A SAFETY ITEM: I recently purchased this GRR-Ripper system
Forum topic by Dick, & Barb Cain posted 470 days ago 1210 views 1 time favorited 27 replies Add to Favorites
Dick, & Barb Cain
5372 posts in 827 days
470 days ago
Topic tags/keywords: safety grr-ripper tablesaw dick
After reading about Haugnutz bad ordeal with his saw, I thought I’d show you my latest purchase.
It’s a GRR-Ripper to replace a push stick.
There’s a video demo of this tool on this site.
I haven’t had a chance to use it yet, but it’ been on my list for a long time now.
2894 posts in 507 days
470 days ago
Hi Dick;
Anything to keep your fingers where they belong is a wise investment.
Have fun with it.
View Bob Babcock's profile
Bob Babcock
1807 posts in 614 days
470 days ago
Looks like a good buy. I like my fingers.
View Mike Lingenfelter's profile
Mike Lingenfelter
403 posts in 642 days
470 days ago
I picked one of these up a few months ago, and I really like it! You have to spend a little time adjusting it before you use it, but it goes quick. I think it is time well spent. For the foot rest I just built, I used the GRR-Ripper to cut 1/4” x 1/4” pieces of maple that I turned into dowels. I would never have tried that with regular push sticks!
-- http://theinquisitivewoodworker.com/
2055 posts in 549 days
470 days ago
I keep looking and not getting.
It may be the right time to change that.
I spend too much time getting the saw stable for my cut and I can see this gizmo saving me some shop time.
Thanks for the heads up Dick.
View niki's profile
niki
386 posts in 608 days
470 days ago
Hi Dick
Sorry to be negative about the Grrriper…it’s just me
If you would post it on a UK forum, you would get a bunch of negative replies…it’s against the EU safety regulations to work without a blade guard.
I made one some 1 year ago and posted it on the UK forum before even trying it, and…if I got it…
I was sure that it’s very safe but when I actually worked with it…well, I was lucky that I was wearing my brown pants….
When my hand was over the exposed blade, I got terrified (and many scenarios past through my mind) and I could not continue…I just hit the “STOP” and never used it again…
niki
View PanamaJack's profile
PanamaJack
4452 posts in 605 days
470 days ago
After Hawg…I ordered one just now! Thanks for the heads up, once again, Dick!
-- Carpe Lignum - Seize The Wood,
View GaryK's profile
GaryK
8541 posts in 516 days
470 days ago
Niki – I can’t see how you guys in the EU can get anything done. Some of your safety regulations go way overboard. I like your solution though. It’s better than paying $50.
Dick – That guy in the video sure saw biased toward the Gripper. He left out the splitter and always pushed at the back right corner to make sure it rotated. All you need to do was to put a non-skid stick on rubber
pad to prevent the material from moving away from the fence.
I’m not saying that the gripper not safer, it looks like it is in some cases. I hope that it keeps your fingers where they belong!
470 days ago
Nick.
I’m curious.
How do you folks run dados with a blade guard in place?
I have to think you must perhaps use a router for this procedure?
I am also wondering how you would go about cutting thin slices from stock unless you devised a jig to cut from the outside of the stock instead of the fence side. ( But then would that not defeat the blade guard again?)
View niki's profile
niki
470 days ago
Thank you GaryK
First, I did not say that I’m “safety angel” but, I’m an amateur and the regulations do not apply to me.
The registered businesses must obey the law and must buy the “correct machine for the correct job”...
But look at the bright side…because of those safety laws, the Table saws manufacturers must provide a Riving knife, a quick install/remove guard with dust port, the blade must stop within 10 seconds and surrounded with a shield and dust port (dust control regulation).
Most of the Table saws (including mine) are coming with short arbor so dado blade cannot be installed.
Some Table saws has a long arbor and they use the dado blade with overhead guard and that’s acceptable.
As you said, I’m cutting dados with the router…
Regards
niki
Dick, & Barb Cain
470 days ago
It looks like we have a little debate going here. I think it’s good thing to discuss things.
I was going to make a copy of the Gripper, but I figured in order to do a good job, it would waste a lot of my time.
