Anti-Kickback Safety Rollers and featherboards
Forum topic by Milo posted 05-07-2009 01:12 AM 6100 views 0 times favorited 11 replies Add to Favorites Watch
View Milo's profile
Milo
869 posts in 3313 days
05-07-2009 01:12 AM
Anyone ever use these? I’ve seen them once, and have been thinking about using them. However, I have yet to actually SEE these on a working tablesaw. Does anyone use these? Do you like them? Do the interfere with you push stick?
Also, has anyone used a featherboard on the outfeed table of a jointer? SEEMS like a good idea, but again, never actually seen it.
Thanks for the feedback!
Dell
-- Beer, Beer, Thank God for Beer. It's my way of keeping my mind fresh and clear...
11 replies so far
View lew's profile
lew
12052 posts in 3749 days
#1 posted 05-07-2009 01:30 AM
Feather boards on a saw, definitely. On a router table, sometimes depending on the size of the material and complexity of the cut. Never used one on a jointer.
View tenontim's profile
tenontim
2131 posts in 3738 days
#2 posted 05-07-2009 01:36 AM
I’m with Lew. I use feather boards on my table saw and router a lot. Never on a jointer. Never have used safety rollers.
27250 posts in 3816 days
#3 posted 05-07-2009 02:09 AM
Milo, you might want to take a look at these magnetic feather boards. They work well for table saw operations and, while I have used one on my jointer, it really is more of a novelty than anything else. You have to continually reset it while you are face jointing so I do not use it much.
View Milo's profile
Milo
#4 posted 05-07-2009 02:38 AM
Thanks gang,
I’ve been freaky ever since I had a couple kickback accidents, so I’m looking at all sorts of ideas.
The featherboard/jointer idea? I’m just crappy at using the dang thing. ;-) Thought I’d throw the idea on the wall and see if it stuck!
View marcb's profile
marcb
768 posts in 3667 days
#5 posted 05-07-2009 04:18 AM
You need to look at the saw thats kicking back and figure out why. While its good to have protection against it, most kickbacks mean something is off with the saw.
I’ve thought about the featherboard on a jointer myself. once of those magnetic ones might work, I always worry about my fingers edge jointing.
Great avatar
117086 posts in 3571 days
#6 posted 05-07-2009 04:22 AM
Magnetic feather boards are my choice
View catus's profile
catus
1 post in 3293 days
#7 posted 05-14-2009 09:22 AM
This is a wonderful opinion. The things mentioned are unanimous and needs to be appreciated by everyone
thanx
catus
Baby Furniture
View Kindlingmaker's profile
Kindlingmaker
2656 posts in 3520 days
#8 posted 05-14-2009 08:12 PM
featherboards ALWAYS, when I can use them.
View GaryK's profile
GaryK
10262 posts in 3982 days
#9 posted 05-14-2009 08:17 PM
I use rollers all the time on my tablesaw:
http://lumberjocks.com/GaryK/blog/1569
View JimmyNate's profile
JimmyNate
124 posts in 3344 days
#10 posted 05-14-2009 09:18 PM
How do you feed the last end of the board with those rollers on, GaryK? It looks like it’d cause problems with the push stick.
-- "We are what we repeatedly do; excellence then is not an act but a habit." ---Aristotle
GaryK
#11 posted 05-15-2009 07:39 AM
JimmyNate – CessnaPilotBarry
I usually only use them for wider or real long stock The distance they extend past the fence is adjustable. They are usually less than 2 inches out. It also depends on the thickness of your stock. If I have no room to use them I don’t. It only takes about 10 seconds to remove them.
My splitter is built into my zero clearance insert. You can’t see it because it’s in line with the blade.
You will find a better picture here: http://lumberjocks.com/topics/2303
In the first picture you can see my fence with the rollers removed.
