Drill Press Identification
Forum topic by Levaughn posted 02-25-2015 08:09 PM 1199 views 0 times favorited 9 replies Add to Favorites Watch
View Levaughn's profile
Levaughn
2 posts in 1180 days
02-25-2015 08:09 PM
Hello all. I would like some help if possible in identifying a Drill Press I acquired some years ago. It appears the pulleys which are Craftsmen and the motor were add ons. My main concern is help with identifying the cast iron body. I looked it over and found no manufacturer markings. I’m not familiar with Drill Presses, but from internet searches it appears quite old and primitive. I would like to know if anyone is familiar with this model and can identify it. I looked at pictures on the internet and came up empty. It runs quite well, I’m fond of it and may need parts for it in the future to keep it that way. Any help would be deeply appreciated. Thanks in advance.
9 replies so far
View bobkberg's profile
bobkberg
439 posts in 3066 days
#1 posted 03-08-2015 06:36 PM
Hi Levaughn,
The primary parts you might need are likely to be bearings. I restored an early 1950’s Craftsman drill press some years ago (ok, almost 30), and found that all the bearings were still available at a local bearing specialty shop.
The counterman looked at the old ones I’d brought in, walked over to the shelf and pulled off the replacements.
-- Bob www.singularengineering.com - A sideline, not how I earn a living
View Woodknack's profile
Woodknack
11600 posts in 2373 days
#2 posted 03-09-2015 06:20 AM
It’s vaguely reminiscent of early 20th century drill presses but doesn’t look that old to me. It doesn’t look to be very old at all. There isn’t anything on it that I can nail down and the base doesn’t seem to match the rest. If there are no markings my guess it’s a foreign made light duty, economy, drill press. Pretty much all bearings used in the last 50-60 years are off the shelf parts especially in less expensive machines. All you need is to measure the inside and outside diameters for the bearings and shop around. Those measurements could be in inches, metric, or a mix of both (why anyone would ever mix metric and inches I don’t know, but they did).
View ChefHDAN's profile
ChefHDAN
1062 posts in 2842 days
#3 posted 03-09-2015 11:25 AM
I’m thinking its a Frankenstien from just enough parts to get the job done
View alittleoff's profile
alittleoff
539 posts in 1269 days
#4 posted 03-10-2015 03:56 AM
Looks like a knock off of an early delta. The motor would be mounted to the base, which was turned backwards. A set of pulleys was mounted where the motor is on your press, and used a long belt to drive it. If it were a delta it would be clearly marked I would think. It does resemble one though.
Gerald.
View MrUnix's profile
MrUnix
6695 posts in 2192 days
#5 posted 03-10-2015 04:52 AM
Very similar to this old Atlas benchtop with just a few minor differences:
Try browsing the photo index over at vintagemachinery.org to see if you can match it up.
View ElChe's profile
ElChe
630 posts in 1329 days
#6 posted 03-10-2015 04:54 AM
+1 on it being a Frankendrill. Cool looking.
Maybe this?
http://vintagemachinery.org/photoindex/detail.aspx?id=16253
Levaughn
#7 posted 03-11-2015 07:42 AM
Thanks for all the replies. It’s a great step in the right direction :)
Woodknack
#8 posted 03-17-2015 08:07 PM
I wonder if this is a pillar tool that’s been converted to a drill press, or a hybrid.
View daddywoofdawg's profile
daddywoofdawg
1028 posts in 1568 days
#9 posted 03-18-2015 02:01 AM
early shopsmith?
