plastic/phenolic sheet sources
Forum topic by Tailor posted 1469 days ago 2662 views 0 times favorited 15 replies Add to Favorites Watch
View Tailor's profile
Tailor
7 posts in 2062 days
1469 days ago
This might be a dumb question, but that never stopped me before.
In many shop made jig and guide designs, I see phrases that go something like this:
“For this jig I chose a sheet of 4/5/6/8/etc mil sheet of acrylic/plastic/phenolic for it’s rigidity/flexibility/strength/etc.”
Or phrases like this:
“First you get a 1/4” plastic/acrylic/phenolic sheet and cut out a (fill in shape or dimensions here)/custom router base/etc.”
The question is this. Where are these people getting this stuff? Unless its just normal to call up a plastics supply place and order a few sheets of these materials, I have no idea where one gets the stuff. Maybe there is an obvious answer I have been missing, if so, please tell me.
I guess I would also like to know if there are any special considerations to working this stuff, does it need to be cut or milled in some special way?
15 replies so far
View depictureboy's profile
depictureboy
420 posts in 1811 days
#1 posted 1469 days ago
Lowes or home depot sells sheets of acrylic. You can also order from the custom cabinet area(formica)
I havent done any of this yet…
phenolic you can get from rockler, but its expensive.
-- If you can't build it, code it. If you can't code it, build it. But always ALWAYS take a picture.
87141 posts in 1746 days
#2 posted 1469 days ago
I have student that uses plastic cutting boards from a dollar store
View interpim's profile
interpim
1115 posts in 1627 days
#3 posted 1469 days ago
http://sdplastics.com/
-- San Diego, CA
View parkerdude's profile (online now)
parkerdude
147 posts in 1620 days
#4 posted 1437 days ago
Hi Tailor,
Here in St. Louis there are a couple of plastic supply and fabrication companies that sell their odd cutoffs and scrap for a lower price than for whole sheets. They sell it out of their office by the pound. Most of the various plastic sheet goods aren’t so high, but phenolic is HEAVY and therefore a bit pricey.
Good luck
-- dust control
View Mike Gager's profile
Mike Gager
613 posts in 1436 days
#5 posted 1435 days ago
try www.grainger.com as well
you might have a local store close to you too, there is a store search function on their site
View Jim Crockett (USN Retired)'s profile
852 posts in 1902 days
#6 posted 1430 days ago
I live in Maine and can’t find anything like that around here – I use McMaster-Carr or Grainger. I can’t even find plastic laminate here – neither Lowes doesn’t carry any and I’ve only found one HD that carries nothing but full sheets and those are $60. Somehow I can’t justify spending $60 when I only need a 15×18 inch sheet and have no place to store the remainder. Can’t find any online either. Lumber stores in the area offer it at $3 per sq ft, minimum of 15 sq ft! What really sucks is that Pionite, one of the big producers is only 25 miles away but you can’t get it directly from them.
Jim
-- A veteran is someone who, at one point in his/her life, wrote a blank check made payable to "The United States of America," for an amount of "up to and including his/her life".
View skone's profile
skone
144 posts in 974 days
#7 posted 821 days ago
Thanks for asking this question. I believe I’ll be trying the local Grainger store — I’ve never been in it. I always thought it was a contractor only, wholesale sort of operation. As for dollar store cutting boards, I think that’s a great idea. You gamble on availability and actual material but I would imagine templates have been made from more questionable materials. And as I’m new to template making, cutting on inexpensive material for practice and room for error sounds great.
-- "Take extra care not to lose what you feel" (Winwood/Capaldi/Wood)
View harvey4804's profile
harvey4804
98 posts in 850 days
#8 posted 820 days ago
Try Port Plastics I deal with this company very often. Very polite and informative and have a large variety in stock. They can even give you certifications for the material if you want them.
-- Ryan, FRMR HMM165 - HMX1 01-10
View Howie's profile
Howie
2449 posts in 1092 days
#9 posted 820 days ago
I use the dollar boards a lot. Also I poke around the Habitat for Humanity stores and sometimes you get lucky and find a piece of Phenolic cheap. When I do I always buy it whether I need it or not.
-- Don't rollerskate in a buffalo herd
View 2talltary's profile
2talltary
5 posts in 805 days
#10 posted 805 days ago
http://www.iplasticsupply.com and http://hightechplastics.com/ are great places for acrylic and phenolic.
View David Grimes's profile
David Grimes
2114 posts in 808 days
#11 posted 782 days ago
Rockler ONLY has the 24” x 36” iirc. I want a 48×48.
-- If you're going to stir the pot, think BIG spoon or SMALL boat paddle. David Grimes, Georgia
View Tedstor's profile
Tedstor
927 posts in 801 days
#12 posted 782 days ago
IKEA sells a 2 pc pack of cutting boards for $1.99. I’ve also “sourced” good materials from garage sales. My freind has a nice router table he made from a clear plastic basketball backboard he bought for $10.
Materials are all around you. I can’t make it 20 paces in Ikea without seeing some item and thinking “hmmm that would make a good _ jig. “
View LaughingLarry's profile
LaughingLarry
1 post in 658 days
#13 posted 658 days ago
Hey David,
Not sure they can help, but I just bought a sheet of stuff called paper based phenolic in .375” thick. The sheet was pricey, but fit my needs really well. I live in San Diego, and picked it up in Anaheim at Industrial Plastic mentioned above – and they cut it to size for me. I don’t know if they have the size you need, but I got a 39” X 48”. They are at: www.iplasticsupply.com and they have lots of cut pieces of lots of materials in their store. Got some great blocks of black plastic stuff to work with. Here is their number – give-um a call: 866-832-9315. Good luck. Larry
View Pimzedd's profile
Pimzedd
334 posts in 1973 days
#14 posted 658 days ago
Tailor, where do you live. If it is a major city, most have plastics supply houses. Some with custom cut to size. Some with have a drop-off bin with great prices. They all stock multiple types of plastics and multiple thickness. This is based on my teaching a Plastics Technology vocational course in Dallas for 34 years. Look in the Yellow Pages under plastics suppliers or plastics fabricators. Wait, do they still have Yellow Pages?
The sites others have provided will probably meet all your needs.
-- Bill - Mesquite, TX --- "Everything with a power cord eventually winds up in the trash.” John Sarge , timber framer and blacksmith instructor at Tillers International school
View MrRon's profile
MrRon
1578 posts in 1412 days
#15 posted 657 days ago
There are many plastic supply houses with on-line catalogs. One such source is: WWW.usplastic.com
