Rust Removal by Way Of Electrolysis
Forum topic by Blackie_ posted 02-23-2015 02:42 PM 1050 views 0 times favorited 9 replies Add to Favorites Watch
View Blackie_'s profile
Blackie_
4883 posts in 2511 days
02-23-2015 02:42 PM
In the past I’d been using Apple Cider Vinegar to remove rust from steel and iron but I was just recently introduced to rust removal by using Electrolysis, I did a search here on LJ’s on this method and found that a few members had written a blog on their process with using electrolysis and after my research it appears that rust removal by electrolysis is a more promising method and easy to boot, I’m sharing this video which will give you all the info and details you need in using the method.
http://youtu.be/NKZv14-K71g
-- Randy - If I'm not on LJ's then I'm making Saw Dust. Please feel free to visit my store location at http://www.facebook.com/randy.blackstock.custom.wood.designs
9 replies so far
View Roger's profile
Roger
20928 posts in 2802 days
#1 posted 02-23-2015 02:51 PM
Thnx for the link Randy. I know Dave, http://lumberjocks.com/superdav721 did a video a long time ago about this same technique. He also used one of those kiddy pools. It seems to work really well.
View longgone's profile
longgone
5688 posts in 3307 days
#2 posted 02-23-2015 04:06 PM
An interesting technique…if only I had something rusty besides my bones…
View Bill White's profile
Bill White
4930 posts in 3959 days
#3 posted 02-23-2015 04:30 PM
Well done vid. I must add that the CathOID and anOID are really pronounced CATHODE and ANODE. Not a slam by any means, just a bit of correction.
Never thought about using a kiddy pool. Great idea.
Bill
-- bill@magraphics.us
View MrUnix's profile
MrUnix
6714 posts in 2197 days
#4 posted 02-23-2015 05:39 PM
Electrolysis works great but is WAY messy.. whatever you wind up using for a tank will be relegated to that task forever afterwards, or the garbage pile. Don’t try it with a kiddie pool that you ever want to use again as a kiddie pool! I’ve had good success on really large stuff by building a frame out of scrap wood and then lining with a couple layers of thick plastic sheets. At least that way, when you are done, you can just throw the plastic away.. grunge and all. For smaller stuff, I have a dedicated plastic bucket that I keep filled and ready to go:
Just need to filter the muck out of it once and a while. But because of the mess involved, I usually try to use evaporust whenever possible if possible. I have an old one gallon paint bucket that I keep filled with it and built a hardware cloth basket to fit in it. Most of the small stuff like nuts, bolts, pulleys, gears, etc.. go in it overnight and then it’s a simple rinse and you are done.
HillbillyShooter
5811 posts in 2291 days
#5 posted 02-23-2015 06:00 PM
Thanks for sharing—interesting stuff.
View Randy_ATX's profile
Randy_ATX
878 posts in 2440 days
#6 posted 02-23-2015 06:10 PM
Looks good Randy. Now I know where to bring my rusted items! ;-)
-- Randy -- Austin, TX by way of Northwest (Woodville), OH
View DocSavage45's profile
DocSavage45
8555 posts in 2841 days
#7 posted 02-23-2015 06:10 PM
Randy,
As you know, I did and have been doing the vinegar thing with my tools that just “rust” due to non use and high humidity in my shop. Rehabbed an 18 inch scroll saw and about 6 hand planes.
When I first thought about doing the rust removal I checked out LJ’s and YouTube for electrolysis and I am a little nervous about the off gases in my shop. I’ve seen some pretty impressive big restorations of used auto parts etc.
Maybe this Spring or Summer
-- Cau Haus Designs, Thomas J. Tieffenbacher
MrUnix
#8 posted 02-23-2015 06:20 PM
Don’t be. It’s really not an issue at all. Hydrogen and oxygen in very, very small amounts are released and dissipated into the atmosphere quickly. You can hold a lighter to the bubbles coming off and get a nice little ‘pop’ though if you feel bored :)
View bonesbr549's profile
bonesbr549
1549 posts in 3065 days
#9 posted 02-23-2015 07:23 PM
I do this all the time. I’d do it in the garage with the door open, not a confined space. It works! I reclaimed a set of relaoading dies someo gave me and you’d not know there were once a big piece of rust. The gas is nasty though, do not do in confined space. If you get enough of it and a spark it will be a bad day!
Same principle will copper coat lead bullets too.
Better living through science.
