Wandering Band Saw
Forum topic by Bryan posted 466 days ago 276 views 1 time favorited 5 replies Add to Favorites
View Bryan's profile
Bryan
3 posts in 532 days
466 days ago
I know its cheap but can someone tell me how to cut a straight line with my Ryobi benchtop band saw? I’ve adjusted everything that I can find but it still wanders to the right.
-- Bryan
View dbriski's profile
dbriski
22 posts in 584 days
466 days ago
Nearly all bandsaws “drift.” Its a function of the blade. you need to set your fence (if your using one) to match that drift. Get a piece of scrap with true edges. Draw a line down the middle of the length that is parallel to the left side. Freehand cut straight along the line about 1/2 though the board. Hold at that angle (clamp to table without moving) now set your fence (if adjustable) to align with that angle. This sets the fence to the drift of the blade so you can make a stright cut. You have to do this every time you change blades.
-- David, www.briskibusiness.com
View Mike Lingenfelter's profile
Mike Lingenfelter
403 posts in 642 days
466 days ago
I do something similar. This technique comes by way of David Marks on Wood Works. Freehand the cut for a inches then set a bevel gauge to the angle. Go a few more inches and check it again. Do this a few times to make sure you have the angle right. Then use the bevel gauge to set your fence. Just one more way of doing the same thing.
-- http://theinquisitivewoodworker.com/
View frank's profile
frank
1420 posts in 734 days
466 days ago
Hello Bryon;
—-well let me introduce you to an-other here….Don who has written an extremely well done article on Bandsaw Drift and Tuning ....
Also thought that I would add if I may, no tool is cheap and we all start somewhere. I at one time did joinery with an old miter saw I found in an abandoned cabin, have made furniture at the kitchen table, learned to do mortise’s with a screwdriver and old broken files that I ground to different shapes, have had shops and tools and lost shops and tools, but I all-ways had a pocketknife to cut, carve and gouge some wood….which in the end has all-ways kept the woodworking spirit going in me. If I lost all my tools tonight, I would still arise in the morning giving thanks for one tool that no-one can take away….and this one tool is free to any, but will cost you every-thing….my imagination!
Thank you and….
GODSPEED,
Frank
-- --frank, NH, http://frank.wordpress.com/
View Hawgnutz's profile
Hawgnutz
505 posts in 604 days
466 days ago
That Ryobi bandsaw is adequate to use on most smaller projects, for sure. Drift is an integral part of using any bandsaw. I would reccomend the book by Cutting Edge publishers on the Bandsw, but almost any book will help you learn about cutting along with some jigs and tips, too.
Amazon used to sell it, but I cannot find it there, now. Check at Rockler or Woodcraft. They usually have a good selection.
God Bless,
Hawg
-- Saving barnwood from the scrapyards
Bryan
3 posts in 532 days
465 days ago
Thanks Guys!! I’ll give your tips a try and let you know if you can pick up a band saw in my trash or not.
-- Bryan
Bookmark And Share This Page
