How to make Mahogany figure 'Pop'
Forum topic by Ivan posted 05-06-2009 04:40 PM 3789 views 0 times favorited 7 replies Add to Favorites Watch
View Ivan 's profile
185 posts in 3308 days
05-06-2009 04:40 PM
Topic tags/keywords: question mahogany finishing arts and crafts
I’m building a trunk and was able to find some beautiful Mahogany with figure.
I wanted to know if anyone has a finishing method that would make the figure pop? After the initial milling I can see some great ribbon grain when I look at it from a raking light.
I know that Maple figure can be made to pop with dye, but I really like the natural look of sun darkened Mahogany and would prefer to not add a stain.
Any suggestions?
-- "Do it right the first time, you'll just kick yourself later..."
7 replies so far
View Julian's profile
880 posts in 3456 days
#1 posted 05-06-2009 05:15 PM
Mahogany gets that striping from being quartersawn. What I do to finish it, is to sand to 220, then use a few coats of amber shellac cut with DNA. Then use oooo steel wool with wax to rub it out, or use poly or laquer , then wax of it needs to be more durable.
-- Julian, Park Forest, IL
View Damian Penney's profile
Damian Penney
1141 posts in 3922 days
#2 posted 05-06-2009 05:34 PM
David Marks uses Potassium Dichromate which looks amazing.
These guys stock it
View marcb's profile
768 posts in 3604 days
#3 posted 05-06-2009 05:58 PM
A good oil based finish can really help figure and curl and other things stand out.
Waterlox is good for that.
never tried the potassium route.
#4 posted 05-06-2009 06:06 PM
I think I’ll try the Potassium Dichromate.
Thanks again,
View bibb's profile
327 posts in 3461 days
#5 posted 05-06-2009 06:21 PM
I have used Behlen’s pore filler dyed black with trans tint then sanded back down. Topped with 3-4 coats French polished amber shellac over with great success.
-- you may only live once, but if you do it right that's all you need
117029 posts in 3508 days
#6 posted 05-06-2009 06:23 PM
Check out how to make grain pop By Charles Neil on you tube.
-- wood crafting & classes
View Chris Wright's profile
Chris Wright
540 posts in 3412 days
#7 posted 05-06-2009 06:35 PM
One method that luthiers use to make figured maple stand out is to put a dark dye down first and work it into the grain, then sand it down so that all that’s left is what’s in the low, soft grains, then but a clear lacquer over it. I don’t know how that will work on mahogany, but you can try and experiment on some scraps you’ve got left over. Can’t wait to see how it turns out.
-- "At its best, life is completely unpredictable." - Christopher Walken
