| Forum topic by Jack Barnhill | posted 193 days ago | 320 views | 0 times favorited | 12 replies | ![]() |
193 days ago |
Topic tags/keywords: sketchup help drawer pull I have already made this drawer pull for my drill press cabinet and now I want to create an SU model of it for future reference. The pull is curved along its length, width and thickness of the top portion of the pull. I have tried for 3 days now to figure out how to do this curved top in SU with no luck. Any, and all, help would be greatly appreciated. The ortho view of the pull is shown below.
Thanks, -- Best regards, Jack, www.PixelsandSawdust.com |
193 days ago |
Hey Jack -- Jim from Heirloom Woodshop, custom furniture maker, woodworking school, heirloomwoodshop.com |
193 days ago |
Jack, send me the SKP of what you posted. I’ll see what I can do to show you how. -- Until you spread your wings, you'll have no idea how far you can walk. |
192 days ago |
192 days ago |
Great job, Dave. They both look great. I like the second better. I can’t put my finger on it but it somehow looks cleaner. What methods did you use? I need to learn how to fish. Jack -- Best regards, Jack, www.PixelsandSawdust.com |
191 days ago |
Jack, I’ll do something up to show how it’s done. -- Until you spread your wings, you'll have no idea how far you can walk. |
191 days ago |
Dave – After several more hours, I finally was able to create the pulls and completed the BTDP cabinet model. The method I used was very time consuming and there are a couple of small artifacts in the pulls. If you have the time, I would still be interested in your method. I’m sure it would be quicker and cleaner. Thanks again for your help. -- Best regards, Jack, www.PixelsandSawdust.com |
190 days ago |
Jack, take a look at this link. Let me know if that makes it easier. -- Until you spread your wings, you'll have no idea how far you can walk. |
190 days ago |
Thanks, Dave. That is similar to what I ended up doing but your use of the guide lines made the model cleaner. I used end points and not everything lined up correctly so it created a lot more work cleaning things up. A couple more general questions. How do you adjust the number of segments in an arc? I thought I saw it one time and now I can’t find it again. What do you consider the best source of SU self-training? Thanks, -- Best regards, Jack, www.PixelsandSawdust.com |
190 days ago |
Jack, Did you use the Skin plugin? You can change the number of segments for an arc or a circle by selecting the tool and immediately enter the desired number followed by the letter s and Enter. The best source of self-training is probably just practice. Learn the basics very well and work to make your drawing efficient. Try to draw anything and everything. I’ve not really seen many good resources for anything beyond the basics. I think it is very difficult to make a resource that can answer every need. The best thing is probably to look at what folks who use the program frequently are doing. -- Until you spread your wings, you'll have no idea how far you can walk. |
190 days ago |
That’s where I saw it at. I won’t forget it again. No, I didn’t use the Skin plugin. I played with it a little bit but, couldn’t get it to do what I wanted. More practice needed there too. Jack -- Best regards, Jack, www.PixelsandSawdust.com |
190 days ago |
The skinning can be done manually but it requires you to draw in all of those little triangles. The plugin is much faster. -- Until you spread your wings, you'll have no idea how far you can walk. |
190 days ago |
Yep. That’s why it took me so long to draw. I redraw the pull using your method and see if I can get rid of the small errors in mine. -- Best regards, Jack, www.PixelsandSawdust.com |
| Forum | Topics |
Woodworking Skill Share
2924 |
3954 |
257 |
952 |
225 |
Woodworking Trade & Swap
621 |
Coffee Lounge
2396 |
LumberJocks.com Site Feedback
524 |
