Cottonwood and varnish
Forum topic by TZH posted 02-16-2015 05:36 PM 3142 views 1 time favorited 22 replies Add to Favorites Watch
View TZH's profile
TZH
553 posts in 3167 days
02-16-2015 05:36 PM
Topic tags/keywords: question cottonwood hand sanding finishing sanding varnish mineral spirits cottonwood fuzz
This coffee table for our daughter has been a long time in the works:
I’ve had a lot of starts, stops, and do-overs, but it was finally starting to come together when I ran into one last problem (hopefully).
As you can see in the photo below, on either side of the epoxy inlay, there are strips of what appear to be areas that either aren’t accepting the varnish (they accepted the penetrating stain just fine) or there’s something else going on. And, that’s where you, my fellow LJ’ers come in. Help, please!
The wood is cottonwood. The stain is dark oak oil based penetrating stain. The varnish I’ve been using is hand rubbed Minwax. One coat of stain, and what you see in the photo above is actually the third coat of Minwax varnish.
In between coats, I did the requisite fine sanding with synthetic 0000 steel wool (dry). The last time before applying the third coat, I sanded using mineral spirits in the synthetic steel wool, wiped up excess, and let it thoroughly dry before applying another coat of varnish.
Those strips of fuzzy were there before the mineral spirits sanding, but I thought they’d disappear with more coats of varnish——- NOT!
The rest of the table top is coming along better than I expected, but those two strips are really perplexing me.
My thought was to let everything cure overnight, go at it again tomorrow with the mineral spirits sanding, dry thoroughly, and then apply multiple coats of water based varnish over everything.
Any ideas, suggestions, recommendations? This one has me stumped!
Thanks.
-- Where The Spirit In Wood Lives On
22 replies so far
View Gene Howe's profile
Gene Howe
10542 posts in 3456 days
#1 posted 02-16-2015 06:03 PM
Just a guess here, as I’ve only worked a few projects with cottonwood.
It appears that you may have “burnished” the wood when you were leveling the epoxy inlay.
If that’s the case, I’m not sure what you can do short of re sanding and re finishing.
Sorry!
View TZH's profile
TZH
#2 posted 02-16-2015 06:22 PM
Gene, that’s definitely a possibility to consider. Question – doesn’t “burnishing” result in almost a glassy smooth effect on the wood? This is kind of fuzzy, and the stain was accepted just fine. That’s why I’m really puzzled by this. Do you think sanding a little bit in those areas and putting a light coat of dewaxed shellac on them might help?
Thanks.
TZH
TheWoodenOyster
1317 posts in 1962 days
#3 posted 02-16-2015 06:41 PM
TZH – That’s bizarre. I was going to say that I thought you sealed up the pores close to the epoxy strip with epoxy overrun, but it seems like the stain wouldn’t have worked and the poly would have if that was the case. Seems like the pores still must be open if it is accepting stain.
Did your sanding pattern change in that area where the strips are? Did you sand the epoxy portion separately from the wood?
My advice would be to keep on adding coats of poly. Especially when you hand rub them, they are going to be super thin. I have had to put 8 coats of wipe on poly onto wood before to get the sheen and feel equal throughout the piece.
One last thought… Did you tape off the boundaries of the epoxy strip before you poured it? If so, it would stand to reason that the tape might have raised the grain, or somehow reacted with the wood in the exact areas where you are getting the weird fuzziness.
Good Luck
-- The Wood Is Your Oyster
View DocSavage45's profile
DocSavage45
8601 posts in 2870 days
#4 posted 02-16-2015 06:51 PM
Some thoughts,
Cottonwood to my understanding is a stringy wood. I’m wondering if you sealed the wood before staining? There may be a difference in the density causing the current issues?
Great looking table!
-- Cau Haus Designs, Thomas J. Tieffenbacher
View TZH's profile
TZH
#5 posted 02-16-2015 06:53 PM
TheWoodenOyster, thanks. You’ve raised some very interesting questions here. I agree about the first part on the stain and varnish, and that’s really the part that’s puzzling me the most.
The sanding pattern didn’t change – I used a random orbital sander for the entire top, although the epoxy run onto the wood did happen. I did tape off the boundaries and the tape could have raised the grain, but I thought I’d taken care of that issue when I did my final sanding prior to applying the stain, itself. The tape I used may, in fact, have been the wrong kind – packing tape. I’d used it on another project and it seemed to adhere better when subjected to the epoxy.
Have you ever applied water based varnish over oil based varnish? if so, how did that go for you? I’m thinking because the water based is a little thicker, it might seal up the pores in that area better than the Minwax.
