Modify surface of wet grinding wheel
« back to Hand Tools forum
Forum topic by Ray posted 02-25-2015 03:50 PM 999 views 0 times favorited 8 replies Add to Favorites Watch
View Ray's profile
Ray
126 posts in 1971 days
02-25-2015 03:50 PM
Is it possible to dress a wheel in a way that will yield different grits?
Thanks
-- Creating less fire wood every day
8 replies so far
View JesseTutt's profile
JesseTutt
854 posts in 2078 days
#1 posted 02-25-2015 03:59 PM
Tormek sells a stone grader for their wet grinder. Here is a link one company selling them.
I have wondered if it would work with my Grizzly version of the Tormek
View OhioMike's profile
OhioMike
79 posts in 2130 days
#2 posted 02-25-2015 04:11 PM
You don’t say what machine you have but I own both the Grizzly (made by Sheppach) and the Tormek. Both respond to the stone grader that Jesse linked to.
The stone on either the Grizzly or the Tormek can be as coarse as 250 grit or as smooth as 1000 grit.
I have found that if I don’t use the stone grader, the stone naturally becomes smoother with use – more like a 1000 grit stone – and that’s how I like it. I only regrade the stone to 250 if I have to grind a very badly damaged tool.
View waho6o9's profile
waho6o9
8167 posts in 2544 days
#3 posted 02-25-2015 04:12 PM
View Ray's profile
Ray
#4 posted 02-25-2015 04:26 PM
“You don’t say what machine you have…”
I have the 8” Central Machinery wet grinder. It was given to me. I think it came from Harbor Freight. It looks very similar to the Grizzly.
View Derek Cohen's profile
Derek Cohen
369 posts in 3936 days
#5 posted 02-27-2015 12:22 PM
Why bother?
The result of the finest re-grading is never going to be fine enough for a bench chisel or plane blade. You still need to hone the edge on waterstones, etc.
Stick to the coarsest grade, keep the surface clean … treat the Tormek as a grinder.
Regards from Perth
Derek
-- Buildiing furniture, and reviewing and building tools at http://www.inthewoodshop.com
View unbob's profile
unbob
808 posts in 1871 days
#6 posted 02-27-2015 04:01 PM
Using industrial cutter grinding machines, the way a wheel is dressed will determine how it cuts. For example, if a sharp diamond point is moved rapidly across the wheel, the grit will open up and be more free cutting. Moving the diamond slowly across the wheel, the grains close up some, the finish will be finer. Using an abrasive dressing stick the grains in the wheel can be closed up further resulting in a bit finer surface finish, but slower cutting.
A useful method, as its not easy to change wheels.
View Ray's profile
Ray
#7 posted 02-27-2015 09:36 PM
Why bother?
Regards from Perth
Derek
- Derek Cohen
Thanks-
I came to the same conclusion yesterday based on the replies that I have received.
View DrDirt's profile
DrDirt
4423 posts in 3710 days
#8 posted 02-27-2015 09:58 PM
To answer your question…. NO
Regardless how you dress the stone… you cannot change a 80 grit stone to a 120 grit stone, using a stone dresser. The grit was chosen at the factory, and is friable (so it breaks away from the stone) exposing more 80 grit material as it wears.
cant change the grit with a diamond dresser.
