| Forum topic by Allison | posted 199 days ago | 719 views | 2 times favorited | 34 replies | ![]() |
199 days ago |
Topic tags/keywords: tip question I can’t say I ever thought about this before. Wood Glue’s shelf life. I am reading the 2009 issue of workbench magazine and inside on page 15 without an authors name is an article about wood glue and shelf life. Did you know wood glue’s shelf life is generally 1 to 2 years? even if it’s NEVER been opened? I did not. I am also guilty of this, buying wood glue when it’s on sale and buying more than I normally would. Trying to save that buck, just to find out now I have wasted that buck. Just something to think about. There has got to be other’s out there besides me that never really gave a second thought to this! Matter of fact I have been complaining about my problems with glue since the first day I stepped into a shop. I now realize that this could have been one of my biggest problems! It just never crossed my mind that when I open a new container of glue it already could be no good. I am now after going up to my shop, a glue less woodworker, having thrown it all away except a little tiny bottle I just got. So do not buy glue that you don’t plan on using in the next year or two. Am I the only one who did not know that glue, especially unopened glue could be bad? I knew about not letting it get to hot or to cold etc. but not this! -- Allison, Northeastern Ca. Remember, Amateurs built the Ark. Professionals built the Titanic! |
199 days ago |
Hi Alison I’m glad i don’t have this problem i use epoxy sp10 plus i never over order so it doesn’t last that long but i thought the life of glue was quiet long so thanks for the heads up Andy -- cut it saw it scrap it |
199 days ago |
All glues have a shelf life but that does not mean the glue does not work. If you are investing time and money on a project, use the freshest glue you can. If you have doubts about the bonding qualities of your adhesive then do a test with the same kinds of materials you are going to bond/glue together to the point of destruction and see if the adhesive or the material fails. Tempatures, air flow and humidity can change the way an adhesive reacts so that too needs to be taken into account. -- Never board, always knotty, lots of growth rings |
199 days ago |
Hi Alison! Thanks for sharing your information….........I didn’t know either! Robin Renee’ AKA….....Woodchic -- Robin Renee' |
199 days ago |
...just a thought… check your finishes! -- Never board, always knotty, lots of growth rings |
199 days ago |
I only found out fairly recently. Prior to that, I had used some Titebond that was over three years old and it seemed to work fine, but I didn’t really test it. I still haven’t thrown it away because it still looks good, although I have already bought some more. Maybe it’s time to do a test with the old stuff. -- Dale Manning, Carthage, NY |
199 days ago |
I usually buy a bottle that’s easy enough to work with. Ya, I might have to buy a new bottle every project or two depending on the size but it makes it that much easier to deploy. This is the reason I don’t buy it by the gallon and transfer it to a smaller bottle. -- The smell of wood, coffee in the cup, the wife let's me do my thing, the lake is peaceful. http://web.me.com/deceiver6/Deceiver/Craftsman_on_the_lake/Craftsman_on_the_lake.html |
199 days ago |
I understand wood glue is affected by uva and maybe you could keep or extend the shelf life by keeping it in a dark box in a cool place might be worth trying Alistair -- excuse my typing as I have a form of parkinsons disease |
199 days ago |
Hey, a reason to be even more of a throwback and use a hot glue pot with animal hide glue! Hurray! In favor of animal hide glue is the fact that I can still see pieces of furniture held together with it after a couple hundred years. I can’t say that about PVA glues though. I have wondered about the longevity of Titebond, since it hasn’t really been around for centuries. Guess our descendants will find out :) -- Ooo, er. |
199 days ago |
Thanks for the info. I’ve always kept it at moderate temperatures, but didn’t know that it could go bad if kept closed. -- Rich, Seattle, WA |
199 days ago |
SCOTSMAN, “most” adhesives and finishes can be kept in cold storage to prolong their shelf life but not frozzen unless the manufacturer so denotes. Still if over the recommened shelf life they should be tested before used. -- Never board, always knotty, lots of growth rings |
199 days ago |
Hey Allison -- Jim from Heirloom Woodshop, custom furniture ,maker, woodworking school, heirloomwoodshop.com |
199 days ago |
I see it as expired candy. Just because they don’t taste as good doesn’t mean they don’t taste good. But fresh glue on important projects is a good idea -- Ed |
199 days ago |
Something I didn’t know either. I am working on a gallon of glue I bought about a year ago and still have about a quart left, I hope it holds up a little longer. Thanks for the info. -- Doug, Cass City, Michigan |
199 days ago |
I use gorilla wood glue it gets about a year life per bottle. -- Measure once cut twice....oh wait....ooops. |
199 days ago |
Never knew it would go bad if sealed properly, and kept at good temps. Will heve to test what I have before my daughter(Scrappys Squirt) and I glue up her husbands “Man Box” we are building. Thanks for the info. Scrappy -- Scrap Wood's the best...the projects are smaller, and so is the mess! |
199 days ago |
Somewhere I saw a brief article explaining the date code on Titebond bottles. The first number on the code is the year and the next letter represents the month. A=Jan, B=Feb, C=Mar…........ They do not use “I” and “J” in the code therfore N= Dec. I keep this posted inside the cabinet with my glue. I have not had any trouble with glue up to two years old. -- Jeff, Dayton, OH |
199 days ago |
Some good information. I knew this but we use it so fast it never goes bad. But I do need to check what I have in my workshop. -- Jerry--A man can never have enough tools or clamps |