Thanks, again.
TZH
View bobasaurus's profile
bobasaurus
3486 posts in 3211 days
#6 posted 02-16-2015 06:55 PM
Sorry to say, but you’d probably have to sand off the existing finish to get rid of it. Maybe some epoxy wicked into the cottonwood pores and just needs more sanding in that area. I would start with a sealer coat of dewaxed shellac, maybe tinted to match the coloring you want. Then any finish you want on top. That should make the topcoat absorption more even.
-- Allen, Colorado (Instagram @bobasaurus_woodworking)
View TZH's profile
TZH
#7 posted 02-16-2015 06:58 PM
DocSavage45, no I didn’t seal the wood because I wanted maximum penetration for the stain. I’d already used Watco Danish Oil Natural on it and had to strip it all away when my daughter said it wasn’t dark enough. By that time, the Watco wouldn’t allow anything else to penetrate and darken the color any more. So, I sanded it all down to bare wood again, and applied the dark oak stain over that bare wood. It was just the right color, so I started with the varnish after that. I think the areas affected in the photo are too “uniform” to be an inconsistency in the wood – at least as far as I can tell.
Thanks,
TZH
View JayT's profile
JayT
5679 posts in 2238 days
#8 posted 02-16-2015 06:59 PM
The tape I used may, in fact, have been the wrong kind – packing tape. I d used it on another project and it seemed to adhere better when subjected to the epoxy.
- TZH
I’m wondering if this is part of the issue from the way those strips are oriented. Could some adhesive residue from the packing tape be what is causing the problem?
View TZH's profile
TZH
#9 posted 02-16-2015 07:01 PM
Sorry to say, but you d probably have to sand off the existing finish to get rid of it. Maybe some epoxy wicked into the cottonwood pores and just needs more sanding in that area. I would start with a sealer coat of dewaxed shellac, maybe tinted to match the coloring you want. Then any finish you want on top. That should make the topcoat absorption more even.
- bobasaurus
How would you recommend tinting the shellac?
View Tennessee's profile
Tennessee
2873 posts in 2542 days
#10 posted 02-16-2015 07:08 PM
How deep is the epoxy inlay? I’ve seen epoxy take up to a month to fully cure. Up to that point, it may still be gassing off as it cures. I also would agree that some of it probably did wick into the surrounding wood, and it may also be curing, causing the top varnish to matte as it gasses through the varnish.
bobasaurus
#11 posted 02-16-2015 07:10 PM
You can tint shellac with dyes (like transtint).
View TZH's profile
TZH
#12 posted 02-16-2015 07:14 PM
- TZH
I m wondering if this is part of the issue from the way those strips are oriented. Could some adhesive residue from the packing tape be what is causing the problem?
- JayT
It’s beginning to look that way from the feedback I’ve been getting – may just have to bite the bullet and start over———again.
TZH
View TZH's profile
TZH
#13 posted 02-16-2015 07:16 PM
How deep is the epoxy inlay? I ve seen epoxy take up to a month to fully cure. Up to that point, it may still be gassing off as it cures. I also would agree that some of it probably did wick into the surrounding wood, and it may also be curing, causing the top varnish to matte as it gasses through the varnish.
- Tennessee
The inlay is about 1/2 inch deep with embedded tiles.
TZH
View TZH's profile
TZH
#14 posted 02-16-2015 07:44 PM
Thanks to EVERYONE for your feedback, ideas, suggestions, recommendations. This is just one of the many reasons why this website is so beautiful – the people in it! All I can say is WOW!
TZH
View TZH's profile
TZH
#15 posted 02-16-2015 10:50 PM
Well, for those who’d like to know, I wound up having to strip everything down to bare wood on the top of the table. Started out hand sanding the affected areas with 400 grit:
Not taking it down at all. Switched to 200 grit:
Not taking it down at all. Switched to 60 grit:
That seemed to work pretty well, but the results left the rest of the tabletop in need of similar sanding. So, got out the trusty old belt sander and took the rest of the finish off – pretty quickly, I might add:
Random orbital sanding to take out the scratches made by the belt sander, and I’m done for the day. Shoulders ache, mind says keep going, but body says NOT!
Seems, too, like when one problem is solved (at least eyeballing it tells me it is), another one rears its ugly head. Now, because the problem area I removed was so deeply embedded in the wood, the epoxy is sitting a little proud of the rest of the top. Anyone have ideas, suggestions, recommendations on how to take it down to level?
Again, thanks to everyone for all the help. In my case, I guess I just can’t fix stupid (my own)!
TZH
