| Forum topic by Thos. Angle | posted 430 days ago | 412 views | 0 times favorited | 21 replies | ![]() |
430 days ago |
Topic tags/keywords: tools fan paint booth I’m looking to build a portable paint booth for the shop. I’m having trouble finding the right fan. I like to spray laquer and it is a bomb waiting to happen. I’ve found some companies which make fans but they all seem too big and way too expensive. I saw an article on a small booth which had a small fan but can’t rember where I saw it. Help me out here, boys and girls.( almost forgot the girls!!!) -- Thos. Angle, Owyhee Design, Oregon |
430 days ago |
I searched “dresdner spray booth fan” – recalling that Michael Dresdner was an expert in the finishing area… edit: Sorry – looking at this again, it’s not gonna help much! Tells you what you already know! That you need a special fan! -- Dorje (pronounced "door-jay"), Seattle, WA |
430 days ago |
Was the article on a booth with a small fan that was for spraying flammables? I’m probably doing more harm than good here! Just curoius if you’re looking for the plans for a standard small spray booth in addition to the fan??? -- Dorje (pronounced "door-jay"), Seattle, WA |
430 days ago |
Explosion proof motors are expensive, nature of the beast. I’m not sure you’ll find an inexpensive one unless you find it second hand. -- Bob, Carver Massachusetts, Sawdust Maker http://www.capecodbaychallenge.org |
430 days ago |
Dorje, I pretty well know how I’m going to build the booth. I’m just looking for a source for the fan. -- Thos. Angle, Owyhee Design, Oregon |
430 days ago |
Hi Tom; When I first read your question, I immeadiately began engineering something in my head. Character flaw I guess. I would suggest, based on not knowing any of the details you are planning, you could come up with a squirrel cage, as found in a home heating system, with the motor mounted outside the vent system. with only the shaft penetrating the duct, and a very good seal at that point, it seems the motor could mounted outside the danger zone. I am not an engineer, and I am not recommending anything here. Just giving you some ideas. Lee -- by Lee A. Jesberger http://www.prowoodworkingtips.com http://www.ezee-feed.com |
430 days ago |
Lee, -- Thos. Angle, Owyhee Design, Oregon |
430 days ago |
I’ve got an old stovetop exhaust fan. -- No piece is cut too short. It was meant for a smaller project. |
429 days ago |
Sorry to have stepped in here at all! Rookie mistake! -- Dorje (pronounced "door-jay"), Seattle, WA |
429 days ago |
Or save the money on the fan and go waterborne. I switched over to Ultima spray lacquer after several years spraying M.C. Campbell Magnalac, in my home garage environment (probably I’m not truly rated to spray this solvent lacquer in a suburban shop environment, anyway). Tough stuff rated by the KCMA (kitchen cabinet makers association), burns in to the next coat, pre-cat lacquer and varnishes available. They have amber tinted finishes available that mimic nitrocellulose lacquers, and for maple etc. they have water-white finishes that do not yellow over time. I don’t miss the off-gassing while cureing, the stink, the concern that I’m building a fuel-air bomb – any of that and I don’t feel that I am not getting a superior finish as a trade off. Still can throw on several coats in a day, dry out of dust in a half-hour, powders without loading sandpaper too fast. I’ve had no fisheye problems, easy gun cleaning. Great stuff. Jeff Jewitt's Homestead finishes also has a great selection. -- "Bordnerizing" perfectly good lumber for over a decade. |
429 days ago |
Doug, that might be a good solution. In the past I’ve not been happy with the waterbase except for clean up and lack of bad smell. I’ve been happiest with nitro and poly but I do spray a lot of shellac. I’ve never tried to spray poly because I’ve been told it is a mess. I saved the web sites you listed and will study them later. Thanks for the suggestion and don’t be surprised if I pick your brain on these. -- Thos. Angle, Owyhee Design, Oregon |
429 days ago |
Dorje, you just step in anytime you feel like it your opinion is highly valued. -- Thos. Angle, Owyhee Design, Oregon |
429 days ago |
I agree with Thos. Angle—every comment is valuable! If it is incorrect information it starts a discussion that provides the right information; if it is a beginner question, the beginners such as myself will benefit from it. -- "Functional WoodArt" by Debbie, Canada (http://www.execulink.com/~yohan) |
429 days ago |
Hers’s something I found on FWW. -- -** You are never to old to set another goal or to dream a new dream ****************** Dick, & Barb Cain, Hibbing, MN. http://www.woodcarvingillustrated.com/gallery/member.php?uid=3627&protype=1 |
429 days ago |
This company Digikey sells a variety of fans, & there prices are reasonable. You can chat online with them if you have questions. I replaced some fans in my compost toilet last year, & saved a bundle. They have one size 850 CFM for about $104.00, These are similar to fans used for cooling electronic equipment, so they may be explosion proof. You’d have to ask them. -- -** You are never to old to set another goal or to dream a new dream ****************** Dick, & Barb Cain, Hibbing, MN. http://www.woodcarvingillustrated.com/gallery/member.php?uid=3627&protype=1 |
429 days ago |
Thanks Dick, the FWW link just asked me to sign in but I added the other to my list to look at later today. I subscribe to FWW but don’t know if I hav access to the archives. -- Thos. Angle, Owyhee Design, Oregon |
429 days ago |
Dick, Thos. You have to pay the subscription to FWW.com to get this comment. Thos, My “Good Neighbor Tom” box I posted in my projects was finished with the Ultima Spray Lacquer. Rubs out like a dream. -- "Bordnerizing" perfectly good lumber for over a decade. |
428 days ago |
Free Fine woodworking trial, check it out -- -** You are never to old to set another goal or to dream a new dream ****************** Dick, & Barb Cain, Hibbing, MN. http://www.woodcarvingillustrated.com/gallery/member.php?uid=3627&protype=1 |
428 days ago |
Thanks Dick -- Thos. Angle, Owyhee Design, Oregon |
428 days ago |
Grainger.com has fans of the right size for a small booth. I looked at them, before someone gave me a little spray booth with an exp. proof fan. Nothing is inexpensive though in this area. I’ve sprayed all day with my little booth with the woodstove stoked on the other side of the shop to keep the make up air warm (winter time). -- Mark DeCou - Kansas Flint Hill's Artisan |
428 days ago |
I’ll check it out, Mark. -- Thos. Angle, Owyhee Design, Oregon |
428 days ago |
The lowest I’ve seen in Graingers for a tube axial fan with an external drive is $1000. Here is a hazardous location motor. Mount a fan blade and make your own. http://www.grainger.com/Grainger/items/6K734 -- Bob, Carver Massachusetts, Sawdust Maker http://www.capecodbaychallenge.org |
| Sponsor | Forum | Topics |
Woodworking Skill Share
1228 |
1660 |
120 |
336 |
103 |
Woodworking Trade & Swap
233 |
Coffee Lounge
928 |
LumberJocks.com Site Feedback
269 |
