Have home kiln with dehumidifier...drying question.
Forum topic by Liveedgewoodtables posted 02-16-2015 04:22 PM 1308 views 0 times favorited 4 replies Add to Favorites Watch
View Liveedgewoodtables's profile
Liveedgewoodtables
8 posts in 1177 days
02-16-2015 04:22 PM
Topic tags/keywords: drying lumber kiln home homemade dehumidifier rh relative humidity insulated box walnut slabs 2 inch 2
I dry 2 inch thick walnut live edge slabs. I drilled two small holes in the middle of my board (to get penetration into the wood with my pin type moisture meter). The middle of my board reads 12%...the outer edge reads 5%.
The dehumidifier has RH range is 30% – 85%. The dehumidifier is not taking out anymore moisture – the outlet hose is completely dry.
Have I dried the wood all I can with this dehumidifier? Do I buy another dehumidifier the can maintain RH below 30%?
My kiln is 10’ x 4’ and 5’ high…and I followed your plans…I have four strong fans in it. These slabs were air dried for 6 months and have been in the kiln for about 4 weeks.
The slabs in the kiln now will be made into a table that will be shipped to the Midwest (Chicago).
Can you give any input?...any help is greatly appreciated.
Bryan@liveedgewoodtables.com
-- Bryan@liveedgewoodtables.com
View WDHLT15's profile
WDHLT15
1705 posts in 2352 days
#1 posted 02-17-2015 01:48 AM
it needs more time for the core and shell to equilibrate. Maybe a couple more weeks. Keep the dehumidifier running. You are close.
View peekasan's profile
peekasan
21 posts in 1581 days
#2 posted 02-17-2015 02:08 AM
The three key elements of a kiln are relative humidity, air flow, and temperature. Add a heater and get the temp up. See if that helps.
View Logboy's profile
Logboy
52 posts in 3106 days
#3 posted 02-17-2015 04:46 AM
Patience, grasshopper. Slabs take longer than lumber to reach equilibrium. The internal moisture has to migrate to the surface before it can evaporate off. That said, I woudnt be the least bit afraid to move those into a warm dry building at those MCs. It might even reach EMC faster. Airflow does little at lower MCs, its all about temp and humidity.
-- No log is too big to saw! www.logboy.com
Liveedgewoodtables
#4 posted 02-18-2015 02:38 PM
Thanks guys for your help. At least I know I’m on the right path. the thing about leaving the dehumidifier on is that it essentially was only working as a fan towards the end…it was accumulating absolutely no moisture.
long story short..i did get impatient and pulled the slabs from the kiln and placed them in a dry building…and will be working them in a couple of weeks….and of course, will be hoping for the best.
