Forum topic by mcg1990 | posted 02-26-2015 02:11 AM | 775 views | 0 times favorited | 6 replies | ![]() |
A while back I made a post regarding rattling/grindy noises coming from my Craftsman 22124. I’ve been too busy to attempt all of the tuning suggestions that were put forward, but I have noticed something new – the zero clearance insert sags into/around the blade. I wonder if anyone could quickly educate me on any problems this may cause, and where to look for a new one? Another problem I have is that the gap between the blade and the insert is so large that often when I’m ripping small strips off of stock (say, taking 1/8 off either side off construction lumber to remove the bevel) the slithers will slip down beside the blade and try its best to cause a jam. Something to consider: I’m wanting to update the saw to a thin kerf BORK and appropriate blade, is now a good time to do so if I’m going for a new ZCI? Thanks |
