Delta Air Cleaner • Fuse
Forum topic by Woodie04 posted 05-05-2009 11:22 PM 1039 views 0 times favorited 7 replies Add to Favorites Watch
View Woodie04's profile
Woodie04
4 posts in 3217 days
05-05-2009 11:22 PM
Howdy,
I am a newbie on this site, but there seems to be a lot of expertise out there. I have a Delta 50-875 air cleaner that has worked well for over a year. I recently took it down to remount it in a different location, and now it won’t turn on. Fuse problem maybe? My circuits are fine. Anybody know how to access / change the fuse on this air cleaner? Te Delta manual is of no help – it doesn’t even mention the fuse (5 amp).
Thanks
George (Woodie04)
PS: Looking forward to using this site a lot.
-- George (Papa) in B.C.
7 replies so far
View lew's profile
lew
11947 posts in 3664 days
#1 posted 05-05-2009 11:41 PM
How did you determine the fuse was 5 amps?
Don’t mean to sound like a smart A** but if you are using the remote is the line cord switch in the ON position and the remote batteries are OK?
Lew
Woodie04
#2 posted 05-06-2009 01:08 AM
Hi Lew,
The fuse cover says on it “5A”. I haven’t used the remote since day 1, and the line cord is in the ON position. Everything is exactly as it was when the cleaner worked – before I moved it.
George
View lew's profile
lew
#3 posted 05-06-2009 03:13 AM
I was looking at the on line manual and, like you said, it doesn’t even mention the fuse or list one in the parts breakdown.
Electronic devices usually have a black “plastic” tubular holder. The end of the holder has a red plastic insert with a screw driver slot that is unscrewed and reveals the fuse. Does this sound/look familiar?
View lew's profile
lew
#4 posted 05-06-2009 03:27 AM
Just found this:
http://lumberjocks.com/pjaromin/blog/3766
View lew's profile
lew
#5 posted 05-06-2009 03:33 AM
Almost looks like the black center either is a push to release or pulls directly out
Woodie04
#6 posted 05-06-2009 03:56 AM
Lew,
Thanks for tracking this – my unit has a square plastic holder. It looks like you could insert a screwdriver into it, but I am afraid to break it. I have tried to pop it out, lift it out, push to release, and pull it out. No go.
I saw the pjaromin blog earlier – that’s how I got to the Lumberjocks site.
116913 posts in 3486 days
#7 posted 05-06-2009 07:03 AM
I know you will work your way through it.
