each size. Also make sure that you have the correct diameter collar for the specific bit that you are using. -- NorthWoodsMan |
190 days ago |
I had this same jig -it’s somewhere in the cellar…Bought a 24” PC which is very good, and now I cut them by hand. I enjoy it more. I enjoy not having high pitched noises blocking out my Supertramp or The Doors…The Craftsman jig is why I save and save and save to get something worth using. -- Elaine, Conover, NC |
190 days ago |
It is a sad state for the craftsman line of tools when a jig that costs a little over a hundred dollars does not even work. |
190 days ago |
I personally make a habit of never buying my tools from stores that sell ladies undergarments. <g> Your mileage may vary. Bob -- A mind, like a home, is furnished by its owner |
| Forum | Topics |
Woodworking Skill Share
2917 |
3944 |
256 |
950 |
224 |
Woodworking Trade & Swap
619 |
Coffee Lounge
2390 |
LumberJocks.com Site Feedback
524 |
