Nailer and nails for picket fencing?
Forum topic by Goss posted 02-20-2015 10:54 PM 822 views 0 times favorited 3 replies Add to Favorites Watch
View Goss's profile
Goss
9 posts in 2207 days
02-20-2015 10:54 PM
Looking for advice on a nailer and nails for a long run of picket (palisade) fencing.
Hello everyone, I am currently planning a long run of palisade fencing using pressure treated softwood. The total run will be 120m (140 yards) for which I intend to use pressure treated 4×4 posts, concreted (postcrete) into the ground.
Fence will be 6’ high, posts spaced using 3m (10’) 3” arris rails (triangular section), top, bottom and centre, and nailing on 4×3/4 round topped pales spaced 1” apart.
There is going to be a lot of nailing in this project and I’m interested in any suggestions as to what nailer and nails to use.
Initial thoughts are a Paslode IM350 and 2 1/2” galvanized nails – dovenailed into the arris rails.
Will that do it or is there something better. Please bear in mind I’m in England so I will be limited to Paslode, Hitachi, Makita or Bostitch.
Also, is an 8” round hole 2’ deep the right size for a 4” post?
Cheers.
-- cut twice, measure once, or is that the other way round?
3 replies so far
View russde's profile
russde
104 posts in 2805 days
#1 posted 02-20-2015 11:04 PM
Goss,
I’m sure other, more knowledgeable folks will be along shortly…til’ then:
I built fences for a few summers and would offer just a few thoughts.
1. Use 8’ centers. 2×4’s that get out to 10’ are just too flimsy
2. Use three 2×4’s. Two on a 6’ fence is almost guaranteed to result in bowed pickets
3. Screw the 2×4’s to the posts with coated deck screws and I agree with the 2.5” galvanized nails, we used a Bostitch but the Paslode is a fine option, I don’t think (for this job) there is a wrong choice in guns.
4. 8” sounds about right, and 2’ is great, should end up using one bag of quickcrete per post or thereabouts.
Russel
View hotbyte's profile
hotbyte
991 posts in 2941 days
#2 posted 02-20-2015 11:26 PM
We just did a picket fence around our back yard. I did 4X4 PT posts 8’ on centers. For 4’ high sections I used 2 2X4 stringers on side screwed into rear of posts. 14 pickets are spaced between the posts. For the rear 6’ “privacy” section, I did 3 2X4 stringers and used a lot more pickets since it was a privacy type fence. Spaced maybe 1/2” apart.
I screwed the pickets to posts using some screws that are coated in something kind of gold colored with a T25 torq head. They have some special spiral within the threads and went in super clean, no splittings, etc.
I nailed pickets on with a Paslode. No idea of model…it’s a “framing” nailer that shots angle strips of nails that I bought 20 yrs ago. I used a galvanized nail that has a round head instead of D shaped head. The round head is offset from nail shank. Once sunk in, it looks just like they are regular hand hammered nails.
I used a 6” “one man” auger about 24”-30” deep holes. I averaged 2 bags quick setting quickcrete per 3 posts. For end/corner posts, gates, etc. I went deeper and opened hole up to use a bag per pole.
I have a 16’ drive-in gate and used 6X6 posts set 36” deep and dug holes extra wide into the opening side. I think I used 3 or 4 bags for each post :)
This is only second fence I’ve ever installed in last 30 years so take it for it’s worth…
hotbyte
#3 posted 02-20-2015 11:28 PM
PS – just goggle your arris rail…never seen those before.
