Delta Rockwell 8 inch Jointer
Forum topic by Rivercitykenb posted 02-18-2015 08:13 PM 1622 views 0 times favorited 11 replies Add to Favorites Watch
View Rivercitykenb's profile
Rivercitykenb
25 posts in 1181 days
02-18-2015 08:13 PM
http://richmond.craigslist.org/tls/4885120708.html
Does this look like a good deal? would be my 1st jointer and dont really know much about it.
trying to pick up a jointer and a planer for under $1000 and this fits right in that wheelhouse.
11 replies so far
View MrUnix's profile
MrUnix
6587 posts in 2164 days
#1 posted 02-18-2015 08:22 PM
Can’t really read the label, but it looks like it might be a 3 phase motor if that makes any difference to you.
View jakep_82's profile
jakep_82
105 posts in 2271 days
#2 posted 02-18-2015 08:24 PM
Unless you have 3 phase power, you’ll need to factor in some additional costs for a phase converter.
View jkinoh's profile
jkinoh
95 posts in 1862 days
#3 posted 02-18-2015 08:35 PM
Why do school shops always feel they have to paint everything that comes in!!?
Did you hear it run and check bearings? Sounds like you’ll probably be looking at a motor, unless you happen to have 3-ph where it will end up. Maybe you already have one to put on it? I’m assuming you are buying from someone that bought it from the school. I’d try to barter a little more.
Also, are the knives in good shape, enough to grind, or will you need to replace?
-- Why buy it for $300 when you can make it for $500!!
Rivercitykenb
#4 posted 02-18-2015 08:39 PM
Havent even called the guy, just wanted to throw it on here and get some advice from people that have a clue what they are looking at… because that might as well be a potato to me.
Rivercitykenb
#5 posted 02-18-2015 08:41 PM
Yeah, I dont have 3 phase in the garage. So that pretty much elimates that. I will keep hunting. Thanks for the help.
MrUnix
#6 posted 02-18-2015 09:05 PM
If you have 220V available where the thing will be used, add another $200 +/- to the price for a VFD. If going that route, it will add several features you won’t get on a single phase machine (soft start, electronic breaking, variable speed, overload protection, etc…). Probably not really needed on a jointer, but something to keep in mind. You can usually find three phase machines much cheaper than their single phase equivalents.
jkinoh
#7 posted 02-19-2015 05:40 PM
You could also make a 3ph converter pretty easy. I used to see 3ph motors around all the time. Had many opportunities to get them for nothing. When I went to build a phase converter, couldn’t find any! Ended up buying one cheap, but needed bearings. I run a 2hp Bridgeport Vertical Mill with it. Also have a big tanker Walker-Turner drill press that’s 3ph. Bought a VSD for it on eBay. Those features MrUnix mentioned are really nice on a drill press. If you can locate a decent size 3ph motor (rule of thumb is to get 2-times the hp of the machine you plan to use it for), it’s easy to make a converter, and probably cheaper than replacing with single-phase. I’d much prefer 3-phase on all tools, but unfortunately that’s not really an option for most of us.
jkinoh
#8 posted 02-19-2015 10:31 PM
Correction to the previous post….VFD (Variable Frequency Drive) not VSD. Dang fat fingers.
View Deano56's profile
Deano56
91 posts in 1158 days
#9 posted 02-20-2015 01:50 AM
Too much money for a three phase jointer, 400 would my limit. I see plenty of 8” good older USA made jointers for that price with a plug and play single phase motor
-- Deano
MrUnix
#10 posted 02-20-2015 02:36 AM
Not around my neck of the woods!
Rivercitykenb
#11 posted 02-20-2015 05:22 AM
The best jointer I have seen on my local CL is a $400 6” rigid. not bad, i mean it looks like a decent jointer. Then there is a powermatic model 60 for $1300 (out of my price range)
