Slide switch for my Shop Vac
Forum topic by sportflyer1 posted 02-21-2015 04:04 PM 824 views 0 times favorited 4 replies Add to Favorites Watch
View sportflyer1's profile
sportflyer1
24 posts in 1166 days
02-21-2015 04:04 PM
The slide switch for my old shop vac is getting intermittent. It turns on OK but tends to switch off by itself due to vibrations . Last night I dismantled the unit and found that the panel mounted slide switch is rated at 11A , 125V . The switch body is definitely less deep( front to back) than the standard 6A slide switches I have in hand . The contacts in the Shop vac switch seems pretty large compared to the 6A switches. I can’ t even try to use the 6A rated switch because it’s too thick and wont fit.
I looked in Mouser and Digikey and basically 6A is what they have in their catalogs. 13A not available as a panel mounted slide switch. So I am in a quandary .
Perhaps I will need to drill a hole someplace else and use a toggle or rocker switch instead . Any ideas?
BTW 11 amps seem pretty hefty for a shop VAC. 11A at 125V is 1375 watts or approx 1.8 HP .
View mrg's profile
mrg
818 posts in 2963 days
#1 posted 02-21-2015 04:12 PM
Try Radio Shack or Jameco Electronics.
-- mrg
View MrUnix's profile
MrUnix
6586 posts in 2163 days
#2 posted 02-21-2015 04:15 PM
Radio Shack will be a hit-or-miss and your local one might not even be there any more since they went under. I’d try opening it up and fixing it if possible.
View pjones46's profile
pjones46
1001 posts in 2606 days
#3 posted 02-21-2015 04:21 PM
You might try looking in those pull out drawer units that are in the hardware stores and the big box stores. They sometimes have drawes with misc switches.
-- Respectfully, Paul
sportflyer1
#4 posted 02-22-2015 04:40 AM
I fixed it by using a 20 a rocker switch. Had to cut a 3/4 inch hole for the switch and also modified the switch housing to accommodate the larger switch. The original switch is an obsolete part.
