FWW Article
Forum topic by Gary posted 05-08-2009 07:27 AM 1027 views 0 times favorited 3 replies Add to Favorites Watch
View Gary's profile
Gary
9333 posts in 3457 days
05-08-2009 07:27 AM
Topic tags/keywords: question
FWW has an article on “hot-pipe bending” Bending wood by pressing it over a 200 degree pipe. Has anyone ever tried that?
3 replies so far
View Gar's profile
Gar
84 posts in 3358 days
#1 posted 05-09-2009 12:04 AM
it works by heat ing up the sap and softing the fibers i may have seen the fww pice i think i have that one any way it is the same more or less as steam bending just be sure not to let the wood burn soak the wood for 2 or 3 hr in water before heating have a form ready as this kind of heat will not last long use a backer to stop spliting i use a leak clamp for pipes as a backer i have used a pice of sheet metal i like bending shaker box and the like people always ask how did you do that plus i get a blast out of it to take something that is flat and make it curved the heat pipe is how you make music instruments you can also bend by heating water not to a boil and puting in the wood to make it flex
Gar
-- GAR
View GaryK's profile
GaryK
10262 posts in 4012 days
#2 posted 05-10-2009 03:37 PM
It’s called a bending iron. This is the one I use:
http://www.stewmac.com/shop/Tools/Special_tools_for:_Bending_sides/1/Bending_Iron/Details.html#details
You could also use a propane touch inside a pipe.
View Gary's profile
Gary
#3 posted 05-11-2009 03:36 AM
Thanks Gary. The torch and pipe is what I saw. This electric one would be easier to maintain.
