Dang it already... :-( Fence problem...
Forum topic by Milo posted 1470 days ago 733 views 0 times favorited 17 replies Add to Favorites Watch
View Milo's profile
Milo
802 posts in 1488 days
1470 days ago
I spent the morning lining up and drilling to put the fence on my new unisaw. Everything used, and the previous owner did things bass ackwards.
I used my smaller biesemeyer to estimate everything I did on this one, but I’ll be danged if when it was all said and down the fence itself did ride up a good quarter of an inch or so off the tabletop. I didn’t notice it until I was across the room and looking back at the saw.
Do you think this is going to be a huge problem? I really detest the idea of drilling the caste iron again. I often us a sacrificial fence also…
Any thoughts? Drill again, right? :-(
Thanks,
Dell
-- Beer, Beer, Thank God for Beer. It's my way of keeping my mind fresh and clear...
17 replies so far
View lew's profile
lew
8982 posts in 1924 days
#1 posted 1470 days ago
A “permanent” sacrificial fence looks like the way to go, to me.
-- Lew- Time traveler. Purveyor of the world's finest custom rolling pins!
View marcb's profile
marcb
762 posts in 1842 days
#2 posted 1470 days ago
What fence did you put on the Uni that you had to drill?
View Ben 's profile
Ben
150 posts in 1533 days
#3 posted 1470 days ago
I recently put a new fence on my table saw. It rides a little high.
This wasn’t a big problem until I went to cross-cut a wide piece of 1/8 inch plywood. I had the fence about 30” to the right, about a foot beyond my right extension table. As I was feeding the plywood through it slipped under the fence and wedged. It caused a pretty nasty kickback and I was lucky I didn’t get hit with the flying lumber. Needless to say I had to take a break from woodworking that day.
So, I would recommend redrilling or flush mounting an auxiliary fence anytime you are cutting thin wood.
View PurpLev's profile
PurpLev
7749 posts in 1817 days
#4 posted 1470 days ago
as long as the fence rides smoothly across the table and true to the blade – Id second lew, and go with a permanent auxiliary fence on it.
27262 posts in 1990 days
#5 posted 1470 days ago
Milo, I agree with Lew’s idea. I tried a Delta T2 fence on my Craftsman saw and, like yours, it sat 3/8 of an inch proud of the table. I put a plywood strip on it as a means of getting zero clearance. It worked pretty well. You can attach it to your saw via screws or you can use these clamps if you do not want to drill into your fence. They work pretty well.
View Chris Wright's profile
Chris Wright
519 posts in 1650 days
#6 posted 1470 days ago
The idea of using a auxiliary fence is a good idea, but I have an idea that might work. Now I’ve not looked at your setup so I don’t know if it will work, this is just a thought, but, why not widen one of the hole (either in the cast iron top :( or in the aluminum rail) and use a wider washer when you put the bolts in giving you some adjustment room. Sort of like a drawer front. Again, I’ve not tried this, so I don’t know if it’s possible to do what I’m thinking, just thought I’d put it out there and see what everyone thought.
-- "At its best, life is completely unpredictable." - Christopher Walken
View Milo's profile
Milo
#7 posted 1470 days ago
Sorry, the fence is 54” biesemeyer… or 50 something, I forget off the top of my head…
The present sides on the fence are replacements, definatly not original. I suppose I could replace them also.
Chris, are you saying drill the holes in the cast iron larger?
Thanks guys,
Milo
View Greg The Cajun Box Sculptor's profile
3774 posts in 1477 days
#8 posted 1470 days ago
Another solution would be to buy some 1/4” UHMW and use it as a sacrificial fence attachment. It works great since it is very slippery and reduces friction when using the fence. I have a piece on my fence and recommend it.
-- Every step of any project should be considered your masterpiece if you want the finished product to reflect the quality of your work. http://www.FineArtBoxes.com
Chris Wright
#9 posted 1470 days ago
Either the cast iron or the fence rail. I don’t know if either will accommodate a larger hole. My Unisaw top has about an inch lip coming down in the front, I’m using the Unifence on my saw so there isn’t any room on in the rail for a larger hole. I’m not familiar with how the rail attaches to the saw on a Biesemeyer, but if you can widen those holes instead, I have no doubt it would be easier then the cast iron.
Chris Wright
#10 posted 1470 days ago
Ok, so I’m looking at the user manual for the Biesemeyer fence. And depending on how many screws you’re using, you might be able to get away with just widening the holes on the rail that holds the guide tube (it’s nice to know the actual names of the parts). And drilling the rail might be better, since if it needs to be replaced it’s bound to be less expensive than having to replace the whole top.
View Toddmc's profile
Toddmc
30 posts in 1538 days
#11 posted 1469 days ago
Does anyone know if cross brand fence systems are extremly different? I want to put a rigid table saw fence system on a steel city table saw. Are there certain things I should be aware of before I try this, or is it even possible? Also would the steel city fence I have work with a rigid brand rail system?
View ajosephg's profile
ajosephg
1719 posts in 1729 days
#12 posted 1469 days ago
I have to ask – Did you check to make sure the fence is adjusted as far down as it goes? Recently I put a Delta T2 fence on a non Delta saw, and their are 6 bolts on the inside of the fence that can be loosened to lower or raise the fence ride height.
-- Joe
marcb
#13 posted 1469 days ago
I’m still trying to figure out why you had to drill, the Bies is built for the Uni hole pattern. Outside of maybe drilling extra holes to help secure the installation you should be able to mount everything with out drilling.
The bottom of the front bracket should be 2 27/32” from the table top. I think the rear rail is 2 25/32
View Milo's profile
Milo
#14 posted 1467 days ago
ajosephg?
Bolts? Where? Can you send me a pix?
Marcb,
For whatever reason (age?) this saw did not match up properly.
Thanks!
Milo
ajosephg
#15 posted 1467 days ago
Milo -
Send me a personal message so that we can exchange email addresses, and I’ll send some photos.
-- Joe
