DeWalt 735 not feeding
Forum topic by Grantman posted 02-21-2015 05:26 PM 1813 views 1 time favorited 34 replies Add to Favorites Watch
View Grantman's profile
Grantman
113 posts in 4200 days
02-21-2015 05:26 PM
Topic tags/keywords: question planer
My 735 is not feeding. I’ve cleaned the rollers two or three times with mineral spirits. I’ve waxed and polished the plate twice. I’ve pulled the side box off and checked the drive chain – no broken sprockets and everything looks OK…both rollers are turning. I’ve rotated the knives so the new side is exposed (the old ones weren’t so old, but I did it anyway). It’s in a heated basement with essentially constant temperature year round. Today it’s about 65ยบ.
I take off 1/64” to 1/32” at a time. Just putting a 6” cherry board stopped it completely. I had to turn the crank up to get the board out of the planer.
I think I’ve exhausted all the suggestions from other posts. Is there something I’ve missed? Any help would be greatly appreciated.
Thanks in advance.
34 replies so far
View hotbyte's profile
hotbyte
991 posts in 3150 days
#1 posted 02-21-2015 05:29 PM
Maybe try a different board just to see if same no feeding results?
Grantman
#2 posted 02-21-2015 05:32 PM
I actually have three boards I’m trying to plane and all of them stop the tool.
View Targa's profile
Targa
118 posts in 1914 days
#3 posted 02-21-2015 05:36 PM
Mineral spirits can sometimes leave a slightly oily residue so you might try using alcohol which is a good cleaner and dries fast without leaving any residue. I just went through the same thing with my 735.
-- Dom
Grantman
#4 posted 02-21-2015 05:37 PM
Thanks, Targa. Will try it.
View WhyMe's profile
WhyMe
1061 posts in 1736 days
#5 posted 02-21-2015 05:41 PM
Do the rollers stop turning when the board stops? If the rollers stop then it’s a loose drive gear in the transmission.
Read this.. http://lumberjocks.com/topics/63806. The problem was a loose gear.
Grantman
#6 posted 02-21-2015 05:48 PM
Targa, nope. Alcohol didn’t do anything. WhyMe, is that something I can fix myself? I pulled the cover plate off and just saw the chain and sprockets. Do I have to pull all that apart?
WhyMe
#7 posted 02-21-2015 05:54 PM
Targa, nope. Alcohol didn t do anything. WhyMe, is that something I can fix myself? I pulled the cover plate off and just saw the chain and sprockets. Do I have to pull all that apart?
- Grantman
If it’s a loose gear I assume it’s a DIY fix. Probably a loose set screw.
Grantman
#8 posted 02-21-2015 06:06 PM
WhyMe, yes. The rollers stop when the board hits the infeed roller. Here’s a quick video I just shot. It stops with the least amount of pressure. https://www.youtube.com/watch?v=1GoDEzhZg2o
While I can build things from wood, I’m not that mechanical. Any assistance will be greatly appreciated.
View TheFridge's profile
TheFridge
10502 posts in 1661 days
#9 posted 02-21-2015 06:15 PM
Check sets screws on all the rollers sprockets and associated linkages.
View bbasiaga's profile
bbasiaga
1240 posts in 2170 days
#10 posted 02-21-2015 06:52 PM
Is there a notch in the shaft and a matching notch in the sprocket? Hard to tell from the cell phone video, but I thought I saw a dark spot there. If so, there should be a rectangular metal ‘key’ there to keep the shaft and sprocket spinning together. Looks missing in the video. Either way, something needs to hold the shaft and sprocket together. Set screw, key, something.
-Brian
View CL810's profile
CL810
3856 posts in 3163 days
#11 posted 02-21-2015 06:54 PM
^+1
-- "The only limits to our realization of tomorrow will be our doubts of today." - FDR
View dbray45's profile
dbray45
3320 posts in 2951 days
#12 posted 02-21-2015 07:02 PM
You may have worn out the roller bearings as well as the shaft that has the loose gear.
-- David in Damascus, MD
View alittleoff's profile
alittleoff
541 posts in 1451 days
#13 posted 02-21-2015 07:05 PM
Your trouble is the shift is spinning in the sprocket. Key is missing. You should have a key in the slot of the shaft that the sprocket is spinning on. It will also have a set screw to hold it in place. The set screw screws down through the gear or sprocket which ever you want to call it, and tightens the key in the shaft. Should be an easy fix.
Gerald
Grantman
#14 posted 02-21-2015 07:15 PM
Good catch on the key, or lack thereof. Looks like a trip to my local DeWalt repair center. Can’t figure why both shafts would lose their keys, though. Hmmmmm….
I’ll be back next week after I hit the repair place.
Thanks to all for the help.
View MrUnix's profile
MrUnix
7005 posts in 2374 days
#15 posted 02-21-2015 07:18 PM
Good catch on the key, or lack thereof. Looks like a trip to my local DeWalt repair center. Can t figure why both shafts would lose their keys, though. Hmmmmm….
Just go to your local hardware store.. those are an off the shelf item and no need to pay 10 times what they are worth just to have Dewalt personally hand them to you.
showing 1 through 15 of 34 replies
