How can I tell if a gouge is for carving or turning?
« back to Woodturning forum
Forum topic by CFrye posted 02-24-2015 08:26 PM 2688 views 0 times favorited 60 replies Add to Favorites Watch
View CFrye's profile
CFrye
10247 posts in 1868 days
02-24-2015 08:26 PM
Topic tags/keywords: gouge carving lathe tool
Not able to find out, via multiple on-line searches if my new-to-me 1 3/4” gouge is for carving(would be OK) or turning(what I bought it for). Does it even matter? It was re handled by previous owner.
Pics:
(Modeled by hubby)
Thanks, in advance, for your help. :-)
-- God bless, Candy
60 replies so far
View chrisstef's profile
chrisstef
17429 posts in 3035 days
#1 posted 02-24-2015 08:30 PM
Id certainly think a tool that large would be for turning. The gouges (2 of em) that I use for carving are chisel sized. You’ll love that butcher steel, its some of my favorite out there.
View ksSlim's profile
ksSlim
1276 posts in 2918 days
#2 posted 02-24-2015 08:34 PM
All of my carving gouges are of thinner material than the lathe tools.
I notice that the gouge is apparently ground “out channel” (backside of the arc).
If the material is thick enough it could see some lathe time, but consider where it will ride the tool rest.
-- Sawdust and shavings are therapeutic
View Joe Lyddon's profile
Joe Lyddon
10123 posts in 4081 days
#3 posted 02-24-2015 08:35 PM
Yes… Turning tools seem to always have longer handles… while Carving tools tend to be much shorter & designed to be use with a mallet.
How the curvature, etc. of the Cutting ends compare, I don’t know.
View Rick Bailey's profile
Rick Bailey
247 posts in 1391 days
#4 posted 02-24-2015 08:35 PM
Looks like a spindle roughing gouge to me.
-- I'll bulid your dream,you tear it down.
Rick Bailey
#5 posted 02-24-2015 08:39 PM
CFrye
#6 posted 02-24-2015 08:44 PM
The previous owner rehandled the tool, is why I questioned it. Not saying he did it wrong or tried to pull one over on me…I just did not want to do anything unsafe.
Any hints on sharpening would also be appreciated. It’s in dire need! I have a slow speed wet grinder as well as a bench grinder, no jigs, yet.
-- God bless, Candy
View ColonelTravis's profile
ColonelTravis
1806 posts in 1923 days
#7 posted 02-24-2015 08:49 PM
After I got my crappy lathe I was surprised to see how many turning tools looked like the size of baseball bats. For my gouges I got the Wolverine jig, which works great. It was so frustrating trying to sharpen them without it. I could do it but they didn’t come out as great as with the jig. I know plenty of people have built a jig because the Wolverine ain’t cheap.
View Woodknack's profile
Woodknack
11827 posts in 2409 days
#8 posted 02-24-2015 09:18 PM
Early 19th century. Could also be a timber framing gouge.
http://www.wkfinetools.com/huk/Butcher/history/hReview/02-History-Butcher.asp
edit; after looking at it again and reading a little about the Butcher Bros., I suspect it is a wood carving gouge. You should ask the wood carving guys what they think.
View waho6o9's profile
waho6o9
8209 posts in 2605 days
#9 posted 02-24-2015 09:29 PM
Good score Cindy! What does the cutting edge look like?
View doubleDD's profile
doubleDD
7444 posts in 2072 days
#10 posted 02-24-2015 09:34 PM
More than likely a roughing gouge. The previous owner put on a larger handle to get better control when roughing. Those out of balanced logs are tough with a small handle.
View Grumpymike's profile
Grumpymike
2263 posts in 2344 days
#11 posted 02-24-2015 09:46 PM
Yep I agree with the spindle roughing gouge group … Handles that long tell you that it is a lathe tool … should have a 40 to 45 degree grind, (I set mine at 42-1/2 degrees as that is optimum between 40 and 45)
Good find on that tool.
-- Grumpy old guy, and lookin' good Doin' it. ... Surprise Az.
View Bill White's profile
Bill White
4950 posts in 3989 days
#12 posted 02-24-2015 10:22 PM
I am an avid Butcher collector. You will find the steel to be of very high quality.
I have one that is very similar, but with a much shorter handle. Kinda looks as if the tool would do multiple jobs depending on the handle.
Wanna sell it?
Bill
-- bill@magraphics.us
View bondogaposis's profile
bondogaposis
4770 posts in 2380 days
#13 posted 02-24-2015 10:28 PM
Looks like a roughing gouge for turning to me.
-- Bondo Gaposis
View LeeMills's profile
LeeMills
550 posts in 1330 days
#14 posted 02-24-2015 10:41 PM
JMHO but it may be a spindle gouge. I suspect a carving gouge with the handle changed.
Beware of the very small/weak tang and do not use for bowls at all. IF a spindle gouge it is probably a “continental gouge” common in Europe. The largest continental I could find was a Sorby at 35mm and an Ashley Iles at 1-1/4 so the one you have would be very large indeed.
Packard does carry some continental gouges but not in that large.
http://www.packardwoodworks.com/Merchant2/merchant.mvc?Screen=CTGY&Category_Code=tools-srby-congou
or the Sorby
http://www.thebestthings.com/newtools/sorby_sgouges.htm
The amount of tang exposed makes me think it is for carving as this would be a long weak point for turning.
View jdh122's profile
jdh122
1018 posts in 2846 days
#15 posted 02-24-2015 10:51 PM
Carving gouges all have a shoulder on the tang. This is what allows you to hit them with a mallet without driving the handle further onto the tang with each wack. If you hit that gouge with a mallet it would eventually split the handle. This means that, while carving gouges can be used on the lathe, you generally should not use lathe tools to carve with.
-- Jeremy, in the Acadian forests
showing 1 through 15 of 60 replies
