Grizzley left vs right tilt table saws
Forum topic by ellen35 posted 198 days ago 646 views 0 times favorited 14 replies Add to Favorites Watch
View ellen35's profile
ellen35
536 posts in 328 days
198 days ago
I ordered a new Griz 0444 table saw that was a right tilt table saw. They are back ordered until the end of June (on Thursday, they were back ordered till May 15!!). Today, I called and they can ship out a left tilt G0575 – same table saw just with left tilt. So I asked them the difference (I know the obvious difference!) and Customer Service said that it is just “preference”. If that’s all it is, great! I did a search on LJ and it is not clear whether one is preferred over the other or why. I appreciate any advice. I did order the left tilt today.
Thanks for all your help. LJs are the best, most helpful group of people I know!
-- Ellen on Cape Cod
View Don K.'s profile
Don K.
1095 posts in 222 days
198 days ago
ellen,
Like he said, it is just personal preference. I have always had “Right” tilting saws, But I just ordered a new Grizzly G0690 this morning, left or right really does not matter to me. But I think you will have better resale value with a left tilting saw. Some company’s have totally dropped their right tilt saws.
-- Don S.E. OK
View woodworm's profile (online now)
woodworm
8262 posts in 486 days
198 days ago
I agreed it is a matter of preference. I have both TS (left tilt and right tilt). With the ripping fence’s on the right of the saw blade, (the rule measurement fitted to the right of the blade) I am more comfortable working with the left tilt.
-- masrol, kuala lumpur, MY.
View PurpLev's profile
PurpLev
2759 posts in 544 days
198 days ago
here is the preference differences:
LEFT TILT: safer for beveled cuts – since if your fence is on the right side of the blade, your main piece (that you are pushing) will be above the blade, and is controlled, whereas the cutoff piece will ‘fall’ under the blade – and just sit on the table surface (a right tilt saw will have the cutoff piece “fall” ON the blade, and will most likely be shot back (kickback) so you’ll need to watch out for that, and also the blade will be tilted towards your push stick/hands – unless you’ll move your fence to the left side of the table…).
RIGHT TILT: since the blade arbor is on the left – the marking gauge (ruler) will ALWAYS be accurate for the length of cut it shows – that means, that regardless of the blade thickness you use (regular kerf, thin kerf, even dadoes) the right side of the blade (against the arbor) will always be the same – and for that – the distance marking on the ruler will always be accurate on the right side of the blade.
I personally never trust the markings anyways, and I like the added safety of beveled cuts when I need to make them – so left tilt works better for me.
woodworm
198 days ago
This may be a good reference
http://lumberjocks.com/topics/4681
16910 posts in 473 days
198 days ago
I prefer left tilt and have not found any accuracy differences due to the tilt. most tools it turns out to be what you get use to. If you get either left or right I’m sure you will find that it will work out fine, I do believe there are safety benefits to left tilt saws, That may be why grizzly stocks more left tilts they get more orders for them.
ellen35
198 days ago
Cool! Thanks for your advice! I think I ordered the correct one for me today!
Ellen
PurpLev
198 days ago
Congrats Ellen! Enjoy the new Toy…err…. tool
View bentlyj's profile
bentlyj
786 posts in 366 days
198 days ago
One thing I like about the left tilt is that you get a nice crisp top edge when you cut an angle.
Right tilts you cut your angle with the face down and are subject to more chipping off the front.
Of course it depends on what your cutting and making.
Sorry if I’m not good at explaining myself, but I normally cut my angle with the face up using my left tilt saw and it gives my a nice sharp edge.
View miles125's profile
miles125
1425 posts in 901 days
198 days ago
Left left left! I’d add 15% to its value just for that feature.
View juniorjock's profile
juniorjock
790 posts in 661 days
198 days ago
ellen, I have the G0575. I have had one other saw and it was left tilt too. To me it seems to be easier for a right handed person. But then again, I’ve never used a right tilt so I really can’t compare. You will like the saw. The Shop-Fox rip fence that came with my saw works great and is easy to adjust. The miter fence is a different story. You will need to upgrade to an Incra or something like that or build a nice sled to use.
-- JJ...... I guess you could say I'm a 54 year old "juniorjock". — Make things with wood.
ellen35
198 days ago
juniorjock
Thanks for the info! I already have an Incra 1000SE. I’m really glad the right tilt fell through and I ordered the left tilt.
Ellen
View DaveH's profile
DaveH
372 posts in 674 days
198 days ago
Left tilt. Much safer. Left tilt is the Europeon standard.
-- DaveH - Boise, Idaho - “How hard can it be? It's only wood!”
juniorjock
198 days ago
Sounds like you’re good to go ellen. I have the 1000SE too and love it. Good luck with the saw.
View Tim Scoville's profile
Tim Scoville
55 posts in 231 days
198 days ago
Left hand tilt is safer. I have pinched wood between the fence and the blade with a RH tilt blade. Nobody got hurt but someone could have seriously been injured. Yeah, I was a bit careless. But it illustrated the potential danger and thus mine is LH tilt now. They are probably not selling many RH tilt TS’s anymore.
-- Tim S, WA
