I need a source for 1/16" birch plywood
Forum topic by helluvawreck posted 02-17-2015 04:51 PM 7915 views 0 times favorited 15 replies Add to Favorites Watch
View helluvawreck's profile
helluvawreck
31417 posts in 2895 days
02-17-2015 04:51 PM
Topic tags/keywords: 116 birch plywood laser engraving
I have found a good wholesale source for 1/8” and 1/4” birch plywood where I can order 10 to 50 sheets at a reasonable price. The sheets are 5’ x 5’ and they will ship them to my shop by truck. However, when it comes to 1/16” birch plywood I am not running into too much luck. I think this plywood comes from Europe and it is nice stuff and does well with laser engraving.
Does anyone know of a good wholesale source for this?
helluvawreck aka Charles
15 replies so far
View DrDirt's profile
DrDirt
4424 posts in 3771 days
#1 posted 02-17-2015 05:20 PM
The only place i see plywood that thin is from the hobby shops e.g. for making Radio Control Airplanes.
They sell in small sheets, but obviously it got made as a large sheet somewhere, however if you are looking for small panels for engraving, Hobby Lobby and others will have those sizes.
Woodcraft sells it ut as 12X24 sheets for over 20 USD
http://www.woodcraft.com/Product/50W22/Birch-Plywood-116-x-12-x-24.aspx
National Balsa seems to have somwhat larger and much better price 3-ply
http://www.nationalbalsa.com/birch_plywood_s/138.htm
The thin ply i used for RC airplanes was always stickered from “Midwest Products”..... suppose that they cut the sheets down to retail sizes and stock all the hobby stores, so maybe they can supply larger?
anyone in aircraft interiors, may have a supplier…. got to be out there.
Sorry that is all i have.
EDIT
This looks interesting….
http://www.boulterplywood.com/MarinePlywood_4.htm
helluvawreck
#2 posted 02-17-2015 05:30 PM
I appreciate your input DrDirt but there must be a wholesale source for it because a lot of laser engravers use it in their products. Granted, it’s not as commonly used as the 1/4 and 1/8 sizes but it’s not a rare thing either. Unless I can find a wholesale place the price eliminates the possibility of using it. It’s cost is 5 times as much (or even more) as I can get the other for.
Thanks for the comment. Thanks.
View gwilki's profile
gwilki
203 posts in 1502 days
#3 posted 02-17-2015 06:21 PM
Searching on “1/16” plywood” yielded several result with various sheet sizes. I guess it depends on where you are and where the source is.
-- Grant Wilkinson, Ottawa ON
DrDirt
#4 posted 02-17-2015 07:10 PM
Maybe these guys?
their “FULL SHEETS” are 4X4 but it is indeed expensive @38 bucks
Maybe the price is driven by ease of damage/PITA factor shipping it around, versus a stiffer panel that is harder to screw up.
http://www.aircraftspruce.com/catalog/wppages/finnishbirch.php
View scrollingmom's profile
scrollingmom
1169 posts in 2493 days
#5 posted 02-17-2015 07:36 PM
I have never used 1/6” plywood but am interested in where you get your 1/8 and 1/4” for wholesale.
-- Kelly, Allen,KS
View daddywoofdawg's profile
daddywoofdawg
1028 posts in 1604 days
#6 posted 02-17-2015 08:15 PM
View Joe Lyddon's profile
Joe Lyddon
10123 posts in 4081 days
#7 posted 02-19-2015 12:01 AM
daddywoof…
Amazing… 1/16” ply = 3 plys… 1.333/64” or .0208” per ply
Those are very thin plys!!
I didn’t think they even made it that thin! Have never seen it…
Expensive stuff…
View AlaskaGuy's profile
AlaskaGuy
4217 posts in 2338 days
#8 posted 02-19-2015 12:04 PM
Don’t know if you can find it in the size you want but aircraft plywood comes 1/16 and even thinner.
So start searching for ” aircraft plywood”.
View Kaleb the Swede's profile
Kaleb the Swede
1835 posts in 1998 days
#9 posted 02-19-2015 12:18 PM
Do you have a Michaels store near you? They have 1/16 inch ply. I remember seeing it once when my wife was dragging me through there
-- Just trying to build something beautiful
View Dark_Lightning's profile
Dark_Lightning
3165 posts in 3138 days
#10 posted 05-25-2016 01:08 AM
I’ve been looking for 1/16” ply. This is one of the sites that turned up in my search. I’m annoyed enough with looking for something and getting Yelp and White Pages and Yellow Pages instead of the actual sources that I’m going to laminate up my own from some veneer that I got cheap at the Habitat for Humanity Restore instead.
-- Random Orbital Nailer
View clin's profile
clin
853 posts in 1025 days
#11 posted 05-25-2016 03:20 AM
AircraftSpruce.com
http://www.aircraftspruce.com/categories/building_materials/bm/menus/wp/plywood.html
They have it down to 1/64”, 3-ply.
About $40 for a 4×4 sheet of 1/16” of “Finnish Birch”
Not what I would call a wholesaler, but not Hobby Lobby either.
Edit:
Looks like maybe there are not wholesalers, but rather you buy direct from the manufacturer. Here’s a Finnish manufacturer:
http://www.koskisen.com/koskisen/plywood/
FYI, I know my local hardwood suppler gets their birch plywood via train then truck. So buying truly wholesale might require buying an awful lot of plywood.
-- Clin
View rougninit's profile
rougninit
14 posts in 631 days
#12 posted 10-06-2016 08:21 PM
just do an internet search for 1/16 plywood. Several companies come up
-- Jim, living in Texas
View robscastle's profile
robscastle
5109 posts in 2233 days
#13 posted 11-02-2016 10:09 AM
Pity you guys are not close by I could do you a really good LJ deal
a variety of sizes
As you can see 32×2120mm x 1220mm A shorter stack 23×1900mm approx x 900mm approx 3 and 4 mm in the middle
And then a second batch of 11×2120mm x 920mm 3 and 4 mm various sheets shorter.
Walnut veneer finish on some then othe really nice varieties all interior and all G1S Possibly AB.
Not a knot or defect anywhere on either side,
I have been trying to unload them for a while now!
-- Regards Rob
robscastle
#14 posted 11-03-2016 05:49 AM
Opps I just realised 1/16 is actually close to 1.5mm nothing that size in my area.
-- Regards Rob
Joe Lyddon
#15 posted 11-03-2016 06:32 AM
Robert, not to worry, they can resaw it… LOL (big grin)
