Delta 52-858 joiner info.
Forum topic by alittleoff posted 02-16-2015 04:48 PM 5630 views 0 times favorited 6 replies Add to Favorites Watch
View alittleoff's profile
alittleoff
539 posts in 1240 days
02-16-2015 04:48 PM
I found a delta 52-858 jointer for sale for 400.00 with a new set of blades and it’s on a Mobil base. The machine looks new and in good shape. Question is is it worth it, when was it made and can you get parts for it easily. I looked around on the Web and didn’t find much info on it at all. I was holding out for an 8 inch planer but thought if this was a deal I could use it until I got an 8 and then resale it. Thanks in advance for any help.
Gerald.
View MrUnix's profile
MrUnix
6586 posts in 2162 days
#1 posted 02-16-2015 05:22 PM
Delta lists the 52-858 as an enclosed base for a jointer, not a jointer itself.. although it does appear to be made for a specific model jointer which they do not list. Might be why you can’t find much info. Most Delta 6” jointers have a model number that starts with 37-XXX, so that is what you need to look for. A picture or two might help further identify what model it actually is.
alittleoff
#2 posted 02-16-2015 06:01 PM
Here’s a picture if I did it right.
Gerald
View TheFridge's profile
TheFridge
9249 posts in 1450 days
#3 posted 02-16-2015 06:08 PM
It’s ok. Not a great deal but you didn’t get reamed either.
View levan's profile
levan
472 posts in 2943 days
#4 posted 02-16-2015 06:56 PM
Looks like you got a fair deal. Most of the time it depends where your located. Its all supply and demand.
I’m sure all parts are readily available. A 6” will probably fill most needs for sometime.
best wishes
Lynn
http://atlanta.craigslist.org/eat/tld/4848256241.html
http://www.ereplacementparts.com/delta-52858-type-stand-parts-c-3275_13799_13802.html
-- "If you think you can do a thing or think you can't do a thing, you're right". Henry Ford
alittleoff
#5 posted 02-16-2015 09:04 PM
I haven’t bought it yet. I wanted to get an idea about how good they were and being able to get parts for it. If I can get parts I’ll probably buy it from what I see. I might be able to get it a little cheaper. Anyway thanks.
Gerald
MrUnix
#6 posted 02-16-2015 09:39 PM
After a little more digging, it appears that is actually a Delta model 37-195 jointer on the 52-858 enclosed base. Has a 1HP motor and rack and pinion fence. It sold for about $520 (MSRP?) brand new back in 2005 and were discounted to $400 or less as they were being discontinued. Parts should not be a problem as usually you just need bearings, belts and knives which are the normal off the shelf maintenance items and can be found pretty much anywhere.
