Walnut turned white.
Forum topic by scvwood27 posted 02-24-2015 11:57 PM 1014 views 0 times favorited 12 replies Add to Favorites Watch
View scvwood27's profile
scvwood27
117 posts in 1977 days
02-24-2015 11:57 PM
Made a frame from walnut. Sanded it, cleaned it with mineral spirits, let it dry and finished it with spray satin lacquer. Why ?
12 replies so far
View johnstoneb's profile
johnstoneb
2939 posts in 2198 days
#1 posted 02-25-2015 12:05 AM
It looks like some kind of contamination didn’t let the lacquer adhere in places. Sand it again and blow or wipe the dust off without the mineral spirits.
-- Bruce, Boise, ID
View JoeinGa's profile
JoeinGa
7736 posts in 2033 days
#2 posted 02-25-2015 12:14 AM
Was it “old” walnut that had been painted before?
scvwood27
#3 posted 02-25-2015 12:22 AM
No. New walnut.
JoeinGa
#4 posted 02-25-2015 12:26 AM
Well there goes MY idea… sorry.
View jumbojack's profile
jumbojack
1677 posts in 2650 days
#5 posted 02-25-2015 12:27 AM
Sand it down again, sorry. Wipe it down with lacquer thinner really well. Let the thinner flash off for an hour. The hit her again with lacquer. Dont let it out in the sun. 55 degrees or better. If your lacquer and frame are at or above 60 degrees you lessen the chance of trouble. You should be golden.
scvwood27
#6 posted 02-25-2015 12:32 AM
Ok jumbo. Temp isn’t a problem, it 75 degrees in Southern California.
View Dark_Lightning's profile
Dark_Lightning
3165 posts in 3135 days
#7 posted 02-25-2015 03:21 AM
Looks like maybe blushing from humidity. Was it raining recently, where you are? I live in SoCal, and it rained here on Sunday and Monday, and a couple of days last week.
Possibly, the mineral spirits hadn’t evaporated, as well. That takes longer when it is humid.
-- Random Orbital Nailer
jumbojack
#8 posted 02-25-2015 04:03 AM
Probably the mineral spirits.
View Deycart's profile
Deycart
444 posts in 2283 days
#9 posted 02-25-2015 05:22 AM
Looks like the wood was not dry enough to me. What was the source?
View MrsN's profile
MrsN
986 posts in 3552 days
#10 posted 02-25-2015 02:38 PM
I have had lacquer do that when the humidity was too high. You can sometimes fix it by using a hair-dryer to dry out the finish.
otherwise sand down and try again in a slightly dryer environment.
scvwood27
#11 posted 02-25-2015 05:57 PM
It was raining the day I applied the finish.
jumbojack
#12 posted 02-26-2015 04:37 PM
Normally when it is atmosphere that clouds or ’ blushes’ lacquer it is just that, a foggy area. The lacquer in this case has separated from your material. I still suspect it is a contaminate (mineral spirit) that caused you malady.
