Porter Cable DP Runout
Forum topic by Garbanzolasvegas posted 02-21-2015 05:54 PM 783 views 0 times favorited 2 replies Add to Favorites Watch
View Garbanzolasvegas's profile
Garbanzolasvegas
356 posts in 1345 days
02-21-2015 05:54 PM
I have tested and used my PC DP and there is zoo much run out. I think I need an after marketer Chuck and mate a new Arbor. I have looks at Jacobs, but would like a Chuck that isn’t made out of GOLD and or Platinum.
I cant spend more money on a chuck than I sent on the DP
Any suggestions
PS I am NOT making part for NASA or anything like that
-- If you don't Play, you can't win
2 replies so far
View bobkberg's profile
bobkberg
439 posts in 3191 days
#1 posted 03-08-2015 07:19 PM
Hi Garbanzolasvegas,
Do you know if the runout is radial or axial? (See http://en.wikipedia.org/wiki/Run-out)
The problem could be bad bearings or a defective quill shaft, or a bad chuck (since it sounds like you already suspect the chuck).
See if you can borrow a dial indicator to test the chuck and shaft at hand-turned speed, and also manually check for wobble at the upper and lower ends.
With the dial-indicator, also measure for runout with the shaft at the top and bottom of the shaft’s travel distance.
Let us know what you find out.
-- Bob www.singularengineering.com - A sideline, not how I earn a living
View TheFridge's profile
TheFridge
10101 posts in 1604 days
#2 posted 03-08-2015 07:41 PM
Try turning to spindle 180 degrees and see if it improves. I also tightened up the screw on the quill as much as possible while still letting travel smoothly
