Tenon Jig Opinions
Forum topic by longgone posted 05-06-2009 06:50 PM 2922 views 1 time favorited 19 replies Add to Favorites Watch
View longgone's profile
longgone
5688 posts in 3309 days
05-06-2009 06:50 PM
I use to have a very old Delta tenoning jig that was a 1st. quality product made in the USA. Unfortunately it was destroyed in the flood. Now that I have my new shop built I am looking to get a new one but the quality of what I now see from the chinese delta product seems lacking.
There are a lot of tenon jigs available online but you cannot touch, feel or examine it as you would in a store. What are your opinions of what is available?
19 replies so far
View PurpLev's profile
PurpLev
8535 posts in 3649 days
#1 posted 05-06-2009 07:04 PM
what are the differences in quality that you see between your old one, and the newer ones?
117095 posts in 3577 days
#2 posted 05-06-2009 07:11 PM
I mostly see mortisers around ,What I use is a multi-router works slick, but spendy.
longgone
#3 posted 05-06-2009 07:17 PM
My older one was a beefier and heavier jig. I went to Lowes to look at the jig they had in stock but it was in a box and they wouldn’t open it, so I drove to a woodworking store about 30 miles from my house and they had a new delta assembled and on display. When I placed it on a display table saw I noticed that it had a slight wobble in it. I brought this to the attention of the store and we adjusted the miter bar. There was no slop in the bar but the base of the jig still had a slight wobble and did not have a good solid fit in the table saw top. No adjustments to correct this. We brought it over to a differrent table saw, a Powermatic, and it was the same. Then we tried it on a third saw, a SawStop cabinet saw, with the same results. Store owner and I agreed this was not good.
View Bill White's profile
Bill White
4932 posts in 3961 days
#4 posted 05-06-2009 07:40 PM
Try a Grizzley.
Bill
-- bill@magraphics.us
longgone
#5 posted 05-06-2009 08:38 PM
Hello Bill,
What is is about the grizzly that impresses you? Do you own one and how accurate is it?
View Chris Wright's profile
Chris Wright
540 posts in 3481 days
#6 posted 05-06-2009 09:21 PM
I’ve read good reviews on the Grizzly tenoning jig. Granted there’s not much to a tenoning jig to begin with so it’s pretty hard to get it wrong. This one at Rockler (http://www.rockler.com/product.cfm?page=10185&TabSelect=Reviews) has great reviews and it’s almost identical to the Delta I use in my shop. This one’s on sale (http://www.woodcraft.com/product.aspx?ProductID=144755&FamilyID=4847) and uses the same castings again as the one from Rockler and my Delta. I say bite the bullet and buy one, if you’re not satisfied send it back.
-- "At its best, life is completely unpredictable." - Christopher Walken
View FlWoodRat's profile
FlWoodRat
732 posts in 3909 days
#7 posted 05-06-2009 09:54 PM
Gregg,
I was too cheap to buy a tenoning jig, so I made my own. It’s safe, efficient and versatile. I also use it as a panel raising jig. It was made from scraps I had laying around the shop. You can check it out here at LJ’s at the following link.
http://lumberjocks.com/projects/13487
What you won’t see in the pics is the vertical sacrificial strip I use when cutting tenons or raised panels. I just screw it on from the backside of the jig above the blade height.
I’m sure you can do even better!
-- I love the smell of sawdust in the morning....
View Don K.'s profile
Don K.
1075 posts in 3327 days
#8 posted 05-07-2009 05:28 AM
Greg,
The one Grizzly sales is the same one Woodcraft sales as their store model if I’m not mistaken, just has different handles. I have one and it works great once you adjust it to your saw. It may not be as “Beefy” as your older delta, but for under $70 it is a darn good jig.
I have the woodcraft version and my friend has the Grizzly, other than the handles, you can not tell the difference, they are both even the same green.
-- Don S.E. OK
longgone
#9 posted 05-07-2009 06:29 AM
I just decided on and ordered the woodcraft jig. It was on sale for $65 and had only $5 shipping. Hope it does the job as the likelyhood of me finding another identical old Delta model is sllim at best.
Thanks for all the input.
Don K.
#10 posted 05-07-2009 06:41 AM
Well one thing about it Greg, when you get it…you put it together…every piece of it (at least mine was like that) So there was no trying to figure what what was wrong stuff. I put it together and matched it to my saw when I did…. has been a super little jig since then.
-- Don S.E. OK
TopamaxSurvivor
18271 posts in 3676 days
#11 posted 05-07-2009 08:50 AM
What is there to fit to the saw? Flat base with 3/4 rib is all there is to the fitting, isn’t it??
Don K.
#12 posted 05-07-2009 09:33 AM
True Topamax, but it will not be exactly square. Kind of like squaring your blade to your miter slots, it has a few adjustments to square it to the blade/miter slot.
-- Don S.E. OK
TopamaxSurvivor
#13 posted 05-07-2009 10:16 AM
Ok, I thought there might be more to eliminate that rocking on the table business. That must be a very poor machining job :-((
Don K.
#14 posted 05-07-2009 05:01 PM
Bob,
It could have been a poor machining job, or it could have been put together very poorly in the store. Every look at the tools put together at the local home improvement store ??? “Scary”...and then they charge for assemble, lol.
-- Don S.E. OK
View juniorjock's profile
juniorjock
1930 posts in 3766 days
#15 posted 05-08-2009 12:31 AM
My Grizzly jig was mostly assembled when I received it….... oh, wait…. I forgot, I had to take the damn thing apart and clean that nasty-ass grease off every piece of it. But, it worked well after it was cleaned up.
