Planer knives
Forum topic by Glen posted 02-19-2015 08:18 PM 1545 views 1 time favorited 14 replies Add to Favorites Watch
View Glen's profile
Glen
116 posts in 3318 days
02-19-2015 08:18 PM
Topic tags/keywords: question
Does anyone have an inexpensive way of sharpening planer knives?
-- Glen
14 replies so far
View stefang's profile
stefang
16219 posts in 3575 days
#1 posted 02-19-2015 09:32 PM
  1. Get a board at least 1/2” thicker than the width of your planer blades and about 5” wide and 6” longer than your plane blades. MDF works well for this.
  2. Cut two lengthwise parallel grooves in the board from end to end with the same angle as your planer blades and also the same width as the thickness of your planer blades to a depth a little less than the width of you planer blades. the grooves have to be pointed from bottom to top towards the opposite edge of the board and an inch or two apart.
  3. Insert the knives in the grooves and the bevels should be slightly protruding from the top the grooves. The knives should be placed so that there is 3” left on each end of the board to use for clamping it to your bench.
  4. Check to insure that the bevels are the same height or very close to it.
  5. You need a sharpening stone or MDF with different sandpaper grits glued on and nice with a piece of wood glued on the opposite sides of the MDf to use as a handle. I use my DMT 600/1200 grit diamond sharpening plate for this purpose.
Please don’t hesitate to ask if you need clarification on any of the above explanations.
View DrDirt's profile
DrDirt
4526 posts in 3983 days
#2 posted 02-19-2015 09:37 PM
Just send them out.
Planer knives are only a ccouple times a year.
15 inch knives are 8 bucks to sharpen. If you value your own time at all, you are spending more than 8 dollars messing with jigs and such.
http://planerknivesdirect.com/sharpening.php
aka Connecticut Tool and Saw
View MrUnix's profile
MrUnix
7114 posts in 2440 days
#3 posted 02-19-2015 09:56 PM
I send mine out also.. not worth the hassle for the results I get trying to do it myself. My local shop does a spectacular job and always returns them in perfect shape and better than new. Although around here, they charge $1 an inch!
View Kazooman's profile
Kazooman
1270 posts in 2193 days
#4 posted 02-19-2015 09:59 PM
I guess it depends on the planer. For most of the bench top models, like the popular Dewalt DW735, new knives are as cheap or cheaper than sharpening. I assume you are talking about a more substantial machine.
View Quanter50's profile
Quanter50
278 posts in 2537 days
#5 posted 02-19-2015 10:10 PM
I’ve noticed more than once that when I send blades out to a “Professional Sharpener” (via. a local hardware store) they came back wavy. When you get them back, put them against a window that looks outside (like you would use a light table). Put them sharpened edge to sharpened edge. Check them against each other you’ll see what I mean. I sharpened them better myself with my Grizzly G2790 Universal Knife Grinder. Anyway, I resolved my planer knife sharpening problems and bought a Spiral Cutterhead for my 15” Planer.
View Roger's profile
Roger
20965 posts in 3045 days
#6 posted 02-20-2015 07:42 PM
Lotsa good info above.
View TheFridge's profile
TheFridge
10818 posts in 1727 days
#7 posted 02-20-2015 07:48 PM
I’ve had then sharpened with varying results. If you have to grind out Knicks, send em off. Just touching it up? Make a jig.
View Ripthorn's profile
Ripthorn
1459 posts in 3226 days
#8 posted 02-20-2015 07:57 PM
I have sharpened my “disposable” knives with 1000 grit sandpaper and a tiny bit of water on my table saw top (cleaned immediately afterwards to prevent rust). With just a couple of strokes on each knife, it was cutting better than new. I just laid it on the bevel, counted 5 or 6 strokes along the length of the knife, a couple strokes on the back, and done. Yes, you get great results sending them out, but my 20 minutes and single sheet of 1000 grit paper served me just fine if you only have one pair of knives or aren’t in the world’s greatest hurry.
View SASmith               's profile
SASmith
1850 posts in 3228 days
#9 posted 02-20-2015 09:06 PM
Here is my method.
Click for details
-- Scott Smith, Southern Illinois
View Glen's profile
Glen
#10 posted 02-24-2015 06:02 PM
Thanks to everyone for the great ideas! I made a jig with 45 degree kerfs cut lengthwise. Then I put sandpaper, grit side up, on my tablesaw top and put the jig, knife side down, on the paper and moved it back and forth about 1000 times, on sandpaper up to 220 grit. Now I can see scratches on the knives. I’m assuming that I need to get finer paper to remove the scratches.
-- Glen
SASmith
#11 posted 02-24-2015 11:22 PM
I usually stop at 400 grit.
View rwe2156's profile
rwe2156
3235 posts in 1721 days
#12 posted 02-25-2015 04:31 PM
I agree with DrDirt.
I just buy new ones.
View Andre's profile
Andre
2373 posts in 2047 days
#13 posted 02-25-2015 05:09 PM
http://lumberjocks.com/projects/106720
This is the jig I use to hone my blades after they are reground.
Guess as long as there are no nicks you could re-sharpen many times ?
View WAPY's profile
WAPY
56 posts in 567 days
#14 posted 07-21-2017 12:29 PM
on pinterest there are a number of jig for the pourpose.
this is one but other can work as well.
-- the good woodworker feels what the tree wanted to become
