Table saw issues help...
Forum topic by JockChris posted 02-19-2015 04:03 PM 669 views 0 times favorited 5 replies Add to Favorites Watch
View JockChris's profile
JockChris
70 posts in 2320 days
02-19-2015 04:03 PM
Topic tags/keywords: table saw miter track parallel issues tablesaw
Hello I have a ridgid 3660 table saw that the miter slots are not parallel to each other. They measured to be out .060
is that normal?? I had the top replaced and this one is better but still not parallel they measured out .019 much better.
Why would someone measure the slots to begin with well I tried making a few table saw sleds any they just would not slide and after doing some more checking here it what i have found out.
So now since I am dealing with a .019 taper do you think it is acceptable??
5 replies so far
View knotscott's profile
knotscott
7980 posts in 3342 days
#1 posted 02-19-2015 04:13 PM
0.02” isn’t too bad, but I really don’t know what the spec is….0.002” would sure be better. The work arounds could include registering your sleds to the edge of the table and/or to the slot that’s closest to being parallel with the table edges and blade. I’d also double check your measuring method just be sure.
JockChris
#2 posted 02-19-2015 04:22 PM
I have measured 1/2 doz. times and I’m using a 0- “1.0 dial indicator running a bar that finds the center of the slot can’t get a better measurement… if so I’d like to know I’ve also oh when using my dial indicator my measurements are .0300
and when I use a shit method with a miter gage i get .016- .019 So i have checked it using to different methods and come up with the same results.
View bondogaposis's profile
bondogaposis
4683 posts in 2318 days
#3 posted 02-19-2015 04:59 PM
Are both sides of the slots out of whack? You could make a sled that runs on the outer or inner edges of both slots.
-- Bondo Gaposis
JockChris
#4 posted 02-19-2015 05:02 PM
No the left slot is ok and I tuned my blade off the left slot and trued the fence from that side as well.
View toolie's profile
toolie
2120 posts in 2595 days
#5 posted 02-19-2015 10:52 PM
that should be fine.
