I got a question about Delta 22-580 13'' Thickness Planer!
Forum topic by Beginningwoodworker posted 05-16-2009 05:37 PM 1324 views 0 times favorited 7 replies Add to Favorites Watch
Beginningwoodworker
13345 posts in 3701 days
05-16-2009 05:37 PM
My planer has two speeds dimensioning and finishing speed, I try the finishing speed I am wondering do it really smooth the board, I have always use the dimensioning speed.
7 replies so far
117127 posts in 3606 days
#1 posted 05-16-2009 05:42 PM
I don’t have a delta but with planners in general if you have a slower feed rate it should give you a better finished board.
teenagewoodworker
2727 posts in 3797 days
#2 posted 05-16-2009 05:48 PM
it just gives you a better cut quality with less chip out if you are using a figured wood or since the knives cut more often a smoother surface. it wont actually bring the board to a finish ready state
27250 posts in 3850 days
#3 posted 05-16-2009 06:53 PM
Charles, the planer is designed to use the 60 cpi setting for the initial dimensioning. Once one side is surfaced you should then alternate sides until you are near the final board width. Then switch, while the planer is running, to the 90 cpi setting and make passes on alternating sides until you reach the final thickness. The 90 cpi setting produces a board that is a little smoother than the 60 cpi setting, as Jim and Denis have said. You will still need to sand and/or scrap to get the board ready for the application of stain or finish but the 90 cpi will give you a smoother board than the 60 cpi setting.
View matt garcia's profile
matt garcia
1897 posts in 3700 days
#4 posted 05-16-2009 10:45 PM
Charles,
That function runs the board through the knives slower for a finer cut. I really don’t know why they added it, every woodworker knows there is plenty of sanding once the joinery is cut, right before glue up. Also after glue up.
-- Matt Garcia Wannabe Period Furniture Maker, Houston TX
View jack1's profile
jack1
2107 posts in 4056 days
#5 posted 05-17-2009 01:05 AM
It will reduce the sanding time and effort no doubt and anything that does that is good. When you use the faster speed, try taking off as little as possible on each pass. That helps the smoothing.
Beginningwoodworker
#6 posted 05-17-2009 01:57 AM
I only take off a 16th at a time.
View BlankMan's profile
BlankMan
1490 posts in 3381 days
#7 posted 05-17-2009 02:20 AM
I’m surprised at the two cutting speeds on this planer, 60 cpi and 90 cpi. My DeWalt 735 is 96 cpi and 179 cpi. And at 179 cpi I do get a very nice finish. DeWalt even says use the 179 cpi setting when planing hard or figured wood to reduce wear on the knives and to reduce tear out. Based on that I’d say run it at 90 cpi all the time. I pretty much run at 179 cpi all the time.
-- -Curt, Milwaukee, WI
