| Forum topic by Maynard | posted 201 days ago | 860 views | 0 times favorited | 26 replies | ![]() |
201 days ago |
201 days ago |
The best stuff and only stuff I ever use! -- Never board, always knotty, lots of growth rings |
201 days ago |
Works great and keeps the rust away. -- It's better to have people think you're stupid rather than open your mouth and remove all doubt. |
201 days ago |
Really good stuff. I use it frequently. Works on all sorts of stuff in the shop -- Gary, DeKalb Texas |
201 days ago |
Found the idead on “New Yankee Workshop” site then couple of months later Norm was cleaning up a couple of old saws and used it in that episode. All I use on my band saw and drill press cast iron tables.(table saw is alum.) Scrappy -- Scrap Wood's the best...the projects are smaller, and so is the mess! |
201 days ago |
Put it on screws and they will drive in much easier. Use on wood bits and they will shed chips more easyly. |
201 days ago |
I use floor wax on my equipment it works great -- Jim from Heirloom Woodshop, custom furniture maker, woodworking school, heirloomwoodshop.com |
201 days ago |
It is the best release agent you can fiind when using epoxy to make a mold or pattern, or bedding a rifle stock. -- Debt is nothing more than the 21st Century's form of slavery. |
200 days ago |
Used it in the Army when we had to do the barracks floors. Lit it on fire threw the lid on poured it on the floor and buffed. I have used it ever since. Restored my Grandmother’s Table then applied the wax. Use it to keep away rust as all above. -- Measure once cut twice....oh wait....ooops. |
200 days ago |
My experience is that wax on machinery will get on the wood and increase likelyhood of finishing problems. WD40 won’t do this. -- miles125, Alabama.."Architecture is frozen music"" |
200 days ago |
I’ve used Johnsons P.W. for several years with great results. Only finnishing problems I’ve had were self induced -- If at first you don't succeed...Don't try skydiving |
200 days ago |
I use it on all of mine. -- Hope Never fails |
200 days ago |
I used it sparily. Small swirled application, allow to haze and buff it off. It keeps a smooth surface for the function of the table and helps the wood glide over it. -- kein Schaden ohne Nutzen |
200 days ago |
I sprayed mine with polyurethane, then waxed it. Never had rust again. -- Mike. mwurm13@yahoo.com |
200 days ago |
I use it on all of my equipment tables ,sliding surfaces of table rails, the faces of my rip fence, etc. On metal, it helps keep rust away; on fences etc. it helps to reduce friction. I even use it on the soles of my hand planes to keep rust at bay. GOOD STUFF!! |
200 days ago |
I use it but not on my machines for the same reason Miles sites, don’t want to take a chance it gets on the wood before the finish is applied. I use Top Cote on all my cast iron tables. Got a big can of it free with a machine purchase one time and I’m sold on it. Still have that same can, years now, one can lasts a long time. -- -Curt, Milwaukee, WI |
200 days ago |
Yeap, Paste wax is the beeter way to go…..I have heard good comments about Butcher’s -- Francisco Luna, San Francisco Bay Area. |
200 days ago |
Yup, and hand tools, too! Never a finishing issue, even with finicky water based lacquers. I’ve also had good results with Trewax and Goddards. The key is “silicone free”. -- - Please help keep Lumberjocks an enjoyable escape by refusing to participate in political discussions. Simply spit out the bait and ignore the thread... |
199 days ago |
I use the Johnson’s wax on all my tools where rust could be a problem. I have a question though. I read somewhere that if you add more than one coat of the wax it just removes the wax you already had on, so you pretty much end up with just one coat no matter how many coats you apply. Is this true? Maynard, I’ve never thought about using the wax for screws. That’s a good tip. I have been using bars of soap. When a bar gets to small to use, I put them in a jar with a little water. I just keep adding the bars to the same jar. After the water has softened the bars some, I use a scrap piece of wood to smash all the bars into one big glob (still in the jar of course). I keep the jar on the bench where I usually do all of my screwing (get your minds out of the gutter, LOL) I just take the screw and push it in to the soap and then it’s ready to go. Sometimes, you have to add a little water to keep the soap from drying out. -- JJ...... I guess you could say I'm a 54 year old "juniorjock". — Make things with wood. |
188 days ago |
I mix my paste wax with mineral spirits. I apply the mixture with a scouring pad and an orbital sander (this cleans up any small spots of rust). Once it’s dry, I rub it out leaving my cas iron tables slipery and better than new. |
188 days ago |
Works great. Should be no concern over getting on the wood because it gets hard on a floor and back when we used it on floor (sign of my age) we didn’t worry about it coming up on anything put on the floor. Just put on thin coats and buff it well. -- Insert clever tag line here |
187 days ago |
I’ve been using a Carnuba Automotive paste wax on mine. No problems yet. Sure makes everything slide easy and haven’t had any rust problems yet. I had a jointer that the bed had a little surface rust on it. I first used automotive rubbing compound to clean up the rust. Then used the automotive paste wax for a good coat of protection. Again, no rust yet. I wax all my iron tables. -- There are three signs of old age. The first is loss of memory. I forgot the other two! |
187 days ago |
rub on – rub off ! -- david ,new mexico ,allheart |
169 days ago |
I have found that “Renaissance Micro-Crystalline Wax” works better than any was I have used. It is an English wax used by the the British Museum and can be used on leather, metal, marble, and most importantly my tools. It dries hard instantly and doesn’t leave any fingermarks. So it is great on finished projects and really brings out the shine. It’s expensive ($26.00 for 7 ounces) but it is well worth it. I’ve had the same can for 5 years and it’s only half gone. Cheers -- Ben Kahmann Dayton, OH |
168 days ago |
I used it on my scrollsaw table, works great and I enjoy the smell as well :) Cheers. Chris -- making dust with my DW788 |
168 days ago |
I use it on everything in the shop. -- If you are not living on the edge you are taking up to much room. |
168 days ago |
I actually use it on my cars ! |
| Forum | Topics |
Woodworking Skill Share
2924 |
3954 |
257 |
952 |
225 |
Woodworking Trade & Swap
621 |
Coffee Lounge
2396 |
LumberJocks.com Site Feedback
524 |
