| Forum topic by Toddmc | posted 1469 days ago | 611 views | 0 times favorited | 9 replies | ![]() |
1469 days ago |
I am curious as to how all the great woodworkers out there design their furniture. First I will tell a little about my normal practice. I fist find a design I like either on the web or in our projects section. Normally I take design elements from two or three different project then add a little of my own. I have never built straight from pre-made plans (I am to cheap for this). After I have the overall design I then Determine the General outside sizes and check that against the golden ration. I then do rough estimation for all the inside parts (like the inside of dressers). I come up with what I think is the appropriate joint and make a note on my drawing. I normally overcut my lumber then end up just using it as over cut. Sometimes I do not bother to resize legs such as for bed or nightstands to what I had drawn up figuring as long as it is bigger then I can undercut the rest of the stock once I get to the assembly stage. I cut all my lumber then I assemble. I want to know what others do. Do most of you use computer programs for your designs (if so which ones)? Are you own drawing measured up perfectly and you follow that plan or do you have overall dimensions written down and cut to fit the rest of the pieces? Or perhaps some of the truly gifted just start building with no plans, and if so how does the product turn out? I want to step up me skill level and need advise on proper planning before I start a project. |
