Dust collector specs question.
Forum topic by Betsy posted 202 days ago 246 views 0 times favorited 7 replies Add to Favorites Watch
View Betsy's profile
Betsy
2386 posts in 789 days
202 days ago
I am in desperate need for a new dust collector. The motor is about as creaky as my knees and it just can’t keep up any longer. So I’m searching the net. I was looking at the Jets and one thing has given me a question. What do they mean by “Single stage design for economical, quiet operation?”
All thoughts welcome.
View PurpLev's profile
PurpLev
2745 posts in 542 days
202 days ago
read: it’s less powerful, and not as good as the 2 stage motors (2HP+ 220v) – but hey – we can use that as a selling point, since it also makes less noise than the bigger motors, and costs less….
Edit : I merely refer to the questioned sentence’s meaning… I do not have any negative views of single state DCs – I own one, and think it’s great! if you don’t have 220v available, and don’t have 1K+ to invest in a collector + ducting, the single state are the only solution, and depending on your way of using them (one machine at a time, or smaller permanent runs) and their strength, they are of great value!
View pauldeo's profile
pauldeo
25 posts in 220 days
202 days ago
My 2 cents is this, for a good, economical, DC, look at Harbor Freight. I have heard a few people say they had problems, but I use my DC from Central Machinery everyday, and have had no problems. it is a 2 HP unit which will keep up with 2 smaller machines, such as a bandsaw and router table, and will adequately handle a shaper, tablesaw, jointer or planer one at a time. I think they are on sale now for 179.
16715 posts in 471 days
202 days ago
Well I owned a 2 stage Oneida and never got it installed sold it because I was moving and now own 3 cheepie harbor freight dust collectors rated by them at 1800 cfm. I just own 3 because there cheep and I run 1 for my table saw , one for my jointer,one for every thing else . I have two mounted out side so catching 1mil dust is not and issue . I bought each one for $200 or less on sale. They have been in place more than 5 years and work fine. I never would have guessed they would be this good and last this long since I have been pretty pickie about the tools I buy.
View pickles's profile
pickles
50 posts in 307 days
202 days ago
Betsy, not sure what your budget is but I played around with several bag (single stage) dust collectors and found that they are a pain to empty and a pain to reassemble. Also, the inexpensive ones are chip collectors not dust collectors and become inefficient when dust accumulates. I made my own cyclone based on Bill Pentz’s design and it is unbelievably powerful and easy to empty. I found a woodtek 3 hp dust collector on cragslist for $150 for my motor and impeller. Probably spent $700 total on stystem with duct work (i have friends who work in construction) and wouldn’t ever go back.
View Durnik150's profile
Durnik150
536 posts in 215 days
202 days ago
Betsy, A single stage basically send all of the material it collects to the collector. There is no separation of bigger pieces from the finer particles. The drawback is that your filter bag (usually 5 micron but I recommend a 1 micron) is exposed to all of the material coming in. I got a single stage Delta 50-760 on sale at Rockler for $349. Keep in mind you will also spend a pretty penny on all the hoses, blast gates, etc. I’d say I put about $600 total before modifying it (below) to a 2 stage.
A 2 stage collector sends the airflow through a container where the larger pieces drop into a bin or trash can. This way the filter only has to deal with the finer particles it was designed to filter.
You can turn your single stage into a two stage by sending the air through a cetrifugal lid mounted on a trash can. The big particles fall and the finer ones move on to the DC. The lids usually run around 30-40 dollars and you have to buy a metal trash can to mount it on ($20?). Don’t get a plastic one or it will collapse under the vacuum.
I hope that helps.
-- Behind the Bark is a lot of Heartwood----Charles, Centennial, CO
Betsy
202 days ago
Thanks guys. Pickles – you sound quite handy with things like that. Not sure I could make my own DC though. Sounds like a two stage would be best. Durnik – your explanation is great. I’ve seen those lids and have not paid much attention to them as I was not sure what they were. Now I know.
I’m going to have to get one this week as when I went in from the shop last night – it became painfully obvious that my current one is not doing the trick. The thick layer of dust on the furniture made it clear enough. Can’t imagine what I’ve been breathing in.
Thanks for the help guys.
View BlankMan's profile (online now)
BlankMan
433 posts in 247 days
202 days ago
PM sent.
-- -Curt, Milwaukee, WI
