a real woodworking question - Rocker back question
Forum topic by Betsy posted 197 days ago 200 views 0 times favorited 6 replies Add to Favorites Watch
View Betsy's profile
Betsy
2386 posts in 789 days
197 days ago
I posted this in the blog section also, but I wanted to solicit some additional opinions. This is my back piece.
I’m pretty happy with the way the mortises/tenons fit together.
Now the question – Since the back slats are captured in the back rails and the back assembly is going to be captured between the side pieces, do I really need to glue the slats into the rails? I’ve got enough depth in the mortises for gluing, but I think if I glue, I’ll need to pare the tenons down a bit.
Thanks in advance.
teenagewoodworker
2481 posts in 662 days
197 days ago
you dont need to glue. but it would probably be a good idea just to give the whole assembly a little more rigidity. especially those little mortise and tenons that after a little bit of abuse could get pretty loose
View lew's profile
lew
4485 posts in 649 days
197 days ago
Betsy,
I agree with TWW, you probably wouldn’t need glue. The fact that the back slat tenons are not round also will prevent them from moving. I have seen chairs that the slats intentionally “float”.
Lew
16714 posts in 471 days
196 days ago
most tenons are glued in chairs. the need the extra strength.
View jockmike2's profile
7302 posts in 1140 days
196 days ago
I have always glued my back tenons because of the stress factor. There’s more there than meets the eye.
-- Mike. mwurm13@yahoo.com
Betsy
196 days ago
Thanks guys.
If I glue——Mike and Jim – I understand that with a glue joint the wood will give before the glue itself. Doesn’t this mean if the slat has a lot of stress that it will break above the joint? (This is purely a devil’s advocate comment by the way.)
Now since the slats fit so tightly in the mortise – there’s really no room for it to wiggle. Do you think that with use the slats will give back and forth and work the mortise open a bit and make the slats sloppy? Glue would probably prevent that don’t you think?
Now about the rigidity factor. Since there is such a span of material from the bottom to the top of the slat – and there is less than 2” of glue space – would glue really add that much to the strength of the chair itself?
I’d really like to see some more thoughts and opinions and reason for same to this. I know it’s a glue or not glue question – but there must be very good reasons why or why not.
I’m positively convinced that you guys can educate me more on this issue. Thanks in advance.
View miles125's profile
miles125
1419 posts in 899 days
195 days ago
I vote just enough glue that it doesn’t squirt out and give you a hassle cleaning it off.