199 days ago |
I found a good web page about wood glue a while back. http://www.woodworking.com/ww101glue.cfm I bookmarked it! -- Carving |
199 days ago |
It is a problem Allison, particularly in hot climates. I tend to squeeze the air out and seal the bottle to minimise the effect of air getting to the product. This works OK on sqeezeable (if there is such a word) bottles. -- Grumpy - "Always look on the bright side of life"- Monty Python |
199 days ago |
I usually buy a gallon of titebond about once a year. Then I will use a little squeeze (mustard type) bottle for convenience. I don’t think I have gone beyond a 1 1/2 years yet on a gallon. -- Gary, East TX -- The longest journey begins with a single step. |
199 days ago |
with intarsia like I do sometimes you are gluing literally over a hundred pieces together. If just one fails you have yourself a problem. @a1jim, I too am one that uses a felt pen to mark certain items, just never thought of doing it to glue, which I will from now on. I still am shocked that NEVER been opened glue also goes bad after a period of time! -- Allison, Northeastern Ca. Remember, Amateurs built the Ark. Professionals built the Titanic! |
199 days ago |
I learned this about 10 years ago. Like a1Jim, I mark mine with a date and seldom use it if it is over a year old. Same applies to “super” glues only it can go bad in as little as 6 months. They say refrigerating it helps but I don’t have a fridge in the shop. YOu get a clue super glue is going bad when it takes a long time for it to set up. Urethane glues doesn’t last forever either and are quite susceptible to contamination from moisture in the air. Squeezing air out of the container helps. I have had it go hard in the bottle in less than a year. -- Les B, Oregon |
199 days ago |
Have a two litre bottle of glue I bought cheap over 12 months ago, is still unopened so looks like it not going to be a bargain after all. Thanks for the info. -- Bob C, Australia. There are two theories to arguing with a woman and neither of them work. |
198 days ago |
Allison, I do know that some of the Elmers Glue, and I do have some that I’ve not tossed away just yet, has Mold on it. I never knew that Glue could get mold, I thought that it would have to be a Consumable item i guess before it could get mold… But you can’t Glue 2 pieces of Wood together with Bread neither… Handi -- Jimmy "Handi" Warner, http://jwarner75.etsy.com, http://handisworkshop.blogspot.com |
198 days ago |
I learnt that the hard way i used some out of date glue one time on a turning job and it let go and destroyed the job the glue did not hold properly so i always buy new small amounts of glue at a time to be sure its freash |
198 days ago |
Allison, I recently contacted TiteBond and here is there respons … very interesting. I asked why they didn’t post the manufacture date and … read their response: When we place the actual date or an expiration date on the material, the ——-Original Message——- How can I determine the age of this product? There is a faint 7 -- Don in San Diego, Ca. |
197 days ago |
Wow, This is sooo interesting, Thank you. -- Allison, Northeastern Ca. Remember, Amateurs built the Ark. Professionals built the Titanic! |
197 days ago |
You’re welcome, Allison. Your topic caught my eye because I recently had to throw about $20 worth of TiteBond away. Living in San Diego where the weather is always warm, my shop is even warmer because there is a huge boiler at one end. TiteBond is good for a year if it is stored correctly which means 70 degrees. I got a little angry at myself because I had bought the glue on sale and now realize it was on sale because it was 11 months old … then it sat in my shop for another 15 months. Live & learn. good luck, -- Don in San Diego, Ca. |
196 days ago |
I keep titebond 2 in the house where room temperature is constant. I suspect the expiration idea is a bit exagerated. Brought to us by the same mentality that insist we change oil in our cars every 3000 miles and day old bread will kill you. -- miles125, Alabama.."Architecture is frozen music"" |
196 days ago |
I guess buying the bigger bottle to save money isn’t the best way to go anymore. I never really gave the shelf life of glue a thought. Thanks for the info. -- Brian, Lebanon PA, If you aren’t having fun doing it, find something else to do. |
195 days ago |
Titebond has a good explanation of shelf life, aging, and a test to ascertain if the glue is still usable. See questions number 4 & 5. JIm |
195 days ago |
I go in halves on a gallon with my father means I get two quarts at a time. I keep my glue in two quart containers and then move it in dispenseing aprarati as needed. Go through it fast enough that I don’t have to worry about it. -- //FC - Round Rock, TX - "Experience is what you get just after you need it" |
191 days ago |
Allison, ANY chemical degrades with time. Putting something in a liquid state (solution, suspension, emulsion) accelerates this process by allowing the molecules to move around more and bump into more of the molecules that cause breakdown. A perfect example of this is shellac. The flakes have a much longer shelf life than the solution, but still go bad over time. The problem with glues like PVA is that they work by changing chemically as they cure. This means that they are more sensitive to internal chemical breakdown than something like hide glue that forms more of a physical bond as it cools. I guess the moral of the story is to never buy more than you can use in a practical period of time. Doing marquetry, a pint at a time might be sufficient. For a pro shop doing lots of large projects, five gallons might be a small purchase. It just depends on how you work. -- Robert from Raymond, MS. "We are what we repeatedly do. Excellence is therefore not a practice, but a habit." - Aristotle |
190 days ago |
Allison, |
| Forum | Topics |
Woodworking Skill Share
2937 |
3968 |
260 |
956 |
226 |
Woodworking Trade & Swap
624 |
Coffee Lounge
2403 |
LumberJocks.com Site Feedback
525 |
