Router or tenon drill press set up
Forum topic by Garbanzolasvegas posted 02-25-2015 01:35 AM 917 views 0 times favorited 11 replies Add to Favorites Watch
View Garbanzolasvegas's profile
Garbanzolasvegas
356 posts in 1191 days
02-25-2015 01:35 AM
I am planning my first quality hardwood project. I want to make it with traditional joinery such as mortise and tenons.
I had planned on using a router to make the Mortises, and round off the tenons. After reading a lot on this seems more people, if they have the resources, lean more towards a Square Mortises machines.
To get a Mortise machine that goes up to 3/4 square holes is over $300.
Also a question. If you have a Mortise machine that goes up to a max of 1/2 wide mortise, can one make it 3/4 by say using 2 holes using a 3/8s drills.
I find that hard to believe since I would think that the bit would wonder into the first hole…
-- If you don't Play, you can't win
11 replies so far
117062 posts in 3541 days
#1 posted 02-25-2015 01:47 AM
this might help.
https://www.youtube.com/watch?v=W4HbLCGRphc
View ,'s profile
2387 posts in 3511 days
#2 posted 02-25-2015 03:32 AM
I think I would go with a router jig set up. Clamp your work piece horizontally, use a template and guide bushing with plunge router and cut mortise. I would go with loose tenons rounded.
View timbertailor's profile
timbertailor
1594 posts in 1388 days
#3 posted 02-25-2015 03:39 AM
It just depends on the level of perfection you need.
If you want clean, square holes, make the investment in a proper mortiser. One with an X Y vise\table is worth the extra effort\investment IMO.
But, I do custom cabinetry where clients demand that no nails or screws are used with solid hardwoods.
runswithscissors
2724 posts in 1989 days
#4 posted 02-25-2015 04:31 AM
Yes, you should have no problem doing a double row of cuts with a mortiser. The chisels are very stiff and rigid and shouldn’t flex unduly. I often cut a mortise where the last cut uses only half the chisel width, and I have never noticed any flexing.
I know there are people who disagree with this. I can only report on my own experience.
If you are considering a drill press mortiser, you may be disappointed. Most people despise those, and come away convinced that machine cut mortises aren’t worth the bother.
Garbanzolasvegas
#5 posted 02-25-2015 01:41 PM
If you want clean, square holes, make the investment in a proper mortiser. One with an X Y vise able is worth the extra effortinvestment IMO.
- timbertailor
Great set up there
View waho6o9's profile
waho6o9
8164 posts in 2541 days
#6 posted 02-25-2015 02:29 PM
Have one of your girlfriends get you a Domino.
Yeppers
Garbanzolasvegas
#7 posted 02-26-2015 12:48 AM
Yeppers
- waho6o9
Well they aren’t real happy with me since Valentines day
View verdesardog's profile
verdesardog
158 posts in 2576 days
#8 posted 02-26-2015 01:22 AM
I have used a drill press mortise for years with no ill effects. It is a pain in the a$$ but it works for the very few mortises I make.
-- .. heyoka ..
View AandCstyle's profile
AandCstyle
3027 posts in 2221 days
#9 posted 02-26-2015 01:40 AM
I use a plunge router and templates. IMO, it is much faster and cleaner than the bench top mortisers.
-- Art
Garbanzolasvegas
#10 posted 02-26-2015 02:18 AM
Why do the router mortise JIG/templates cost way more than my router or a Mortise drill???
Garbanzolasvegas
#11 posted 02-26-2015 02:23 AM
Mortisepal is out of business
