Turkey Box calls
Forum topic by ducdowg posted 05-08-2009 04:47 AM 2188 views 0 times favorited 6 replies Add to Favorites Watch
View ducdowg's profile
ducdowg
6 posts in 3277 days
05-08-2009 04:47 AM
Has anyone ever made a box call? If so any tips?
View Gar's profile
Gar
84 posts in 3241 days
#1 posted 05-09-2009 12:30 AM
let me know are you making a one sider or two sider on both the side need to be about 1/16 no more than 3/32 thick i make the chamber or hole about 1 3/8 deep by 4 1/8 long 1 3/8 wide rounded on each end with 1in stock left at each end and diped for the belly of the sound board the sound board need to be about 1/4 thick rounded to a 1/6 taper on each side i cut the chamber with a router and a pattern just like you would a door hinge for a one sider l leave the side sticking up the thicknes of the board plus 1/16 you can leave this on left for right hand or right for left hand and by the way cedar makes the best sounding calls i use cabnet makers chalk on mine but any chalk will work good luck with the call and the hunt i love gunning gobblers
Gar
-- GAR
View Gar's profile
Gar
#2 posted 05-09-2009 12:32 AM
the board need to taper to 1/16 not 1/6
-- GAR
ducdowg
#3 posted 05-09-2009 07:00 AM
Thanks Gar! Im making a two sider. I made one out of cedar it sounds good but it is a little high pitched. Got to find out how to lower the tone.
ducdowg
#4 posted 05-10-2009 01:44 AM
Well I have one done. It sounds pertty good. Time to start anouther.
View Willie1031's profile
Willie1031
141 posts in 2444 days
#5 posted 06-21-2011 06:43 PM
I’m looking at making one now. Got plans off of www.customsawing.com.
I hope I don’t get in trouble for posting another website on here.
-- A man cannot be comfortable without his own approval. -- Mark Twain
View stratiA's profile
stratiA
101 posts in 3282 days
#6 posted 06-22-2011 06:22 AM
I made one using plans from customsawing.com. I experimented with the plans with longer ones as well. My observation is you should use a harder wood for the lid. Also, the grooves in the sides helped a lot with tone. Pretty sure the thinner the sides or reduction of mass (grooves) ultimately tunes the call. Sand after u assemble. http://lumberjocks.com/projects/25466
-- Strati Alepidis, Burlington, Ma, Member Red Sox nation