Now I can spend my time to produce something.
View Hawgnutz's profile
Hawgnutz
505 posts in 604 days
470 days ago
On my accident, I was cutting dadoes with a 15 degree slant to tilt the dominoes. I have done it dozens of yimes before, but te repetitiveness got my lacksadasical. Coul dnot have used a roouter. (would have been my chpice for this)
Let me know if eth gripper is all that it is cracked up to be. Making boxes, it sure would be easier to use to make 1/4” or 3/8” sthick stock.
God Bless,
Hawg
(finger is doing fine!)
-- Saving barnwood from the scrapyards
470 days ago
Dick:
a peace oiffering!
Last thing I want here is confrontation/debate.
What’s to learn if we don’t discuss?
View Don's profile
Don
2586 posts in 705 days
470 days ago
I’ve been using the Grr-Ripper for four years; I have two of them. When cutting pieces for small boxes, they are invaluable. It allows one to control small pieces of wood with hands and fingers well away from the blade. I can’t imagine how else I could make some of the cuts I do with complete safety.
It would be interesting to learn just how many home woodworkers in Europe and other parts of the world actually keep their blade guards on the saw. I persisted for a few years trying to do so, but quite frankly, ofet found I was pushing the limits of safety trying to work with the cumbersome guard.
-- CanuckDon "I just love small wooden boxes!" http://www.canterburybaptist.org/
View niki's profile
niki
470 days ago
Hi Dick
There is no debate…so far, I’m the only one that does not feel safe with the Grriper…
I think that safe or unsafe is a personal feeling and everybody is free to choose…
Please have a look at the picture below…I think that many will tell me that it’s unsafe but, I feel very comfortable and safe with it (for the last 11 years)...personal feeling…
Don
I don’t have any idea how many home woodworkers in Europe keeps the guard “ON” but if you noticed, on most of my posts the guard is installed and till today I did not have any problem cutting even small pieces using push shoes, and for crosscut, hold downs or clamps, usually with a sled.
Best regards
niki
Dick, & Barb Cain
470 days ago
Niki,
Thanks for your input, but I don’t think I’d ever use my hand held saw without the guard. Mine has a lever, if you want the guard out of the way temporarily.
Hand held power equipment can be very dangerous. A guy that worked for me removed the guard on a right angle grinder, because he thought it was a nuisance. One of the other guys was using it , & the wheel caught on his coveralls, & almost ripped them off of him. Luckily he didn’t get hurt.
Bob: What great price for the grripper.
Don: You upped my confidence, that I made a good purchase.
View niki's profile
niki
469 days ago
Hi Dick
That’s exactly what I meant by “safety is a matter of personal feeling”...It’s ok for you to work without guard on the table saw but big “no, no” for the circular saw…I feel the opposite.
The saw on the picture has an electric brake and stops in less than a second once I release the switch.
There is another EU safety regulation that states “the blade must stop within 10 seconds” that was made after the accidents survey shown that many accidents happened during the “run down” of the blade (from 2008 the regulation will be mandatory for all the power machines).
Regards
niki
Dick, & Barb Cain
469 days ago
Hi Niki,
I’ve had my old Wards Powercraft saw for over 40 years now. I’ve gone through 2 sets of bearing, & brushes, so you can see that I’ve used it quite a bit. I don’t think I’ll be parting from it, but if I were to buy a new saw, I’d buy one with the brake like Niki recommends.
This is excellent advice for all of you Newbies.
View cajunpen's profile
cajunpen
5345 posts in 594 days
469 days ago
Dick, I’ve had the Grrrriper for a couple of years and use it almost every time I’m ripping anything narrow. I used it today to rip some 1/4” pieces – it’s handy as pockets on a shirt, and whether it makes things safe or not – I feel safer. I also have a zero clearance plate on my TS and use it 99% of the time – I have one of those little Green Splitter blades (Can’t recall their name) installed and leave it in place when I use the
Grrrriper – no problems. You have made a great addition to your shop.
