How to mark a compound miter
Forum topic by RobH posted 1478 days ago 587 views 0 times favorited 3 replies Add to Favorites Watch
View RobH's profile
RobH
465 posts in 2221 days
1478 days ago
Hey all,
I have finally put up the swing bar on the boys’ playground in the back yard, and I want to put in a couple of braces between the 4×6 beam and the 4×4 supports. I plan on laying the support board flat on the 4×4 support and running it at an angle up to the 4×6 beam. This, of course, will result in a compound angle at the beam. Since I am not sure of the angles the supports make with the beam or the angle at which I will be sloping the support up to the beam, I cannot mathematically figure out the compound angle. Does anyone know how to mark out the compound miter one the swing set? If I can figure this out I will mark it out and then cut to the layout lines.
Thanks again for the help,
Rob
-- -- Rob Hix, King George, VA
3 replies so far
View sandhill's profile (online now)
sandhill
1978 posts in 2095 days
#1 posted 1478 days ago
Sounds like 22 degrees? Then 0 – ~ from the 90 degree verticals
87312 posts in 1749 days
#2 posted 1477 days ago
Hey Rob
I can’t figure out why you need a compound angle instead of just an angle on each end
TopamaxSurvivor
13194 posts in 1847 days
#3 posted 1477 days ago
If the brace can’t be marked as DaveR suggests, you could stretch a string along where one edge of the beam will be. Use a framing square to do your layout of the angles. Once you have one side of the square on the line, you read where it tounchs in inches and fractions. layout one angle, then the other and follow it around the beam. Repeat for the other end. Easier than it sounds :-))