View Don Niermann  's profile
Don Niermann
138 posts in 500 days
468 days ago
I have used the gripper ripper for about 3 years and think it is one of the most inovate and usefill tools intro0duced for a long time. There is no way to cut strips and do router tasks as msafe as using this jig. I cannot agree with the negative comments with this jig. It is a fantastic piece of equipment. I got rid of most of my push tools ounce I learned how to use it.
-- WOOD/DON (...one has the right to ones opinion but not the right to ones own facts...)
View SteveM's profile
SteveM
58 posts in 695 days
468 days ago
I love my Gripper for both the added safety and the better efficiency of cuts. Costs a bit but lots less than prosthetic fingers.
Dick, & Barb Cain
468 days ago
I first seen the Grripper on the woodworking channel about a year ago. I figured it was about time I got one.
Safety should always be first, it’s so easy to procrastinate.
467 days ago
Just to bring this discussion up to date, I find that Micro-Jig” is comming out with a new Grrr-ripper .
That is why the old one is being discounted at some outlets.
It seems a shame that the purchasers of the first one were not given some sort of upgrade path or at least acknowledgment of their support.
I don’t completely understand what the advantages are with the new on yet.
Apparently you can piggy back two together now- Oh Joy! a $150.00 jig on top of a $75.00 old style jig.
Not a good move from a marketing perspective.
That will definitely invite Competition.
Dick, & Barb Cain
467 days ago
I bought an extra when I bought mine from Woodcraft. It may be the upgrade. You can change the angle of the handle, raises it a little higher, & also a stop block for jointer. It’s part B.
View WayneC's profile
WayneC
5684 posts in 625 days
467 days ago
It looks like it is a new handle and is listed at $12.95?
435 days ago
I have to jump in here.
As you can imagine, I buy pretty much whatever I felt neccessary to make my shop safe. I also bought many gimmicks, that seemed to be a good idea at the time. (sometimes I’ll buy something simply because the store had nothing else that caught my eye, or I didn’t already have one or two of them.
That being said, and realizing I’m a compulsive buyer, I havent bought one of these.
And I am a safety NUT! I generally use different thicknesses of MDF push sticks. These sticks are aywhere from 12 – 20 inches long, and ard made in 1/8”, 1/4”. 3/8”, and so on to 3/4” The shape of it is like a sports car in the front, and a vertical section in the rear which looks like an inverted pistol handle. This handle is shaped so when you push forward, you are also pushing down. The underside is cut to a straight edge, roght up until the center of the handles center point of balance between the downward pressure, and the forward pressure.That ends up being toward the front of the handle section, whigh is shaped to comfortably provide for a firm hand Grip. The remanider of the bottom is stepped up about an 1/8” less than the thickness of the piece being cut. All edges are routed to provide a comfortable grasp, except the bottom edges. The handle area is about 4 1/2” higher than the workpiece, so I feel my hands are safe. A zero clearence blsde insert is also a good idea’
I find these to be very quick to produce, sacfraficial, meaning I regulary cut them too in the course of cutting
something.
My thinking is they are easy to make, cost next to nothing, as we use scraps, are riding on our rip fence, so there always handy, and they perform quite well.
Smoetines I’ll cut the bottom edge on an angel, which helps to hold it in as well.
Beyond these push pistols, I am very secure in protecting my mathamatical abilities with them , and don’tfeel the need to go further with it.
I also use the same concept in using a large board on a jointer. The only real difference here is the handle is facing the rear of the push block, so I can pull it down to the table, and in to the cutter, simultainousy.
I reall feel no need to add anoither product to set up and learn. Don’t forget, I’m getting old. and set in my ways.
View Sawdust2's profile
Sawdust2
868 posts in 616 days
433 days ago
Boy.
IMHO one of the best discourses on this site.
Hawgnutz
433 days ago
Well. after my accident I value my fingers all the more! I bought the MJ splitter, which is the removable splitter for use with the Grr-ripper, which I am ordering from Rockler. $15.00 for the splitter, and $40.00 for the Grr-ripper is a cheap payment to protect my hands and fingers when I make those small strips for boxes!
I will keep you informed as to my findings on them!
God Bless,
Hawg
Bookmark And Share This Page
